289 Valvetrain Help - Vintage Mustang Forums
post #1 of 26 (permalink) Old 06-28-2019, 12:22 AM Thread Starter
alex1965's Avatar
289 Valvetrain Help
Hello all,
Got everything up to the pushrods installed today on the 289, not bad for a day's work. I decided to call it a day because I wasn't sure what I was supposed to do next.
Can somebody give me an idiot-proof rundown of how to install rocker arms and adjust valve lash? Or tell me what needs to be done? The book I am following does not make much sense to me and I would love to hear from others about what needs to happen.
Thanks!
Alex
289
4 speed
Rally-Pac
Bench Seat
Power Steering
All-around discs
Aftermarket A/C
And not nearly enough time
alex1965 is offline
post #2 of 26 (permalink) Old 06-28-2019, 12:28 AM Thread Starter
alex1965's Avatar
I have hydraulic lifters (all new) along with new pushrods, if that's necessary information.
289
4 speed
Rally-Pac
Bench Seat
Power Steering
All-around discs
Aftermarket A/C
alex1965 is offline
post #3 of 26 (permalink) Old 06-28-2019, 01:03 AM
DaleB's Avatar
What book do you have? I have the Monroe book. The procedure there is almost identical to one I saw on YouTube a few weeks ago. Basically, you get a cylinder at TDC on the compression stroke so you know both valves are fully closed and both lifters are on the cam base. Turn the adjusting nut for one rocker arm until you just take up all the slack movement in the pushrod, then tighten 3/4 turn more.
#1 at TDC on the compression stroke - Adjust #1, #7, and #8 intake and #1, #5, and #4 exhaust
Rotate the crank 180 degrees (1/2 turn) and adjust #4 and #5 intake, #2 and #6 exhaust
Rotate the crank 270 degrees (3/4 turn) and adjust #2, #3, and #6 intake and #7, #3, and #8 exhaust
I've never done it either, but it's pretty simple and the procedure makes sense.
The video said NOT to fill the lifters with oil. The Monroe book (which I have heard is good) says to prime them with oil. I'm not entirely sure it will make a difference... I haven't gotten far enough along to fully understand the way the lifters work internally, but it would seem that after a few seconds the oil in the lifter would be forced into the pushrod.
DaleB is offline
post #4 of 26 (permalink) Old 06-28-2019, 01:28 AM
kenash's Avatar
I, for one, have never "not" primed the lifters. Not sure the why "video" author stated "Not" to fill?
If using the adjustment process mentioned, It's very helpful to first, carefully, chalk mark the pulley every 90º. There are other methods that don't require this. One I've used, has you follow the firing order, starting with #1, then progressing through the F/O.
Which ever is easier to follow will be fine. But, the key is insuring the valve(s) is fully closed during the firing stroke in each case.
BTW, are you assembling a stock engine, that is stock heads, cam etc?
Ken ..
64 1/2 Poppy Red Cvt. Resto-Mod
333 Cu.in. T5z, 3:55, Dual 40 mm DCOE Webers
Performer RPM, CI cam, TFS/TWs, Tri-Ys, Discs w/Shelby Drums
Maryland
kenash is offline
post #5 of 26 (permalink) Old 06-28-2019, 01:50 AM
Tallguy's Avatar
I just did this today on my motor. Everything said so far is correct. I chose to do each valve pair in the firing order rotating the crank 90 degrees each time. I put a piece of 1" masking tape around the balancer and cut it to fit just right. Then removed it and measured out 90 degree marks and reinstalled the tape. This way it was fast and easy to rotate to the right place. When you take up push rod slack make sure move it up and down until all slack is gone. Then go 1/2-3/4 turn more after that.
One thing to consider is if you have guide plates, now is the time to adjust/center them. My new heads from Edlebrock looked like a 3 year old aligned the plates. I re-aligned all of them (bring cyl to TDC loosen studs X2, install push rods, install rocker without nut, adjust plate to get best centering and torque it to 45 Ft.Lbs or whatever spec if for your heads). Then rockers go on and pre-load set. Easy and quite a rewarding step to complete!
66 Convertible. Full restoration in the works
Tallguy is offline
post #6 of 26 (permalink) Old 06-28-2019, 07:23 AM
22GT's Avatar
Adjust hydraulic valves with the engine cold.
Do this, and it will run smoothly, and likely with more power:
Disconnect the coil + wire.
Attach a bump switch to the solenoid, or just use a screwdriver.
Turn the engine so the #1 intake valve is fully opened. Loosen the exhaust valve until you can move the #1 exhaust valve pushrod up and down (NOT spinning).
Tighten this valve until no up and down movement can be felt, then tighten an additional 3/4 turn.
Note: Spinning the pushrod can cause a false adjustment, as a slowly collapsing lifter can allow the pushrod to spin freely, thus throwing off the base line of your adjustment.
Turn the engine so the #1 exhaust valve is fully opened. Loosen the intake valve until you can move the #1 intake valve pushrod up and down (again, NOT spinning).
Repeat for the other 7 cylinders.
