1965 Mustang LED turn signal indicator in instrument panel - Vintage Mustang Forums
post #1 of 9 (permalink) Old 06-14-2019, 12:38 PM Thread Starter
Is there any way to get an LED turn signal indicator working for both directions in the instrument cluster?
Swapped all the incandescent bulbs for LED bulbs and of course the turn signal indicator light only works one way, which I've read is because the 65 only has the 1 light and switches polarity to indicate left/right, which doesn't work with an LED bulb.
Is there any way to get this working with an LED bulb? Or is the only way to get both left/right working to switch that one bulb back to incandescent?
mustang6518 is offline
post #2 of 9 (permalink) Old 06-14-2019, 01:25 PM
DustoffMedic's Avatar
I have a 65 also and when I redid the cluster I used all LEDs and also replaced the constant voltage regular, the little one on the back of the cluster. Plus, make sure you have a LED type flasher and a good ground.
DustoffMedic is offline
post #3 of 9 (permalink) Old 06-14-2019, 01:28 PM Thread Starter
Yep, I also replaced the voltage regulator. What do you mean an LED type flasher? Right now my whole car is incandescent apart from the dash cluster and footwell lights.
post #4 of 9 (permalink) Old 06-14-2019, 01:58 PM
myfirstcar66's Avatar
They are an electronic type with a printed circuit inside instead of just a bi-metal spring resistor. I think the number is 532. I got one at NAPA.
My 1st car...
'66 Tahoe Turquoise/ Aqua coupe
•289 / 4100 •C4 Auto •Disc Brakes
•Dual Exhaust •Quick Manual Steering
•Rally Pac •Console •Deluxe Belts
•LOTS of Rotunda accessories
Older son's 1st car...
'66 Emberglo / Parchment deluxe coupe
•289 / 2100 •C4 Auto
•Dealer A/C • Console
•Dual Exhaust • Power Steering
Younger son's 1st car...
'66 Nightmist / Blue & white deluxe coupe
•Factory A/C •Console
WAITING FOR RESTORATION
myfirstcar66 is offline
post #5 of 9 (permalink) Old 06-14-2019, 01:59 PM
LED lights react differently to voltage and they need a different "pulse" from the flasher. If you ever upgrade your rear lights to LED which I did you'll need one to prevent "hyperflash", that rapid blinking. Meanwhile, it can't hurt to use one. It may solve your problem.
post #6 of 9 (permalink) Old 06-14-2019, 03:40 PM
Magnus's Avatar
@gtonavy here on the board sells a special bulb that's supposed to work in the 65 dash:
1964-1966
I haven't tried it but his other lights are great so I'm gonna guess this one should work perfectly and it's only $10.
Magnus is offline
post #7 of 9 (permalink) Old 06-14-2019, 06:23 PM
New2me's Avatar
You might consider keeping incandescent bulbs in the turn signal and high beam indicators. A few years ago I changed all my dash lights to LEDs including those two and it was great until I drove it at night. Those two are bright enough at night to be distracting, enough so that I had to pull my instrument cluster back out and put incandescents back in those two sockets.
Early 65
1998 5.0, fitech efi, holley in tank returnless pump
4R70W transmission with USShift quick 2 controller
3.00:1 8" open rear end
New2me is online now
post #8 of 9 (permalink) Old 06-14-2019, 08:21 PM
gtonavy's Avatar
I make a replacement isolated indicator bulb for your 65.
If you install this, your front turn LEDs will now work.
Just send me a PM or e-mail.
1967 CV 289 A Code
1973 450SL
http://www.vintageleds.com/
gtonavy is offline
post #9 of 9 (permalink) Old 06-14-2019, 08:24 PM
Nailbender's Avatar
Yep!
65 C Code hardtop from California still wearing it's original paint.
Roller 331, TW 170 heads, T-5z, FiTech EFI, FPA Headers, Arvinode exhaust, SoT Bilstien coilover front suspension, TJ on eBay 8" 3.40 Trac-Loc 3rd member. Mustang Steve 2008 GT bracketed 12.4" front disks
Nailbender is offline
