Starter motor weirdness - Vintage Mustang Forums
 14Likes
post #1 of 30 (permalink) Old 05-24-2019, 11:33 AM Thread Starter
Brief description of the issue:
1. 65 Mustang that I drive weekly made a grinding noise when I tried to start it first time (for the week).
2. Second attempt to start it was successful and there was no grinding noise. Drove it to the store and turned it off. Nothing abnormal during driving.
3. Started it up to come home with no issue or grinding.
4. Park it in the garage and shut it off. Attempt to start it again and this time the starter spins but the motor doesn't.
5. Ordered new PA Performance PMGR starter and installed it according to instructions with extra wire and moving original wire to the positive side of the solenoid. New starter does the exact same thing - spins but doesn't engage.
6. Ordered new starter solenoid (fender wall) and installed it. Same exact results.
I've tested voltage on my battery and it is 12.5 Volts at rest. No changes to the vehicle recently. The starter and solenoid I replaced had been working for 10 years with no issues.
EDIT: checked flywheel teeth and they looked decent. Have rotated engine with a wrench in case teeth were bad in one area.
Any ideas?
Sent from my Moto G (5) Plus using Tapatalk
1965 Fastback owned since 1986 - original 289 block & heads - bored .030 over - ported & polished heads - triple angle valve job - performer RPM intake and cam - 10:1 compression - forged pistons - 600cfm holley 4150 - ford full length headers - 4 speed toploader - original 8 inch rear with 3.73 LSD - wilwood front disc brake conversion - upgraded suspension lowered 1 inch - welded sub-frame connectors - 3 row radiator - monte carlo bar - export brace - complete MSD ignition
19Fastback65 is offline
post #2 of 30 (permalink) Old 05-24-2019, 11:43 AM
Appears that starter bendix gear is not engaging with flywheel gear. If you have replaced starter and still not engaging then pull starter and look at flywheel ring gear and see how it looks.
Jedi is offline
post #3 of 30 (permalink) Old 05-24-2019, 11:51 AM Thread Starter
Sorry just edited my post to add that I inspected the teeth and also rotated flywheel manually in case one area was bad.
post #4 of 30 (permalink) Old 05-24-2019, 01:49 PM
Hemikiller's Avatar
Which starter number did you order? Looks like they have their applications screwed up. It's not as simple as 65-78 auto or manual.
Powermaster has a great graphic explaining the issue.
c6fastback and 19Fastback65 like this.
Nothing worthwhile is ever quick, cheap or easy, those that can't do, complain
71 Mach 1
HOLLEY TECH PAGES
FORD OE TACH HOOKUP FORD OE TACH HOOKUP w/MSD (pg 7)
Hemikiller is offline
post #5 of 30 (permalink) Old 05-24-2019, 02:02 PM
erials's Avatar
I also had this problem in my manual shift 66. Very annoying and thought I would eventually ruin the ring gear on my flywheel if I didnít fix it.
Went through a couple of starters listed for manual but problem continued. Finally I went to auto zone and asked for the starter listed for the automatic. Installed it and never had this problem again.
forums.vintage-mustang.com/forums/photopost486/showgallery.php?cat=500&ppuser=20265
66 Mustang 2+2 FB
GT Replica
289 4 speed, 4bbl carb, dual exhaust, rally pac, console, a/c and p/s.
Progressive rate springs and 1 inch sway bar.
erials is offline
post #6 of 30 (permalink) Old 05-24-2019, 02:12 PM Thread Starter
I ordered the PA Performance 1881, but I think you are right. It isn't the correct depth.
post #7 of 30 (permalink) Old 05-24-2019, 02:26 PM Thread Starter
So it looks like the only other starter that PA Performance sells for older mustangs is the 1806.
post #8 of 30 (permalink) Old 05-24-2019, 02:55 PM
erials's Avatar
I looked at the 2 starters listed on the PA Perf site and these appear to be custom and I could not find any details regarding dimensions or starter drive action distance on the site.
In my case, I used the stock style rebuilt starters that auto zone showed at the time. I was only looking to solve the flywheel engagement/ grinding problem I was having.
In comparing the manual to the automatic starter on the counter at the store, it seemed that the nose on the automatic starter extended just slightly more than the manual. This is what made me try the one listed for A/Tís. Since youíre going the aftermarket performance route I canít say definitively that either of the starters listed on their site are going to solve your issue. The other starter may be the answer I just canít say for sure.
Might be worth a call to them to see if they can provide details that will confirm one way or the other. Sorry Iím not more helpful.
66 Mustang 2+2 FB
GT Replica
erials is offline
post #9 of 30 (permalink) Old 05-24-2019, 03:17 PM
Hemikiller's Avatar
The problem is Ford swapped starters around depending upon car lines, models, options and other factors, but a bigger problem is that parts have gotten mixed and matched over the last 50+ years.
From the factory, Mustangs are fairly easy - 65-68 289 used the deeper "automatic" starter for all transmissions as they both used a 157th flywheel/flexplate. Beginning with the 302 in '68, they used the 164th flywheel which used the shallower "manual" starter, as the ring gear was on the "front" of the flywheel. Automatics still retained the deeper "automatic" starter. This carried through '73 with all 302, 351W & 351C engines.
19Fastback65 likes this.
71 Mach 1
HOLLEY TECH PAGES
post #10 of 30 (permalink) Old 05-24-2019, 03:24 PM Thread Starter
Hemikiller, it seems that Powermaster is aware of this but PA Performance is not. Talked to them on the phone. Now will have to see what I have to do to get this problem resolved.
post #11 of 30 (permalink) Old 05-24-2019, 03:53 PM
C6ZZGT's Avatar
Any ideas?
How long was the original starter in the car ? Why not just change the Bendix (starter drive)?
6r07a143871 --owned since 10/83
C6ZZGT is offline
post #12 of 30 (permalink) Old 05-24-2019, 05:45 PM Thread Starter
I'd say around 15-20 years. I like the idea of shaving 12 pounds off the front of the car and it's much easier to install/remove the new style mini-starter when you have long tube headers. CJ Pony gave me a refund, so thanks to them I can order the right starter now.
post #13 of 30 (permalink) Old 05-24-2019, 05:52 PM
PA 1806 (auto) starter is the one you want. I recently installed one and it works flawlessly. Unfortunately for you, since you have installed and engaged the starter, they may not swap it out for you. Phone call is in order.
patrickstapler is online now
post #14 of 30 (permalink) Old 05-24-2019, 09:03 PM
awhtx's Avatar
It sounds to me like you have a starter for a 164 tooth flywheel installed on an engine that has a 157 tooth flywheel.
awhtx is offline
post #15 of 30 (permalink) Old 05-24-2019, 10:16 PM Thread Starter
Stupid question. The Powermaster has a part listed for EFI engines only yet it appears to physically fit my application. What does EFI have to do with the starter?
Similar Threads
bypassing pmgr mini starter solenoid dbenichou289 Mod and Custom Forum 19 05-05-2019 04:54 PM
New starter problem(probably ground related) macstang Vintage Mustang Forum 4 02-03-2019 10:43 PM
Another Starter & Ground Question DavidJSmith Vintage Mustang Forum 6 09-27-2018 09:56 PM
PMGR install without starter run-on issue dbenichou289 Mod and Custom Forum 1 03-24-2018 08:28 PM
Correct starter for a '65 200L manual... Varilux Vintage Mustang Forum 15 02-04-2018 11:25 PM
