Sticky throttle - is a spacer problem? - Vintage Mustang Forums
post #1 of 3 (permalink) Old 05-26-2019, 02:38 PM Thread Starter
I have a 1966 convertible with a 289 4 Barrel. It was my Dad's car before it ended up in my garage. His throttle tended to stick (I'm using throttle just as a general term to explain the problem). When he hit the gas pedal the throttle would stick and he would have to feather the pedal to drop the RPM's. He couldn't figure out the cause so he ended up attaching springs to the pedal to counteract the sticking. This didn't seem to work very well though.
Two years ago I rebuilt the engine from the ground up with two mechanic friends. I replaced the carburetor with a rebuilt stock carb and most everything else was replaced. AND IT STILL STICKS!
The one thing I didn't replace was the spacer. Could that be the problem? Could the flaps in the carb get stuck on/in the spacer? Do I really need the spacer? Any thoughts? The engine just purrs but the throttle sticks constantly making it not very enjoyable to drive.
Thanks,
JP
My Dad's '66 - now mine!
jp1131 is offline
post #2 of 3 (permalink) Old 05-26-2019, 02:48 PM
The spacer is how the PCV valve is plumbed. Yes I have seen throttle plates hit the edge of the spacer and cause a bit of sticking.
Also check the drivers side motor mount. If it is busted, the motor rocks on accel and that pull the throttle open more which leads to a runaway stuck throttle effect.
Everybody has to start some place
Asm109 is offline
post #3 of 3 (permalink) Old 05-26-2019, 03:13 PM
Brian Conway's Avatar
Throttle plates sticking on the paper gasket above the pcv plate/spacer? Get the air cleaner off along with the throttle return springs. Operate the throttle manually and see what's going on. Brian
5R09A 4 Speed GT Built 5/29/65
9T02R 4 Speed SCJ Built 9/19/68
Owner Driver Mechanic
Brian Conway is online now
Similar Threads
5.0 install in 65 Convert...Question on crank pulley spacer aaron29 Vintage Mustang Forum 4 04-23-2019 11:46 AM
Built Phenolic Spacer ... Still hard starts when hot KillaBeave Vintage Mustang Forum 15 08-30-2018 11:37 AM
Vacuum leak causing surging during partial throttle? aakrusen Vintage Mustang Forum 17 07-05-2018 08:28 PM
Throttle Return Spring - Probably Overthinking Again jomotopia Vintage Mustang Forum 1 05-07-2018 09:20 PM
Fast idle problem....finally a (surprising) diagnosis! pathwayrev Vintage Mustang Forum 12 05-03-2018 11:17 AM
