5-speed bellhousing options? - Vintage Mustang Forums
 3Likes
  • 2 Post By Woodchuck
  • 1 Post By 68Hildago
post #1 of 12 (permalink) Old 06-26-2019, 02:26 PM Thread Starter
My ‘65 has a T5 behind a late model 5.0. It has an aftermarket, scatter-shield type belhousing, which uses the Z-bar clutch mechanism.
I don’t really like the bellhousing for several reasons, so I was considering swapping to a Foxbody type of bellhousing, and a hydraulic clutch.
However, I recently looked at a ‘66 that was running a T5 with why appears to be a factory, Ford bellhousing, and the Z-bar clutch. So, now I have several questions:
1. What is this bellhousing? Is it a factory 4-speed bellhousing?
2. How hard are these bellhousinga to find, and what throwout bearing would this set-up use?
3. Could this set-up retain the 157-tooth, 50 oz-in bellhousing that would have originally behind my 5.0 engine?
File Type: jpg 62CEA76B-691D-4821-B054-C23688F73026.jpg (274.8 KB, 6 views)
File Type: jpg C40983D3-37E3-44A4-966B-E3C42BACF66B.jpg (211.1 KB, 6 views)
File Type: jpg 0B6C35A7-A4B9-4044-AAB6-3CC91834DB31.jpg (220.5 KB, 5 views)
Benny is offline
post #2 of 12 (permalink) Old 06-26-2019, 02:35 PM
Woodchuck's Avatar
Yes, you can run a T-5 with a factory period bellhousing and an adapter plate between the bellhousing and the transmission. It's a simple as that...with the T-5 crossmember, of course. The aluminum bellhousings are a dime-a-dozen since they were put behind just about ANY V8 with a manual (3 or 4 speed) transmission with a wide-pattern transmission from '65 on.
Huskinhano and 2nd 66 like this.
Bart
What, me worry?
- Alfred E. Neuman
Woodchuck is offline
post #3 of 12 (permalink) Old 06-26-2019, 03:31 PM Thread Starter
I’m not seeing an adapter plate in the pics I attached. It looks like the trans is bolted up straight to the bellhousing, like it would be with a Foxbody bellhousing.
Benny is offline
post #4 of 12 (permalink) Old 06-26-2019, 03:43 PM
68Hildago's Avatar
That is a foxbody bell housing using a fulcrum adapter to utilize the factory clutch fork and zbar setup.
Woodchuck likes this.
68Hildago is online now
post #5 of 12 (permalink) Old 06-26-2019, 03:52 PM Thread Starter
Ahh, thank you
I thought it looked like a Foxbody bellhousing, but having the fulcrum on the other side was blowing my mind.
Are those adapters still available? Are there any known issues with them, or are they reliable?
Which TO bearing gets used with that set-up?
Benny is offline
post #6 of 12 (permalink) Old 06-26-2019, 03:54 PM
68Hildago's Avatar
It is just a 1x1x2 block placed 1" from the opening edge. I used my 3 speed bell housing fulcrum and made my own spacer. Easy.
This way you can use your existing Clutch fork and release bearing along with your factory zbar setup.
I ended up removing all that and went with a hyd clutch setup last summer.
post #7 of 12 (permalink) Old 06-26-2019, 04:02 PM Thread Starter
Can I ask why? Just to remove the “clutter” of the Z-bar, or were you not happy with how it worked?
Benny is offline
post #8 of 12 (permalink) Old 06-26-2019, 04:31 PM
68Hildago's Avatar
Partly because I could. My twin brother installed a Hyd clutch the year before and was impressed with the feel and lighter pedal (he used to run a cable clutch). Both of us built our own and did not buy a kit. We get a full 1.5" throw (factory T5 is approx 1.4") which a lot of the off-the-shelf hyd clutch kits do not get.
I had already reinforced my zbar due to it bending (on its maiden voyage none the less) and had it working pretty good. I did have a constant squeak due to the assist spring that I couldn't resolve. I also installed the Mustang Steve's bearing kit on my worn out pedal assembly which greatly increased the smoothness. Since I was contemplating which headers at the time, I figured what the heck, lets do it.
It really does work great and would put it above the zbar setup.
Here is a thread covering some of the hyd clutch install.
https://forums.vintage-mustang.com/m...ml#post9504825
post #9 of 12 (permalink) Old 06-26-2019, 05:53 PM Thread Starter
Great thread. I’m an engineer too, so I enjoyed reading through it.
Tell me something....with your 1.5” of throw, and you running an “air gap” between your TO bearing, and pressure plate, or are you running them in contact?
I have another car with a T5 and a hydraulic clutch, and with a 7/8” bore on both the slave and master, I can not get the clutch to disengage with an air gap. A lot of people have told me to run the TO preloaded against the pressure plate, but it just doesn’t seem right to me.
Benny is offline
post #10 of 12 (permalink) Old 06-26-2019, 06:06 PM
FWIW , I used the 3/4 speed bell with my T-5 swap and the CPC adapter plate
at 1st it was behind a 289 now the same set up with the addition of a CPC Zbar pivot adapter is behind a GT40P
not endorsing CJPP but they have nice pics
https://www.ebay.com/i/123805754191?chn=ps
https://www.cjponyparts.com/equalize...5-0l/p/CEBBE4/
2nd 66 is offline
post #11 of 12 (permalink) Old 06-26-2019, 06:12 PM
68Hildago's Avatar
T5 release bearings are designed to have pre-load and that's what I have setup.
post #12 of 12 (permalink) Old 06-26-2019, 06:24 PM Thread Starter
Ok, thank you again.
Benny is offline
