1965 power steering pump leaking. How to stop? - Vintage Mustang Forums
 1Likes
  • 1 Post By watto1
post #1 of 6 (permalink) Old 06-30-2019, 02:19 PM Thread Starter
My 65 power steering pump is leaking. It all began when I moved the bracket holding the back of the pump out of the way to get to the oil sending unit at the base of the engine. At first I thought it was the return line or nipple may have cracked. But its farther up. It looks to be where the bolt comes out that holds the bracket. It leaks pretty good to. I first thought it was oil but now I found its leaking through the bolt hole.
Any ideas of what I can do?,
Dean
Got my hands on the wheel, foot to the pedal, gonna drive this car till the tires turn to metal - gonna sleep when I'm dead and laugh at the devil..
69RR is offline
post #2 of 6 (permalink) Old 06-30-2019, 02:42 PM Thread Starter
Ok I think i found the issue. There is a thin nut in between the canister and the bracket. I thought it was welded in. When I took the bracket off I found it was really loose - I tightened and waiting to see if it leaks. Easy fix if that's all there is.
69RR is offline
post #3 of 6 (permalink) Old 06-30-2019, 02:58 PM
Josep's Avatar
I also has a leak in my Convertible PS. It was the seat inside the hose. We replaced that seat (they’re cheap!) and we solved the issue. I’m happy you have fix that leak.
Josep
https://mymustangintexas.wordpress.com
1966 Mustang Hardtop 200 Inline 6 - Arcadian Blue - AT Thermactor - 6R07T213966 - San Jose projected build date June 11th 1966 - DSO 71
1966 Mustang Convertible 289-2V - Vintage Burgundy - AT PS PT DB - 6F08C109403 - Dearborn projected build date September 9th 1965 - DSO 36
Email me at [email protected]
Josep is offline
post #4 of 6 (permalink) Old 06-30-2019, 06:31 PM Thread Starter
Originally Posted by Josep View Post
I also has a leak in my Convertible PS. It was the seat inside the hose. We replaced that seat (theyíre cheap!) and we solved the issue. Iím happy you have fix that leak.
Josep
Thanks Josep!
69RR is offline
post #5 of 6 (permalink) Old 07-01-2019, 04:46 AM
watto1's Avatar
You probably have it sorted, the thin nut seals the pressure outlet of the pump by pressing on an internal fibre washer, guaranteed to leak if it's louse..
Good work!
Sent from my SM-G950F using Tapatalk
69RR likes this.
watto1 is offline
post #6 of 6 (permalink) Old 07-01-2019, 07:00 AM
watto1's Avatar
[quote=watto1;10190304]You probably have it sorted, the thin nut seals the pressure outlet of the pump by pressing on an internal fibre washer, guaranteed to leak if it's loose..
Good work!
watto1 is offline
