Engine build - Vintage Mustang Forums
 8Likes
  • 5 Post By awhtx
  • 1 Post By rbohm
  • 1 Post By ophthos
  • 1 Post By Chip Phillips
post #1 of 14 (permalink) Old 06-14-2019, 11:18 AM Thread Starter
ophthos's Avatar
Engine build
Not planning on doing anything until the fall/winter, but I'd like to do my research and plan ahead. Going to pull out my 289 and do "something" to get more horsepower. I know I could drop in crate motor but what's is the fun in that. Looking to upgrade the 289, going to keep the C4 and the 8" but change gears. Need to get the 2:80's out.
Don't know anything about the engine other than it is a C code with the prior restorer put a cobra intake manifold and a Holley 4 barrel. Engine runs nice, great vacuum, just not peppy enough. Plan is for a street engine. This car will never see the strip and I drive it a lot. Don't need high rpm power, looking more for spirited driving from stop light to stop light.
So, if you were going to build your dream 289 street motor what would you do? And while were at it, what would you do to the C4 and what gears would you put in? Just remember, I plan on driving this car around town, back and forth to work (5 miles) 3-4 times a week and as much as I can on weekends.
I'm fortunate that I can spend some money but I don't want it to get so expensive that's its cheaper to drop in a crate motor. Also I know things may change when I get into the motor, but lets assume its a stock bottom end and is not max bored out.
lets have some fun and build me a kick ***** street motor!
66 Convertible, GT clone. 289 4V, C4. Springtime yellow with black top
ophthos is offline
post #2 of 14 (permalink) Old 06-14-2019, 12:37 PM
awhtx's Avatar
22GT has posted the "recipe" for a hot little 289 many times. Maybe he'll come along and post it again. Basically a cleanup with port matching on the heads and a hydraulic version of the old solid 289 HiPo cam. Distributor tune-up by Dan at Mustang Barn. Tri-Y headers.
kenash, subpar63, 2nd 66 and 2 others like this.
awhtx is offline
post #3 of 14 (permalink) Old 06-14-2019, 01:00 PM Thread Starter
ophthos's Avatar
So I read about Dan. Stupid question: I took points out and put Pertronix in, does the distributor still need to be tuned up?
ophthos is offline
post #4 of 14 (permalink) Old 06-14-2019, 01:18 PM
Yes, he can still set it up for you, give him a call and let him know the specs on the motor. I've put a Mallory Espark in my old dual point YL dist.
Jedi is offline
post #5 of 14 (permalink) Old 06-14-2019, 04:14 PM
Grimbrand's Avatar
Pertonix kit just gets rid of the points; the mechanical and vac advance stuff still needs to be set up right, as does the timing when you put it back in. Summit M-series 500 cfm carb, unless you happen to have a good 4100 1.12 lying around.
If having it look stock is most important to you, then the factory 4v manifold would be fine. Otherwise, I'd put on a Weiand Stealth, and (if money's not a problem) some AFR 165 heads.
When you ONLY drive around in-town, you can get away with steeper gears, and the 289 does not mind RPMs much with its short stroke. You could maybe even go with 3.73's if you never intended to get it out on the highway. They'd sure be fun! But if you occasionally get it up on the interstate, I'd keep to 3.25 or lower gears, just to ensure double-digit economy, and save wear on your u-joints, engine, and ears.
"No matter what you are, be the best one you can." -Abraham Lincoln
Grimbrand is online now
post #6 of 14 (permalink) Old 06-14-2019, 04:27 PM
HoosierBuddy's Avatar
I went down this road with my old 289 before I bumped up to a 347.
I agree that the "dream" engine has aftermarket heads, and in my case that was the aforementioned AFR165 heads with 58 cc combustion chambers.
HOWEVER...if you do change heads, you have to keep in mind that most will lower your compression ratio considerably and if you have stock C-code pistons WORSE the pistons will hit the new larger valves with any kind of useful cam at all as the stock C-code pistons in '65 didn't have any valve relief. They just have a little dish cut in the top of them.
SO...a perfect piston to use with a '65 289 and AFR 165 heads is the Keith Black KB116 piston. It's a pop up style that will get you right up to 10:1 CR. You can run that with the aluminum heads and mid-grade or premium gas just fine. They are hypereutectic...which is better than "cast" and cheaper than "forged" so kind of middle-of-the road in price and quality.
On top of that, you'll want a dual plane or dual plane hi-rise 4 barrel intake and a carburetor (or EFI unit) with about 600CFM (or a little less) capacity.
For the top end, I went with Comp stuff including a cam they recommended and their roller rockers....but some have complained about their quality as of late, so I leave that for further research.
Long story short...my 289 ran great with that stuff on it. Well enough that it destroyed my OEM C4 in about 2 weeks.
But you can fix that too. It's just time and money.
Phil
"Two barks means faster!" Enzo
HoosierBuddy is offline
post #7 of 14 (permalink) Old 06-14-2019, 04:34 PM
Back when I first had my '66 Fastback, we rebuilt the A-code 289 with ported and polished 351W heads, Lunati cam and lifters (wish I could remember the specs, had enough thump to it to be fun), Holley 600 carb converted to a double pumper, Edelbrock RPM intake, 289 HiPo dist that was converted to elect ign. hooked up to a MSD 6AL box, Tri-Y headers and a 65 Shelby style racing side exhaust. Can't remember what else we did to it.
