autocross using an autolite 4100 carb - Vintage Mustang Forums
 7Likes
  • 1 Post By Jsams
  • 3 Post By Klutch
  • 2 Post By Lightning
  • 1 Post By paraman31
post #1 of 15 (permalink) Old 06-17-2019, 02:08 PM Thread Starter
hi, i'm wondering if anybody has done some autocrossing using a 4100 autolite carb? me and my son just got back from the rocky mountain mustang rally in steamboat springs over the weekend and he signed up for the autocross event. he loved the SoT coilovers but fell a little flat on the course! didnt know if it was fuel starvation or fuel was spilling over into the engine cutting out but figure i ask the folks out there that autocross. he really loves the autolite 4100 that was his first project rebuild going old school instead of going with a holley or edelbrock carb that we see at most shows. don't really want to go efi and since he doesn't autocross other than that show just wondering if any tips out there from veteran 4100 autolite users? sorry for the long post! thanks in advance for any info! robert
paraman31 is offline
post #2 of 15 (permalink) Old 06-17-2019, 02:25 PM
myfirstcar66's Avatar
I don't autocross but I do spirited driving now and then Haha! The 4100 is the only carb I've had that does NOT stumble coming out of hard turns. Took off my Edelbrock 1406 because I couldn't "tune" that out. With the 4100 there is no more -blah- it's all WHHAAAA....
My 1st car...
'66 Tahoe Turquoise/ Aqua coupe
•289 / 4100 •C4 Auto •Disc Brakes
•Dual Exhaust •Quick Manual Steering
•Rally Pac •Console •Deluxe Belts
•LOTS of Rotunda accessories
Older son's 1st car...
'66 Emberglo / Parchment deluxe coupe
•289 / 2100 •C4 Auto
•Dealer A/C • Console
•Dual Exhaust • Power Steering
Younger son's 1st car...
'66 Nightmist / Blue & white deluxe coupe
•Factory A/C •Console
WAITING FOR RESTORATION
myfirstcar66 is offline
post #3 of 15 (permalink) Old 06-17-2019, 04:24 PM Thread Starter
thx 66 for the reply! his car has great response thru canyon sweepers but during the course it stumbled coming out of a tight turn into the slalom so he was actually kinda shocked cuz he's got great throttle response all the time until he ran the course. haha!
post #4 of 15 (permalink) Old 06-17-2019, 05:24 PM
Maybe your float level is a little too high and its spitting gas out the vent tubes under heavy braking?
2nd 66 likes this.
Jsams is offline
post #5 of 15 (permalink) Old 06-17-2019, 07:57 PM
I drove my recently completed Mach 1 project to the Roundup and also participated in the autocross. I'm running a Summit Racing carburetor which is very similar to the 4100. On my 2nd and 3rd runs, my engine fell on its face right after the start. I think it's a vapor lock issue. Some friends of mine recommended revving the engine a little before the start and that really helped on my 4th run. In fact, I did a bit of a burnout at the start.
Consider Steamboat Springs is between 6,000 and 7,000 feet above sea level. That's a BIG factor for vapor lock issues. Combine that with ethanol in the fuel and it becomes an even bigger problem. There's a gas station on Lincoln Street in Steamboat which sells 100% gasoline. Although the premium is $3.70 a gallon, it would be worth it next time. (My friend who brought his 1970 Boss 429 reported his idle jumped up a full 250 RPM when he ran 100% gasoline.)
Fuel line routing is a critical factor for preventing vapor lock. I think that was my issue. I have an aluminum fuel filter and it's very close to the top of the engine. I'm going to try re-routing that to see if it helps.
Does the car have a phenolic spacer under the carb? If not, that might help. Also, as suggested, definitely check the float levels.
Anyway, I don't think the 4100 is the problem. That's a very good carb used by many a racer for many years.
2nd 66, myfirstcar66 and Grimbrand like this.
Currently working on a 1970 Mach 1 project. See it here: http://forums.vintage-mustang.com/vi...ode-build.html
Klutch is offline
post #6 of 15 (permalink) Old 06-17-2019, 08:27 PM Thread Starter
thx jsams, i was thinking the same thing so that's something worth looking into! hey klutch that's cool that you were also at the rmmr! that was an awesome show on yampa! getting back to the question , my son's 67 didn't have any problems with vapor lock driving up from utah since we are pretty close to the same elevation as colorado. the cruise went great even tho we got separated from our group when we stopped to help a fellow mustanger who did have vapor lock. his car runs really strong normally up until he started his autocross runs, haha!but he had a great time still so that's all that matters! i'm kinda leaning towards what jsams was saying and will look into that! appreciate al the info guys!! btw klutch my kid's car was the 67 coupe bullitt green with the green halo headlights driving around!
post #7 of 15 (permalink) Old 06-17-2019, 08:38 PM
Originally Posted by Klutch View Post
...Although the premium is $3.70 a gallon...
Just for a little perspective about the cost of premium gas. Regular unleaded with ethanol is currently $3.64.9 / gallon here on Oahu.
Not trying to hijack this thread. We now return you to the 4100 discussion.
Harry Z
HarryZ is offline
post #8 of 15 (permalink) Old 06-17-2019, 08:47 PM
I autox (not as of yet this year ,RAIN) with a 1406 with out that issue. I'd check float level . It helps to get some heat in the engine sometimes for better velocity and atomization .Then again I'm at about 400' above see level vs you in the mile high club.
Trying ethanol free will help with percolation along with a phenolic spacer
2nd 66 is offline
post #9 of 15 (permalink) Old 06-17-2019, 09:35 PM
Not sure if I saw that car. Mine was the Calypso Coral (orange) '70 Mach 1 with the hood tach. I ran in the PM1 autocross session. I was parked near 8th street with three other Mach 1s.
Klutch is offline
post #10 of 15 (permalink) Old 06-17-2019, 09:47 PM
I think a properly adjusted 4100 is a better carb than a holley or edelbrock of similar size.
65 coupe 5.0L/5 speed
2001 Lightning #1757
Lightning is offline
post #11 of 15 (permalink) Old 06-17-2019, 10:11 PM Thread Starter
i agree lightning! hey klutch my son also ran the pm session right before the ac cobra's and the rain! haha he was the first car running with the other 65-66 stangs. he was parked across of sunpie's bistro. awesome place btw!
post #12 of 15 (permalink) Old 06-17-2019, 10:40 PM Thread Starter
thx for the info 2nd66! we did put a spacer plate on his car. so far he's been lucky that he hasn't had any vapor lock ! runs great other than the autocross course. maybe the float is set high and it overflows when it's sloshing around
2nd 66 likes this.
post #13 of 15 (permalink) Old 06-17-2019, 10:53 PM
66ryan's Avatar
What material is the spacer plate?
66ryan is offline
post #14 of 15 (permalink) Old 06-17-2019, 11:02 PM
vapor lock and percolation aren't the same thing
Percolation happens in the carb when gas gets to hot
vapor lock happens in the line when the fuel gets to hot and the pump can't provide enough fuel
2nd 66 is offline
post #15 of 15 (permalink) Old 06-18-2019, 12:30 AM Thread Starter
hey 66ryan, we have the 1" 4 hole carb spacer plate with the vacuum port in back which i want to say is made out of cast along with a thin aluminum heat spacer plate. the fuel bowls are cool to the touch when running hard so i'm thinking the fuel isn't percolating in the bowls but i could be wrong. after my kid's autocross lap the car is fine once the car slows down at the end of the run,just has issues when doing the tight turns back and forth
