Engine RUINED? - Vintage Mustang Forums
 24Likes
post #1 of 47 (permalink) Old 06-29-2019, 12:11 PM Thread Starter
alex1965's Avatar
Engine RUINED?
Sorry for the dramatic title. I need views on this, as it's very important.
I've been in the process of rebuilding my engine. Some of you may have seen my "Valvetrain Help" thread. ( https://forums.vintage-mustang.com/v...rain-help.html ). I mentioned that my machinist had put Chevy valves into my heads, and everybody quickly said this was bad.
My machinist has been in business for 40+ years and has a great reputation. He was kind enough to let me rebuild the bottom end with him, because we wanted it done properly but I also wanted to be there. He is extremely knowledgeable and competent, and has forgotten more about engines than I'll probably ever know.
I have attached my build sheet/invoice for the machine shop and I would GREATLY appreciate if you could tell me what's wrong with the combination of parts I'm running. I don't want to ruin my engine. I trust my machinist, and he said that he has used this build for many small block Fords and they turned out great.
Thanks in advance...
289
4 speed
Rally-Pac
Bench Seat
Power Steering
All-around discs
Aftermarket A/C
And not nearly enough time
alex1965 is offline
post #2 of 47 (permalink) Old 06-29-2019, 12:13 PM Thread Starter
alex1965's Avatar
Should also mention: I got a new cam, lifters, and pushrods as well. I assume they're tailored to match the build. He put new studs in the head for adjusting the valvetrain. I reused the rocker arms and nuts.
289
4 speed
Rally-Pac
Bench Seat
Power Steering
All-around discs
Aftermarket A/C
alex1965 is offline
post #3 of 47 (permalink) Old 06-29-2019, 12:17 PM Thread Starter
alex1965's Avatar
https://forums.vintage-mustang.com/v...ord-heads.html
This thread is exactly my situation: 1.84 and 1.5 valves in my 289 heads. Useful reading there. And my other research doesn't seem to indicate that this would be a problem?
289
4 speed
Rally-Pac
Bench Seat
Power Steering
All-around discs
Aftermarket A/C
alex1965 is offline
post #4 of 47 (permalink) Old 06-29-2019, 12:32 PM
If you truly trust your machinist, why are you shopping for opinions now? It seems that your due diligence about your machinist and the scope of your build should have been completed before you hired him to build your engine. Am I missing something here? (I did not read the earlier thread).
Israel likes this.
url]http://i87.photobucket.com/albums/k156/jefftepper/IMG_0027_edited-1.jpg[/url]
*Principal wrench on this 69 Mach I*
JeffTepper is offline
post #5 of 47 (permalink) Old 06-29-2019, 12:36 PM Thread Starter
alex1965's Avatar
I do trust my machinist, and had no intentions of changing what he had put together. I did some quick research about the parts he had suggested and saw no issues or problems. However, three people all seemed to agree that Chevy valves in a Ford head could be problematic. I wanted to get more opinions before I fire it up and potentially ruin my engine... and I don't think that's a bad thing.
289
4 speed
Rally-Pac
Bench Seat
Power Steering
All-around discs
Aftermarket A/C
alex1965 is offline
post #6 of 47 (permalink) Old 06-29-2019, 12:50 PM
DaleB's Avatar
As long as two of those people are not you and your machinist, build on. Everyone has an opinion. Only YOU have the engine.
DaleB is offline
post #7 of 47 (permalink) Old 06-29-2019, 12:55 PM Thread Starter
alex1965's Avatar
I'm well aware of this and agree completely. However, to completely ignore input saying that the combination of parts I have could cause problems in my engine would be foolish and potentially very expensive. I'm not looking for advice on a new build, I'm looking to verify that what I have won't be a problem.
289
4 speed
Rally-Pac
Bench Seat
Power Steering
All-around discs
Aftermarket A/C
alex1965 is offline
post #8 of 47 (permalink) Old 06-29-2019, 12:57 PM
dobrostang's Avatar
If you are truly worried about the Chevy Valves, then before you bolt the heads down use clay or silly puddy to convince yourself that there is enough clearance between the pistons and valves. Turn the engine over slowly with the heads bolted down and stop if you feel interference. THat is the only thing I can think of that would toast the motor instantly.