I did this on a friend’s engine that had been adjusted when built, then driven for several years. It was running OK, but not great, you could hear some valve noise. After doing the above, it did not seem to be much better immediately after adjustment, mostly because the lifters had been varnished into position by years of driving. Coupla miles around the block, though, and it was a whole 'nother engine.
Adjusting mechanical valves.
I drove a 289HP daily for 20 years, and every 6000 miles I adjusted the valves, which took less than an hour.
Adjusted properly, they aren't noisy, either, just a high-pitched singing sound.
Factory spec for the 289HP C3OZ-6250-C cam is .022" cold, .018" hot.
The procedure in the Manual is a bit complicated, and involves marking the balancer at 90° points, and then you follow some weird pattern, like I1, E4, I6, E2, or some complex crap. Takes an hour just to figure out what they want you to do.
Do this instead-
Run the engine until it is a full operating temperature. Disconnect the coil + wire.
Bump the starter until the second valve on the #1 cylinder is all the way open. This means the one closest to the radiator is closed, on the base circle of the cam lobe. Adjust the valve to .018".
Bump the starter until that valve is fully open, and adjust the second valve.
Continue to adjust the valves in pairs until the RH head is adjusted, and install the valve cover.
Repeat the process on the LH side of the engine. I like to start and run the engine to be sure it is still fully warmed up.
Remove the LH valve cover, and adjust the LH valves to .018".
Very quick, and very accurate.
If the engine has just been assembled, do the procedure cold, at .022”. Then warm up the engine and do it hot.
Amateur restorer. Well, sometimes I have been paid for it. But not right now.
22GT is online now
post #7 of 26 (permalink) Old 06-28-2019, 08:23 AM
malarson's Avatar
I use this procedure from the Tom Monroe book and It works perfectly every time. You only have to turn the engine twice, much easier!
69 Mach 1, 351W, T5, owned for 31 years, 03 Mach 1 Azure Blue, 65 fastback, 289, C4 (son's), 67 fastback, 289, C4 (wife's)
malarson is online now
post #8 of 26 (permalink) Old 06-28-2019, 08:39 AM
22GT's Avatar
Getting the exact 90° turn on the engine makes my head hurt. The procedure I posted can be done in less than an hour.
22GT is online now
post #9 of 26 (permalink) Old 06-28-2019, 08:49 AM
malarson's Avatar
Pretty simple really, put a socket wrench on parallel to the ground, turn it til its perpendicular. Everyone has their way, I find this the easiest.
And also, how do you do your procedure with the engine on a stand? I get you can turn it by hand, but why do that 16 times?
post #10 of 26 (permalink) Old 06-28-2019, 09:35 AM
DaleB's Avatar
Socket and a ratchet or breaker bar on the balancer bolt lets you easily turn it 90, 180, 270 with no problem at all. In the car or out. It's easier with the plugs out, of course. On the other engine I regularly work on, you just turn the prop.
DaleB is offline
post #11 of 26 (permalink) Old 06-28-2019, 12:16 PM
Tallguy's Avatar
On a new motor build while on an engine stand with no spark plugs it is so easy to rotate the crank 90 degrees at a time and get two valves per turn in firing order. If the motor was in the car all built up I think I like 22GTs way.
Tallguy is offline
post #12 of 26 (permalink) Old 06-28-2019, 12:51 PM Thread Starter
alex1965's Avatar
Well, oops. I primed the lifters with oil with a squirt gun (as directed by Tom Monroe-- I do have his book) before I installed them. Perhaps I was just tired yesterday; I'm looking at his instructions now and they don't seem so bad. Thanks for pitching in.
I did end up priming the lifters-- see above. Thanks for the advice on marking the pulley with chalk.
I am building a mild performance 289 for my driver. It's on the performance end of street, but not track. Cam card below:
289
4 speed
Rally-Pac
Bench Seat
Power Steering
All-around discs
Aftermarket A/C
alex1965 is offline
post #13 of 26 (permalink) Old 06-28-2019, 12:53 PM Thread Starter
alex1965's Avatar
Thanks, this is helpful. I will probably end up using your masking tape method to ensure I get proper 90* turns!
Do this instead-
Thanks. I think I saw this somewhere doing some research last night Very detailed instructions, thank you for posting.
289
4 speed
Rally-Pac
Bench Seat
Power Steering
All-around discs
Aftermarket A/C
alex1965 is offline
post #14 of 26 (permalink) Old 06-28-2019, 12:54 PM Thread Starter
alex1965's Avatar
Yeah, I think I'm going to do the 90 degree rotation method. Just seems to be more simple to me and it's what the book talks about.
289
4 speed
Rally-Pac
Bench Seat
Power Steering
All-around discs
Aftermarket A/C
alex1965 is offline
post #15 of 26 (permalink) Old 06-28-2019, 02:00 PM
kenash's Avatar
You using OEM type heads with your cam change? Are you aware of push rod geometry and the importance of adjusting for it, if it applies in your case? Not suggesting that it does, 'cause except for your cam change, we don't know the other details of your build.
Ken ..
Maryland
kenash is offline
