Will this Toploader work for me? - Vintage Mustang Forums
 1Likes
  • 1 Post By JEFFinOC
post #1 of 14 (permalink) Old 06-16-2019, 11:07 PM Thread Starter
JEFFinOC's Avatar
Hey guys,
I'm looking to convert my 302/C4 in my 68 FB to a 4 speed and wondering if this Toploader would work. It's a RUG M1 which is designed for a 390. But it is a wide ratio. I realize a RUG E2 would be optimal but would this still work?
https://losangeles.craigslist.org/sg...911520180.html
Thanks!
jbman likes this.
1968 Fastback J Code. Acquired April 2019. Project build with my two sons!
JEFFinOC is offline
post #2 of 14 (permalink) Old 06-16-2019, 11:09 PM
jbman's Avatar
Originally Posted by JEFFinOC View Post
Hey guys,
Thanks!
I thought the big block top loaders had a different input shaft.
Sent from my SM-N960U using Tapatalk
jbman is offline
post #3 of 14 (permalink) Old 06-16-2019, 11:15 PM
Ironstang's Avatar
Iíve owned a few 390 toploaders. The input shaft/pilot bearing were too short to reach the pilot bearing. The ones Iíve owned I replaced the input with a small block version and used them without issues.
Ironstang is offline
post #4 of 14 (permalink) Old 06-16-2019, 11:56 PM
gregb's Avatar
The shifter mount is also in a different location....requiring one made for the 390 cars.
69 Mach One, 428CJ, 5 Speed, 3.91's.
gregb is offline
post #5 of 14 (permalink) Old 06-17-2019, 06:48 AM
sixtysevenGTconv's Avatar
Hey guys,
Thanks!
I have an M1 in my 67 390 car.
I wonder about trans mount flanges to bell housing size? It maybe also longer meaning changing out driveshaft?
Minor this as said, need a trans shifter mount plate to relocate shifter? Maybe.
Longer speedo cable as M,M1, M2 all have cable going in on rh side of trans.
Trans mounting cross tunnel brkt is different for 390 trans.
If you borrow a tool more than twice, you need to own it You get what you pay for!
George email: <[email protected]>
sixtysevenGTconv is offline
post #6 of 14 (permalink) Old 06-17-2019, 07:13 AM
dobrostang's Avatar
THere are ways to mickey mouse a big block toploader to work on a small block, I have tried them all in the 20 years I ran a BB TL. None of them worked very well. I ran an adapter pilot bushing that went quickly, then machined one out of Silicon Bronze which worked the best. One time I took my BB TL to THE TL guy in Silicon Valley who sold me a BB input shaft he had welded an extension on so I had him put that in. It worked but eventually gave up and destroyed my TL case.
Best to replace the input shaft with a SB shaft if your not running crazy HP.
Next, its likely it has the wrong tail shaft, mine did but the PO drilled out the Hurst Comp Plus plate to put the shifter in the right place then had a custom drive shaft made to the right length. Getting the right tail shaft is possible.
Frankly, if you want to just drop it in, get the correct TL or if this is the right price and a known entity, do the work...
Heavy Metal Thunder Video http://www.youtube.com/watch?v=cW3L_O7N_xs
dobrostang is offline
post #7 of 14 (permalink) Old 06-17-2019, 07:26 AM
Hemikiller's Avatar
There are two length Toploaders, the 14" tail, which is this unit, and the 17" tail, which is used in full size Ford/Merc as well as certain Torino/Montego applications. Only difference between the small block and 390 unit is the input shaft is shorter on the 390.
Could use the Hurst shifter for the '67 390 Mustang, or I believe the two untapped holes by the tail bushing can be drilled and tapped to allow use of the small block shifter. There was also an adapter plate at one time that allowed the use of the forward pattern with the small block shifter.
All toploader speedometer gears are on the passenger side and require the long cable.
Toploader uses same trans crossmember as the C-4 and 3 speed with a small block. 390 toploader crossmember is different, but because of the engine, not the transmission.
That said - $1400 is a lot of money for a toploader you need to swap the input shaft on to have it work correctly.
Nothing worthwhile is ever quick, cheap or easy, those that can't do, complain
71 Mach 1
HOLLEY TECH PAGES
FORD OE TACH HOOKUP FORD OE TACH HOOKUP w/MSD (pg 7)
Hemikiller is offline
post #8 of 14 (permalink) Old 06-17-2019, 08:49 AM Thread Starter
JEFFinOC's Avatar
Thanks guys. You have easily talked me out of this. I was leaning that way anyway. Been looking for quite a while now, and the small block wide ratio TLís are not that plentiful. No worries, Iíll keep looking. Thank you for input!
JEFFinOC is offline
post #9 of 14 (permalink) Old 06-17-2019, 09:15 AM
Mustangerbob1's Avatar
Couple things:
Never believe the tag. For example, there are about 30 top loader 4 speed tags for sale on ebay, mostly in the $25 range. A couple taps with a hammer and chisel, and the old tag comes off, and you can put on another tag.
There are more top loaders out there. I have a 1965 rebuilt top loader for $1100 that I am listing on Craigslist tomorrow. I am in Dallas, but can ship it for about $100 or so to California. There are many more like mine out there.
[email protected] ed ay +3112
Richardson TX
1968 GT500 Arrest Me Red (The Big Boy Toy)
1966 K Code Vert (The K 'Vert)
Mustangerbob1 is offline
post #10 of 14 (permalink) Old 06-17-2019, 10:59 AM
Hemikiller's Avatar
There's a rebuilder close to that sells a rebuilt wide ratio small block Toploader for $1100 out the door, they'll buy your core if you have one.
https://www.reedstransmissions.com/our_products
71 Mach 1
HOLLEY TECH PAGES
post #11 of 14 (permalink) Old 06-17-2019, 12:18 PM
Jeff,
I have a nice used wide ratio small block top loader , with all factory linkage ( but no shift lever) for $850. If you are interested , I will take the trans to the "Pickers Paradise" swap meet at the Buena Park Elks lodge this Sunday the 23rd. I'm taking it anyway and don't sell parts from my home.
Randy
'66 GT350H-3 time cover car - Car Craft July'77,Modified Mustangs and Fords Feb2011 ( w/article), Mustang Monthly June 2014. Bracket raced by me for the last 44 years. Yes it is a real one.
'68.5 R code GT fastback
'67 Ranchero 408W -427 glass hood
'78 F350 "Oleynik" car hauler
Ford Experimental parts collector
GT350HR is offline
post #12 of 14 (permalink) Old 06-17-2019, 11:11 PM Thread Starter
JEFFinOC's Avatar
^ Thank you, Randy! PM Sent.
JEFFinOC is offline
post #13 of 14 (permalink) Old 06-17-2019, 11:30 PM
LeeFred's Avatar
And this is why I enjoy this forum so much...way to step up GT350HR and help a fellow member out.
LeeFred is offline
post #14 of 14 (permalink) Old 06-17-2019, 11:31 PM
supershifter2's Avatar
Thats way too much money for that. And the little clutch teeth look to have been ground some. $500.00 tops !
supershifter2ô < !
supershifter2 is offline