Heavy Metal Thunder Video http://www.youtube.com/watch?v=cW3L_O7N_xs
dobrostang is offline
post #9 of 47 (permalink) Old 06-29-2019, 01:02 PM
Turnall's Avatar
Alex, I clarified on your valve train thread. My comment was pure sarcasm...
Allen
Turnall is offline
post #10 of 47 (permalink) Old 06-29-2019, 01:05 PM
Kelly_H's Avatar
Ok, well, the other day someone on VMF (the facebook group version) told me that control arms should not be greased because grease degrades rubber bushings.
The point is that I would trust someone who has 40 years of experience who you know knows what they're doing, over some rando on the internet with unknown background. Most people here on the forum are very sharp. But there are always a number of people who speak with authority but have no data to back it up.
Calamity Jane 1966 Modified Fastback - Driven semi-daily!
Wrecked and rebuilt even better
289 v8, 4-speed, 3.25 9" rear, goodies and stuff.
See my travel blog here for my adventures: http://mapandamustang.blogspot.com/
Over 50,000 miles of North American roads driven on road trips since 2014. More always in the works - stay tuned!
When I show up at a car show and my car is covered in mud, it's probably because I drove 2000 miles to get there
Kelly_H is offline
post #11 of 47 (permalink) Old 06-29-2019, 01:06 PM Thread Starter
alex1965's Avatar
I already have the heads and intake bolted on. I can turn the engine over, and I don't feel anything contacting... but it is a little difficult now that there's a little bit of compression.
Allen
Okay, thank goodness. That's what I was hoping. Hard to tell tone over the internet!
289
4 speed
Rally-Pac
Bench Seat
Power Steering
All-around discs
Aftermarket A/C
alex1965 is offline
post #12 of 47 (permalink) Old 06-29-2019, 01:08 PM
bbmach's Avatar
No need for drama. :-) Itís can be a bit of a challenge if the person assembling is different than the person machining. Thatís why you should be checking everything. The first time is fun. The second? Not so much.
Inherently parts is parts. If the machine shop did his job, the valve seats in the heads have been modified to fit the Chevy valve sizes. No biggie. As mentioned, no real reason to do it these days, as there are a lot of other options, but whatever as the kids say. Chalk it up to old-school thinking.
Also, as mentioned, youíll need to pay close attention to the rocker arm geometry and push rod length during the mock up part of the build. But you should be doing that anyway.
If the shop has done this in the past, they should give you an idea of which pushrods youíll need. But, you still have to check.
Get back to work! :-)
kenash likes this.
1969 Mach-1 Mustang
460 / C6 / 9"
Back in Dixie DSO 22 (Charlotte)
bbmach is offline
post #13 of 47 (permalink) Old 06-29-2019, 01:12 PM Thread Starter
alex1965's Avatar
I'm aware that the internet gives a voice to those who might not necessarily deserve one, but I was just a little concerned because the people who thought it was problematic were knowledgable and long-time members.
What exactly should I be looking for regarding rocker arm geometry and pushrod length? I am definitely trying to avoid a second time around
289
4 speed
Rally-Pac
Bench Seat
Power Steering
All-around discs
Aftermarket A/C
alex1965 is offline
post #14 of 47 (permalink) Old 06-29-2019, 01:14 PM
DaleB's Avatar
Why would you take the opinion of SGOTI over your machinist who's done this before? I'd listen to someone who could tell me, "Hey, I did this same thing, and here's the problem I encountered". But the guy who just says, "Oh, no, that won't work" without anything to back it up... not so much.
It's interesting, though, that the topic came up. I was just reading -- literally yesterday afternoon -- an article on Ford smallblock heads. The author says that using larger Chevy valves was a common practice. According to the article, the only potential issue was that cutting the seat larger would get you out of the induction hardened area of the head, leaving non-hardened cast iron. Not a problem (according to him) for a street engine. Ah, here's the link: Modifying Small Block Ford Cylinder Heads
Now, is this guy more credible than someone else? I have no idea, but a quick Google search will bring up quite a number of references detailing pretty much the exact same thing.
DaleB is offline
post #15 of 47 (permalink) Old 06-29-2019, 01:18 PM
bbmach's Avatar
Comp Cams has a good, short video on pushrod length and geometry. Helps if you pull the spark plugs when rotating the engine.
kenash and Rebel Racing like this.
1969 Mach-1 Mustang
460 / C6 / 9"
bbmach is offline
