Need help on brake line flanges - Vintage Mustang Forums
 19Likes
post #1 of 28 (permalink) Old 06-15-2019, 02:21 PM Thread Starter
I have installed front disk brakes on my 66. I also installed the dual bowl master and distribution block / proportion valve /residual valve. I have to be the world's worst flange maker. The line that goes from the distribution block to the rear bake line leaks. Also the line that goes from the rear brake section of the master to the distribution block leaks. I have size 3X hands and I've been working in that little area for longer than I care to admit. Can anyone tell me how to correct my flanges? I've watched the videos on Youtube, but I'm still doing something wrong.
rjwin1967 is offline
post #2 of 28 (permalink) Old 06-15-2019, 02:27 PM Thread Starter
Here are my flanges.
post #3 of 28 (permalink) Old 06-15-2019, 02:56 PM
maladezo's Avatar
Try this, put some very slick assembly lube on the flare and nut, then go tight loose tight loose a number of times to seat it in. Then tight for the final seal.
My favorite lube for this is Torco MPZ engine assembly lube.
The SnapOn brake line wrench works much better than the Craftsman or Mac.
'67 coupe, 390, 4spd.
maladezo is offline
post #4 of 28 (permalink) Old 06-15-2019, 03:32 PM
gregb's Avatar
I can’t tell from the pic but is that single or double flared? If it’s double try not cranking down when making the double part. If it’s single you need to make it a double flare.
Hemikiller, cmefly, 2nd 66 and 1 others like this.
69 Mach One, 428CJ, 5 Speed, 3.91's.
gregb is offline
post #5 of 28 (permalink) Old 06-15-2019, 06:14 PM Thread Starter
Thank you. I'll give it a shot.
post #6 of 28 (permalink) Old 06-15-2019, 06:59 PM
pics look like single flair which is No bueno
Oh and they are called flares not flanges
Hemikiller and Woodchuck like this.
2nd 66 is offline
post #7 of 28 (permalink) Old 06-15-2019, 07:04 PM
carlite65's Avatar
Oh and they are called flairs not flanges
'flare' would be the correct spelling.
carlite65 is offline
post #8 of 28 (permalink) Old 06-15-2019, 07:05 PM
your correct
2nd 66 is offline
post #9 of 28 (permalink) Old 06-15-2019, 07:46 PM
awhtx's Avatar
your correct
"You're correct" would be correct.
awhtx is offline
post #10 of 28 (permalink) Old 06-15-2019, 07:47 PM
awhtx's Avatar
They certainly look like single flares to me and as stated, that is not correct for brake lines.
awhtx is offline
post #11 of 28 (permalink) Old 06-15-2019, 08:24 PM
Nailbender's Avatar
Yep!
Anyway, the flaring tool should have come with directions and pictures.
65 C Code hardtop from California still wearing it's original paint.
Roller 331, TW 170 heads, T-5z, FiTech EFI, FPA Headers, Arvinode exhaust, SoT Bilstien coilover front suspension, TJ on eBay 8" 3.40 Trac-Loc 3rd member. Mustang Steve 2008 GT bracketed 12.4" front disks
Nailbender is offline
post #12 of 28 (permalink) Old 06-15-2019, 09:07 PM
Grabber70Mach's Avatar
To me the end you say that is leaking the nut doesn't appear to me to be the correct one to be used on brake lines with a double flare. There doesn't appear to be enough recess for the flare to sit in properly.
Grabber70Mach is offline
post #13 of 28 (permalink) Old 06-15-2019, 11:19 PM
Meh, at least I got the terminology correct
2nd 66 is offline
post #14 of 28 (permalink) Old 06-15-2019, 11:21 PM
Woodchuck's Avatar
What your flare SHOULD look like... You need to use the double-flare adapter first before forming the flare.
Grabber70Mach and 2nd 66 like this.
Bart
What, me worry?
- Alfred E. Neuman
Woodchuck is offline
post #15 of 28 (permalink) Old 06-16-2019, 09:18 AM
All good advice. I've tried several of the lower priced double flaring tools, but this is the only one I've found that produces flares as good as the high priced tools, and it is very easy to use:
https://www.eastwood.com/eastwood-on...16-tubing.html
reevescajr is offline
