Tail Light Body Fit Issues - Vintage Mustang Forums
 3Likes
  • 1 Post By alex1965
  • 2 Post By NEFaurora
post #1 of 14 (permalink) Old 06-18-2019, 11:05 PM Thread Starter
alex1965's Avatar
Hello, today I was trying to get a few small things done on the car and I realized that the tail light bodies I ordered aren't exactly fitting well. I can insert the bolts into the top two holes, and then push the bottom in, but they strain the top bolts trying to get the body flush with the panel-- however, I CAN get all four bolts in. When I tighten the bolts, I'm getting virtually no compression on the white gasket. If I understand correctly, the white gasket goes between the body and the tail light panel, and the black gasket goes between the body and the lens.
1. Is that the correct gasket placement?
2. Has anybody else had problems fitting aftermarket tail light bodies? How did you remedy it?
3. Any tips or advice for this install?
I can't for the life of me get them to line up. I've thought about widening the holes with a rat tail file, but the car was just barely painted, and I figured I'd ask here on VMF before I went and did something I might regret.
I've attached a few photos, but I'm not sure they'll be helpful. You can see the level of gasket compression I'm getting in a few of them. Is it just a matter of cranking down on the nuts until everything lines up, or am I going to have to modify the car?
Any and all advice or information is welcome!
Thanks all,
Alex
289
4 speed
Rally-Pac
Bench Seat
Power Steering
All-around discs
Aftermarket A/C
And not nearly enough time
alex1965 is offline
post #2 of 14 (permalink) Old 06-19-2019, 12:22 AM Thread Starter
alex1965's Avatar
I've fiddled with it a bit more. It appears that the hole for the tail light body is too small-- the tail light body is fat and does not fit fully in the hole. Should I widen the hole on the freshly painted car with a file or try to file down the tail light body instead?
289
4 speed
Rally-Pac
Bench Seat
Power Steering
All-around discs
Aftermarket A/C
alex1965 is offline
post #3 of 14 (permalink) Old 06-19-2019, 08:02 AM
Did you replace the tail light panel? I say this because I don't remember that much of a gap in the top left corner. Do you have a OEM tail light housing you could try to see if your problem is the tail housing or the back panel.
Ford put a wedge with hole in it first then the nut. (Don't know what they are called it) This goes on then the nut, so the nut sits flat.
BW66 is offline
post #4 of 14 (permalink) Old 06-19-2019, 09:24 AM
awhtx's Avatar
Enlarge the hole as needed to get the housings to fit. Then touch up the paint. It will all be hidden from view when completed.
And as the other guy said- there are supposed to be wedges installed on the studs before the nut is installed. Look at a picture of the tail light installation kit on CJ or NPD website.
awhtx is offline
post #5 of 14 (permalink) Old 06-19-2019, 12:15 PM Thread Starter
alex1965's Avatar
The tail light panel was replaced, yes. I do not have easy access to an OEM taillight body to try.
The wedge is called a tail light spacer, right? I've read somewhere that they are not necessary if you are using newer bolts.
https://www.cjponyparts.com/scott-dr...1966/p/HW1429/
289
4 speed
Rally-Pac
Bench Seat
Power Steering
All-around discs
Aftermarket A/C
alex1965 is offline
post #6 of 14 (permalink) Old 06-19-2019, 12:16 PM Thread Starter
alex1965's Avatar
That's what I'm planning to do. I'll circle back around with an update. Thanks for the reply!
289
4 speed
Rally-Pac
Bench Seat
Power Steering
All-around discs
Aftermarket A/C
alex1965 is offline
post #7 of 14 (permalink) Old 06-19-2019, 09:06 PM
awhtx's Avatar
Yes, that's them and I have never heard that they are not needed under any circumstances.
awhtx is offline
post #8 of 14 (permalink) Old 06-21-2019, 02:37 PM Thread Starter
alex1965's Avatar
Update: I got them to fit. While the aftermarket taillight panel fit very well, the tail light body holes were slightly too small. I had to widen the flange/lip of the hole with a file and some gentle hammering before it would accept the taillight body.
Turnall likes this.
289
4 speed
Rally-Pac
Bench Seat
Power Steering
All-around discs
Aftermarket A/C
alex1965 is offline
post #9 of 14 (permalink) Old 06-21-2019, 04:26 PM
NEFaurora's Avatar
Chinese Offshore Replacement taillight Panel... That explains it...
At this point, I would dent the top and bottom of the taillight housing to fit.
It's better to fit the taillight housing to the panel... otherwise its cut..cut..cut to the taillight panel with a dremel..
A piece of wood and BFH (Big Freakin' Hammer) might would too before you try any cutting..
Tony K.
Tony Kovar
1965 Mustang Convertible 200cid I6, 3spd Manual (Soon to be swapped for a '65 Date Coded C4!)
MCA#70001
Getting Ready for the 2020 Melbourne, FL MCA Nationals!
NEFaurora is offline
post #10 of 14 (permalink) Old 06-21-2019, 06:41 PM
Under the nuts there are supposed to be little wedges so the nuts are parallel and pull tight. I also found the holes for the bezels were drilled wrong on the replacement housings. I had to weld them shut and redrill a couple.
Flade
68 289 convertible Candy-apple red & white
66 200 coupe Blue
94 GT convertible Red & black
98 GT convertible White & black
98 V6 convertible White & tan
Flade is online now
post #11 of 14 (permalink) Old 06-21-2019, 07:19 PM Thread Starter
alex1965's Avatar
No harm done, I got it all done. Had to do a bit of filing and touch up paint on the widened holes, but none of it is visible and all's well now.
289
4 speed
Rally-Pac
Bench Seat
Power Steering
All-around discs
Aftermarket A/C
alex1965 is offline
post #12 of 14 (permalink) Old 06-21-2019, 08:04 PM
NEFaurora's Avatar
I had used the Scott Drake "Concours" FoMoCo Stamped Tailights on my two verts... They worked out and fit perfectly... Of course both cars have their original taillight panels as well.. You can buy them thru NPD or Virginia Classic Mustang.
Tony K.
Tony Kovar
MCA#70001
post #13 of 14 (permalink) Old 06-21-2019, 08:12 PM
NEFaurora's Avatar
Just an FYI... The Top Taillight Nuts on both Taillight housings had Factory Spacers behind them to help the lights fit better to the panel...This was done the same at all 3 Mustang plants. The Bottoms just had the nuts.
Scott drake sells a kit of 8 Shaped Taillight Spacers....Only (4) will be used... Give the other 4 to a buddy or use them on your other '65-'66 car if you have one.. Don't use all 8 Spacers as the bottom housing nuts didn't get them.
See pic:
Tony K.
File Type: jpg OriginalFordRearGTJCali1966Mustang Pic 4.jpg (153.3 KB, 6 views)
Dan Babb and 66Ccode like this.
Tony Kovar
MCA#70001
post #14 of 14 (permalink) Old 06-21-2019, 10:34 PM Thread Starter
alex1965's Avatar
Mister Tony, thanks for the valuable information. I have ordered the spacers and I will utilize them on the top two (four total) nuts! Thanks for pitching in.
289
4 speed
Rally-Pac
Bench Seat
Power Steering
All-around discs
Aftermarket A/C
alex1965 is offline
