Sparks in Steering Column. Electrical Problems? - Vintage Mustang Forums
 4Likes
post #1 of 16 (permalink) Old 05-23-2019, 01:53 AM Thread Starter
luiscovar's Avatar
Hey VMF,
I've been having an issue with my car which I think started from when I saw sparks in the steering wheel column. Before this my car would start with the key and the radio would work fine but ever since I saw the sparks (and occasionally hear some electricity crackling noises) but now that stopped working. I cannot turn on the key with the key, I turn the key all the way and I nothing happens. The lights turns on, the radio turns on, the fan turns on but no noise from the engine where I turn the key.
Another problem I am facing is my radio constantly turning off and on when I am driving. I noticed this especially happens when I hit a bump or when I am making a turn (left or right). And today as I was pulling out of the drive thru I heard some electric crackling in the steering where column and the car turn off. The only reason I am still able to drive it is because I can start the car by connecting the contacts in the starter solenoid.
Any idea why this is happening?
luiscovar is offline
post #2 of 16 (permalink) Old 05-23-2019, 02:22 AM
69GT350H's Avatar
I would definitely look at the wiring in the steering column if that is where the sparking and crackling noise is. It sounds like a wire (positive 12v) is shorting out against metal (ground).
VMF Build Thread - 1969 Shelby GT350 Hertz rebuild Gallery
Used by Hertz for the 1969 "Rent-A-Racer" program at Miami Internation Airport.
69GT350H is online now
post #3 of 16 (permalink) Old 05-23-2019, 02:51 AM
Joe
I would start by pulling the steering wheel and inspecting the horn slip ring and brushes. As "emergency" equipment, the horn circuit is unfused and has constant battery power, even with the ignition off. Unfortunately, this means that a short in the steering column can wreak havoc on your entire electrical system. Make sure you disconnect the battery before doing anything!
'65 Coupe, 302, Autolite 4100, C4, 3.00
Joe is offline
post #4 of 16 (permalink) Old 05-23-2019, 06:51 AM
22GT's Avatar
What steering wheel do you have?
Amateur restorer. Well, sometimes I have been paid for it. But not right now.
22GT is offline
post #5 of 16 (permalink) Old 05-23-2019, 10:25 AM
Just some guy
GypsyR's Avatar
IE, is it a GRANT? In which case a non-functioning horn and occasional sparks are considered normal.
GypsyR is offline
post #6 of 16 (permalink) Old 05-23-2019, 04:11 PM Thread Starter
luiscovar's Avatar
I have the one in the picture. Not sure what kind it is though.
post #7 of 16 (permalink) Old 05-23-2019, 04:17 PM
When this happened to me, the horn ring was coming into contact with one of the connections on the hazard switch. Make sure all the pin bodies are flat and below the plastic cover that should be on the switch.
1970 Mach I, 351C, 4-spd, Medium Gold Metallic, 1 of 1 with delivered options
1967 Shelby GT-500, Dark Moss Green with Parchment Interior (1 of 64), concours restored
unitedwestand212 is offline
post #8 of 16 (permalink) Old 05-23-2019, 05:08 PM
22GT's Avatar
HmmmÖ Not seeing a picture.
22GT is offline
post #9 of 16 (permalink) Old 05-24-2019, 01:03 AM Thread Starter
luiscovar's Avatar
Sorry, forgot to attach picture.
post #10 of 16 (permalink) Old 05-24-2019, 02:09 AM
Full gallop this way --->
4ocious's Avatar
That there's a Grant, and if the horn/hub bits look something like these they are notorious for causing fires.
I reconfigured a base '68 coupe a little bit...
4ocious is offline
post #11 of 16 (permalink) Old 05-24-2019, 08:37 AM
awhtx's Avatar
It's not the Grant steering wheel that's the problem- it's the Grant hub/horn kit that causes the sparks and fires. Get yourself a GT Performance hub/horn kit.
https://gtperformance.net/product/10...tall-hub-ford/
awhtx is offline
post #12 of 16 (permalink) Old 05-24-2019, 08:51 PM
FrankieThe69Kid's Avatar
I have a Grant. I installed a horn button under the dash and took the horn pins out of the hub. Had one catch fire once.
69 Convertible, 351W, T5, E-Brock Performer 351-W intake, Performer Plus cam, Holley 4160, power assist, dual exhaust, 4-wheel manual drums.
FrankieThe69Kid is offline
post #13 of 16 (permalink) Old 05-24-2019, 09:50 PM Thread Starter
luiscovar's Avatar
Thanks, I’ll probably end up buying this and replacing it. Hopefully that fixes the problem. Will a replacement also fix the issue where I can’t start the car with the key? Or does the problem go beyond that?
post #14 of 16 (permalink) Old 05-24-2019, 10:30 PM
Thanks, Iíll probably end up buying this and replacing it. Hopefully that fixes the problem. Will a replacement also fix the issue where I canít start the car with the key? Or does the problem go beyond that?
That sounds like the ignition switch to me... or the connector. Get under the dash and look for the fat yellow wire and make sure it's not worn somewhere where it can short. "BIG SMOKE!" was the warning I was given many years ago when I was having similar problems.
I'd turn the key and get nothing. I'd reach behind the ignition switch, move the "fat yellow wire" a little, turn the key again and the car would start.
Replaced the ignition switch and it's been good ever since... ever since 2006.
post #15 of 16 (permalink) Old 05-25-2019, 01:26 PM
Just some guy
GypsyR's Avatar
On your car, though I don't believe there's an obvious direct connection between the sparks and your starting it is quite obvious you need to attend to the sparking stuff first as it's a fire and safety hazard. Then see is your starting issues are affected or even fixed. It's worth a try. The upgraded adapter should take care of your steering wheel problems.
I like my Grant Signature wheel on my '67 just fine and have no interest in any other. Out of our three Mustangs two have Grants on them and when I get to that point, the third probably will have one too. Grant makes a number of other very nice wheels. But I'll always be right in line to criticize their crummy adapter kits. They're not even funny.
68Hildago likes this.
GypsyR is offline
Similar Threads
CJ Pony Parts Experience EvenFlow Vintage Mustang Forum 70 Today 06:06 AM
'65 steering column install 65GTKcar Vintage Mustang Forum 12 09-19-2018 07:41 AM
73 Mustang steering column install mfendley Vintage Mustang Forum 2 07-22-2018 08:33 AM
1968 mustang steering column rebuilding questions. adumb Vintage Mustang Forum 5 02-04-2018 06:09 PM
1968 steering column assembly questions GBailey1018 Vintage Mustang Forum 18 01-09-2018 08:07 PM
