Pushrod length sound accurate ? - Vintage Mustang Forums
post #1 of 2 (permalink) Old 05-22-2019, 07:30 PM Thread Starter
Here's what I have;
1991 5.0 block decked .010
Flo Tek aluminum heads 158cc/58cc which use 5/16" pushrods & guideplates
Compressed thickness of head gasket is .045
B303 Cam .480 lift with 1.6 rockers
1.6 roller rockers
A local mechanic came over today with an adjustable pushrod tool and says 6" is the length pushrod I need...he determined this in less than 60 seconds without taking any of the cam specs into consideration.
Obviously I know little to nothing about this process but I watched a video in youtube "Push rod geometry for engines" which stressed sweating the details on gross valve lift in order to determine the exact length pushrod needed.
Just wondering/hoping someone who has a similar setup or has done this numerous times can tell me if a 6" pushrod sounds accurate ?
Flo Tek website says stock 5.0 pushrods, which are 6.272" can not be used with their heads.
Thanks !
65 A code Silverblue convert T5 & 5.0 swap
64 Indy Pace Cars 5F07F113217 & 114176 - sold
aaron29 is offline
post #2 of 2 (permalink) Old 05-22-2019, 07:34 PM
Woodchuck's Avatar
Well, take a look at the link and you tell me whether you think he got it right....
http://www.compcams.com/Technical/In...20Geometry.pdf
Bart
What, me worry?
- Alfred E. Neuman
Woodchuck is offline
Similar Threads
Pushrod length 67 sprint AZ Vintage Mustang Forum 0 08-31-2018 06:55 PM
Pushrod length and chevy valves 67 sprint AZ Mod and Custom Forum 2 08-20-2018 07:45 PM
rocker to valve stem wear pattern - Is this acceptable Brian66 Vintage Mustang Forum 20 07-05-2018 08:28 AM
Push rod length wichol98 Vintage Mustang Forum 2 05-12-2018 04:01 PM
correct pushrod length for a 93 roller motor Damron801 General Discussion (Non-Vintage Mustang) 4 12-26-2017 12:37 PM
