So...cowl repair. Need advice - Page 3 - Vintage Mustang Forums
 17Likes
post #31 of 46 (permalink) Old 07-07-2019, 11:17 AM Thread Starter
wicked93gs's Avatar
Ok, so I have the cowl out(upper and lower) Just wondering how people usually reinstall it? With the lower and upper as one piece, or lower first, then upper? I am concerned about getting the lip for the lower cowl and the lip for the windshield channel to line up correctly with the upper cowl
wicked93gs is online now
post #32 of 46 (permalink) Old 07-08-2019, 11:25 AM
xcelr8's Avatar
Mine was a two piece unit. I installed the lower first then the upper. You'll need LOTS of clamps and machine screws to hold the lower in place when welding and the same when putting the upper on.
If you take your time and clamp it properly along the windshield lip and firewall lip you'll be perfectly fine. Any extra material can be trimmed away and hammered into shape. Long repair but the most rewarding repair you'll do. Check my pics, I took many when I replaced mine.
Watch the progress on my 66 coupe here,
http://photobucket.com/projecttetanus
xcelr8 is offline
post #33 of 46 (permalink) Old 07-08-2019, 12:03 PM
latoracing's Avatar
I would definitely take the time to epoxy prime everything as you are going. From the firewall, under the cowl and the inside (top and bottom) since you are in there. I actually put a single stage urethane on the inside of my '70's cowl over the epoxy when I replaced it. There are several alignment holes in the cowl to assist you in getting it lined back up. I strongly suggest using an export brace to check the firewall positioning before welding the lower in place. Fit everything before committing to welding. If something needs to be adjusted, do it during the fit-up process. I remove the paint from each rosette weld hole with a small wire bush once everything is primed and sheet metal screwed in place. I've installed a couple of these, it really isn't that bad. Pay attention to the details and it will come out nice.
vegasloki and rdnck1 like this.
I have never "made" anything, I just modify the things around me into useful items with abilities that were GIVEN to me.
Mike
latoracing is online now
post #34 of 46 (permalink) Old 07-08-2019, 12:18 PM Thread Starter
wicked93gs's Avatar
So...just for general amusement...the firewall flange where the alignment holes were was rotted away:
So I had to cut and patch it. I am pretty sure I got the new alignment holes positioned correctly(at least within 1/32nd of an inch) and drilled to the correct size(although in this picture I ran out of welding wire before I finished the weld). I agree though that this isnt that bad of a job...the floorpans were far worse as far as work involved(maybe because I installed torque boxes at the same time)
post #35 of 46 (permalink) Old 07-12-2019, 07:51 PM Thread Starter
wicked93gs's Avatar
Lower prepped and ready to go back in. Any last minute checklist I need to do before starting to weld(tomorrow). I dont have an export brace for alignment...just the factory shock tower braces.
Rowdy likes this.
post #36 of 46 (permalink) Old 07-12-2019, 10:26 PM
Looks great!
66kcar is offline
post #37 of 46 (permalink) Old 07-13-2019, 05:30 PM
xcelr8's Avatar
Do you have any holes punched to weld at the lower windshield lip?
Turnall and rdnck1 like this.
xcelr8 is offline
post #38 of 46 (permalink) Old 07-14-2019, 06:37 PM Thread Starter
wicked93gs's Avatar
I didnt have any pre-drilled in the lower cowl at the lip area...but it only sits on about 2 inches of lip on either side for the lower cowl(I do need a drill a couple on each side to secure it there)...the vast majority of that lip wont get any holes in the lower cowl...all the holes will be in the upper cowl where it welds to the lower cowl lip
lower cowl installed aside from those couple holes on the top lip in the corners
post #39 of 46 (permalink) Old 07-23-2019, 03:14 PM Thread Starter
wicked93gs's Avatar
Thanks for all the help and advice guys, its going back together...should be done by the end of the day with this rather intimidating task:
One last question though: Anyone have any tips for applying seam sealer to the front triple-lip of this area to most effectively seal it?
post #40 of 46 (permalink) Old 07-24-2019, 04:23 PM
coupster's Avatar
Weld in the export brace bracket on the firewall while you are there....probably too late...
65 FB 289/3sp Rangoon Red/Red interior
68 Coupe 200/6 T-5 Diamond Blue/Blue interior
68 Coupe 302/C4 Black interior
69 Coupe 250/6 C4, Blue/Black interior
70 Coupe 390/C6 Auto Gold Metallic/Ginger interior
2010 Gold V6/Auto Sunset Gold/Black interior
65 Falcon Vintage Burgundy/Palomino interior
coupster is offline
post #41 of 46 (permalink) Old 07-24-2019, 04:43 PM Thread Starter
wicked93gs's Avatar
I am not actually 100% finished with the area yet...upper is welded down, but before seam sealer goes on the front lip I will be adding 1x1(or 1x1.5, whichever works better for export bracing) tubing under the cowl lip that will connect to the A-pillar area and down to the torque boxes, as well as forward to the outer shock towers, so whatever export brace I end up using will have a very solid connection point...it is actually the next(last) thing I have to do before I can turn my attention back to the interior....just have to pick up some square/rectangular tubing to get started on that project.
coupster likes this.
post #42 of 46 (permalink) Old 07-24-2019, 07:04 PM Thread Starter
wicked93gs's Avatar
Done...at least until I tackle the bracing...but going to do some other things first.....decided just now I am going to re-direct my attention to the interior first and come back to metalwork a little later.
post #43 of 46 (permalink) Old 07-25-2019, 09:13 AM
xcelr8's Avatar
Looks great! Long but satisfying repair when done.
I just went around the entire lip of the new cowl, left side to right, with a thin coat of sealer on mine. There's also the long seam that runs drivers to pass side behind the dash inside the car you'll want to seal up. Use seam sealer in a caulk gun there.
vegasloki likes this.
xcelr8 is offline
post #44 of 46 (permalink) Old 07-25-2019, 09:51 AM Thread Starter
wicked93gs's Avatar
Yeah, plan on seam sealing all that...but cant do it yet with the bracing I plan on running under the cowl lip, I still have more welding to do first, and for some odd reason seam sealer tends to catch fire when you weld close to it.
I am not familiar with the one inside though unless you mean up under the windshield lip...which is probably going to be a real pain to get to.
post #45 of 46 (permalink) Old 07-25-2019, 10:31 AM
xcelr8's Avatar
Yeah, last step would be shooting some primer and sealing.
The interior lip I'm speaking of runs the stretch under the lower cowl pan inside the car where these arrows are. PITA, but reachable if you have the sealer in a tube/caulk gun.
xcelr8 is offline