The 289 is a great little V-8. I wish that when I bought the car back in March that it was still in it. But that motor came out and was donated to another project and now has a crate 302 in it (not my choice)...
Steve
Current Stable: 1966 A-code Fastback (302 Ford Crate motor, T-5)
2008 Shelby GT Convertible
Former Mustangs: 1967 A-Code Fastback (sold to buy the ‘66 Fastback 33 years ago)
‘66 A-Code Fastback (owned it from 1986 to 1999, sold it to a friend, who sold it to another fellow Mustanger. I just repurchase the car in Mar. 2019...)
‘95 GT Convertible
‘14 MCA Edition (Mustang Club of America) with Performance Pack
TUS ‘66 2 + 2 is offline
post #8 of 14 (permalink) Old 06-14-2019, 05:09 PM
RV6
RV6's Avatar
3.55's in the rear will do wonders. I run my little 289 with Perfomer RPM heads (6025) and manifold. I bumped the compression up using domed pistons (Keith Black 116-030) and installed a Crowler 15208 cam and 1.6 roller rockers. The heads were also shaved a little to bump the compression. She's sporty from 1500-5500 RPM and gets 20 MPG on the highway with the T5.
I live at 8500' MSL and she runs great. At sea level she'll smoke the tires at every stop light if I push her.
Gary
Pine, CO
1967 Coupe, 289-4V, T-5
RV6 is offline
post #9 of 14 (permalink) Old 06-14-2019, 07:59 PM
rbohm's Avatar
i am going to build a mild 289 for my 66 coupe when i get the energy to build it. it will have windsor jr heads, a comp cams retrofit roller cam with .480 lift/260 advertised duration with the 351w firing order(i was going to use the cam in a 351w but sold that engine), flat top pistons, tri-y headers. i havent yet decided on an intake, though likely it will be either an edelbrock performer rpm or a weiand stealth and it will be topped with either a 4100 autolite carb, a 600cfm edelbrock performer carb, or possibly one of the bolt on throttle body EFI systems on the market.
i figure this build will make about 325hp, and with a C4 and 3.25-3.50 gears will do very nicely on the street.
2nd 66 likes this.
64 falcon
66 mustang
05 grand marquis
a man's fate is a man's fate
and life is but an illusion
fordsix.com admin
rbohm is offline
post #10 of 14 (permalink) Old 06-14-2019, 10:30 PM Thread Starter
ophthos's Avatar
Thanks for all the responses.......I have a lot to learn and read about. I'm kind of a newbie to all this. The 66 is the first classic car I've owned, but I'm learning as I go along. From what I've learned about myself, when i get into the engine, I will probably tear the whole thing down. Check the block and rebuild the entire thing from scratch. Just need to find a good engine shop in my area and have a plan before for every possibility before I get into it.
From what I found under the dash, I don't trust the prior "restorer". I had to replace the entire under dash wiring, so for peace of mind, I'll probably do a complete rebuild, so replacing the whole rotating assembly is a possibility. I'm fortunate enough not to have to worry too much about a budget.
thanks again for the info so far. Gives me something to read over Fathers day weekend!
ophthos is offline
post #11 of 14 (permalink) Old 06-14-2019, 10:34 PM
Do your self a favor and get the Tom Monroe book How To Rebuild Your Small Block For or google the free PDF ( I can't post it any more )
2nd 66 is offline
post #12 of 14 (permalink) Old 06-14-2019, 10:39 PM Thread Starter
ophthos's Avatar
Already picked it up. Good to know its recommended!
2nd 66 likes this.
ophthos is offline
post #13 of 14 (permalink) Old 06-14-2019, 10:47 PM
very much so
2nd 66 is offline
post #14 of 14 (permalink) Old 06-18-2019, 12:16 AM
I just went through the same thing-my dad gave me his 65 convertible 289 that we had restored back in the 1980's together. We were considering it pretty high performance-Erson flat tappet cam, 4 bbl holley 600 vac. secondary, dual exhaust, Mallory Unilite ignition, 3.31 gears. It was sure fun when I was in highschool. So, recently I wanted to do something different with it. Started out thinking I would do a 347 with the 289 block, but after talking to some engine builders sounded like the best idea would be to drop a 302 block in there and keep the matching 289 aside. I found a 1971 302 long block on Craigslist for $100 and sold the heads/etc. Thought about the Eddy stuff, but for a bit more you could get some AFR 185''s Then, for a bit more, roller cam with retro-fit lifters (I"m using a Bullet Racing 284/292 , .588/.585 lift LSA 109 cam). I'm also using a 750 Brawler race carb, you could use a 650 with less tuning I'm sure. Some dougs try-y headers that I got a good deal on at amazon I don't know how :0 And a 2.5 inch Magnaflow exhaust system. To me, it seems just right-I don't race but like power. In fact, I wouldn't mind more. I don't regret spending the extra her and there for the good stuff in other words.
myfirstcar66 likes this.
Chip Phillips is offline
