JBA Shorty Problem? - Vintage Mustang Forums
 7Likes
post #1 of 34 (permalink) Old 07-03-2019, 12:16 AM Thread Starter
alex1965's Avatar
JBA Shorty Problem?
Hey all, hoping to hear from anybody who has the JBA shorties on a 289 or 302 sort motor. Realized today that I have a very simple problem: replacing spark plugs. The number 7 spark plug seems impossible to replace without taking off the headers on the driver side, which is obviously something I don't want to do every time I change spark plugs. The number 8 cylinder is also very difficult but I could manage it with one of those jointed socket thingies.
Is there a tool that I should be using that I don't know about? I'm really confused here.
See pics! Thanks in advance.
289
4 speed
Rally-Pac
Bench Seat
Power Steering
All-around discs
Aftermarket A/C
And not nearly enough time
alex1965 is online now
post #2 of 34 (permalink) Old 07-03-2019, 05:11 AM
I have JBA shorty headers on my 302 and one spark plug on the drivers side is difficult to access as you say. I was determined not to have to remove the header just to remove a spark plug.
I was able to slide my spark plug socket over the spark plug, but there was no room to plug a ratchet or anything else into it.
I ended up drilling a hole through the end of the socket, and using a metal rod slid into the hole, I could tighten the spark plug. I would hand tighten it as much as possible first and then give it a bit more using the metal rod. As spark plugs do not have to be done up very tight, I found the metal rod worked fine. I drilled holes through the socket in several places, so there was always a hole visible at any rotation of the spark plug.
Alternatively, if your spark plug socket has a hex end on it, then you might be able to get a ring spanner ( sorry wrench ) on the end once it is slid over the spark plug.
Jeremy.
JRFox is offline
post #3 of 34 (permalink) Old 07-03-2019, 06:18 AM
watto1's Avatar
Interesting.. have you tried to fit a plug lead yet? Looks tight for space indeed..I've heard of people needing a shorter plug..
Sent from my SM-G950F using Tapatalk
watto1 is offline
post #4 of 34 (permalink) Old 07-03-2019, 06:35 AM
The plug lead goes on fine and clears the header. I use silicone leads with silicone ends and they have been fine. I am just using regular spark plugs.
JRFox is offline
post #5 of 34 (permalink) Old 07-03-2019, 06:50 AM
You could try one of the spark plug sockets that have hex flats on the drive end, and use a ratcheting box wrench on that.
'65 A-code coupe, T-10 4-speed, 8" 3.25 limited slip
stephen_wilson is offline
post #6 of 34 (permalink) Old 07-03-2019, 07:49 AM
I ran into the same problem on my JBA 1650 headers. I solved the problem by modifying a spark plug socket. I cut the length and ground the square ratchet drive hole until round (to clear the insulator). I also cut an old box end wrench to enable a slightly longer throw in a couple of tight areas. You can buy a similar tool off of the Snap-on truck if you want to spend the big bucks ($37.25)!
dobrostang, TheRktmn and rusty1161 like this.
'66 GT Fastback, 302, Edelbrock Top End, Sniper EFI/Aeromotive, MSD, JBA Headers & 2.5" Exhaust, T5Z, Currie 3.55 Trac-Loc
rhutt is online now
post #7 of 34 (permalink) Old 07-03-2019, 08:50 AM
I do it with a wrench similar to rhutt. One of my spark plug suckets in the tool box could be used without modification. Believe it's a 3/8" sucket. But the actual placement of the plugs may also vary a little between different brands of heads. I use 45 degree boots and ignition wires runs over the center of the valve covers like stock. Works perfect with the JBAs.
Westmus is offline
post #8 of 34 (permalink) Old 07-03-2019, 09:57 AM
dm289's Avatar
I hate to hijack this post.. I too have a set of JBA 1650 headers I plan to use on my 66 Coupe; what style spark plug wire ends are you guys using?
Straight?
135 degree?
90 degree?
Thanks, dm289
dm289 is offline
post #9 of 34 (permalink) Old 07-03-2019, 10:11 AM
Summit sells an SLP Performance socket for $23.95.
I use 90* MSD boots with no interference issues.
rhutt is online now
post #10 of 34 (permalink) Old 07-03-2019, 10:37 AM
dobrostang's Avatar
I use a hex socket like others, further, I keep a 6-8" length of tubing that fits snugly over the porcelain on the plug and use that to spin the plugs to start the threads and thread it as far as as you can.
rhutt likes this.
Heavy Metal Thunder Video http://www.youtube.com/watch?v=cW3L_O7N_xs
dobrostang is offline
post #11 of 34 (permalink) Old 07-03-2019, 11:52 AM Thread Starter
alex1965's Avatar
Jeremy.
Okay, this is what I suspected. People modify sockets and access it from the bottom or top with a wrench because there's no way to get a ratchet in there. Thanks for the input!
289
4 speed
Rally-Pac
Bench Seat
Power Steering
All-around discs
Aftermarket A/C
post #12 of 34 (permalink) Old 07-03-2019, 11:54 AM Thread Starter
alex1965's Avatar
I have indeed tried my old spark plug on it. There's no way the original style will clear the header-- it can be put on, but the rubber sleeve sits against the header. Obviously not good at operating temperatures, so I'll have to look for a spark plug set with sharper elbows at the end or something similar.
Could I get a picture of yours? I'm not having the same experience as you.
Yeah, that sounds like what I'll have to do. Thanks for pitching in!
289
4 speed
Rally-Pac
Bench Seat
Power Steering
All-around discs
Aftermarket A/C
post #13 of 34 (permalink) Old 07-03-2019, 11:57 AM Thread Starter
alex1965's Avatar
Wow, that's expensive for a socket. I'll see what I can do. Thanks for the advice!
Interesting, I'll have to give my spark plug sockets another look. Didn't seem to be able to clear the header yesterday.
Straight?
135 degree?
90 degree?
Thanks, dm289
Westmus just mentioned he uses 45 degree boots without problems, but I was pretty sure that wasn't going to work for me. If you have an old set, you could try that!
I think 90 degrees is the way I'll have to go. Thanks for the input!
That's a good idea. Thanks for the advice.
289
4 speed
Rally-Pac
Bench Seat
Power Steering
All-around discs
Aftermarket A/C
post #14 of 34 (permalink) Old 07-03-2019, 01:08 PM
Just want to add that what I called "45 degree" boots are the same as the 135 degree. The wire goes up nearly vertical from the plug with these. While the wire will be angled with 90 degree boots. It's mostly about how you want it to look.
Westmus is offline
post #15 of 34 (permalink) Old 07-03-2019, 01:32 PM
GT289's Avatar
Attachment 713912
Attachment 713914
I was present when that particular header design was prototyped (on a '66 Mustang GT).
That tube is NOT where I recall, so I just looked at the prints. (I used to work at JBA
back in the day when they did in-house production, before selling it off to Pertronix)
Apparently someone has changed that production jig. Same deal on the 1650-1. Tube
location is changed from the original placement. See original catalog page below.
- Douglas Adams
GT289 is offline
