Broken water pump bolt - Vintage Mustang Forums
 12Likes
post #1 of 30 (permalink) Old 07-06-2019, 02:47 PM Thread Starter
Ok, as some of you know, I broke a water pump bolt off in the block. Thanks to your help I stopped with the extractor process before (most likely) breaking the extractor off and creating a bigger mess. Some advice included welder extraction which I’m not experienced at but I bought a welder and I am going to practice on some nuts and bolts before moving onto the real deal. Wish me luck. 😳
TAG1966 is offline
post #2 of 30 (permalink) Old 07-06-2019, 02:53 PM
kenash's Avatar
Good Luck! Good idea using the welder. It will pay for itself in the coming years.
Huskinhano and Turnall like this.
KenA..
64 1/2 Poppy Red Cvt. Resto-Mod
333 Cu.in. T5z, 3:55, Dual 40 mm DCOE Webers
Performer RPM, CI cam, TFS/TWs, Tri-Ys, Discs w/Shelby Drums
Severna Park, Maryland
kenash is offline
post #3 of 30 (permalink) Old 07-06-2019, 03:27 PM Thread Starter
Especially after seeing my exhaust manifold and related bolts 😳
TAG1966 is offline
post #4 of 30 (permalink) Old 07-06-2019, 07:17 PM Thread Starter
So my practicing is not going well. I’m using a flux core welder. Can’t seem to get a strong enough weld to hold the nut to the bolt. Any of you seasoned welding veterans have any good tips?
TAG1966 is offline
post #5 of 30 (permalink) Old 07-06-2019, 07:22 PM
you would be better served using a gaswelder . but other wise turn the wire speed down and the power up
Huskinhano likes this.
2nd 66 is offline
post #6 of 30 (permalink) Old 07-06-2019, 07:26 PM Thread Starter
“you would be better served using a gaswelder . but other wise turn the wire speed down and the power up”
So Oxy acetylene?
TAG1966 is offline
post #7 of 30 (permalink) Old 07-06-2019, 08:14 PM
First off more info on the welder you bought
Tom
One thing great about getting older. A life in prison sentence is less of a deterrence
Huskinhano is offline
post #8 of 30 (permalink) Old 07-06-2019, 08:53 PM
FrankieThe69Kid's Avatar
So Oxy acetylene?
Oxy/Acetylene is a torch for braising, different than welding.
A gas welder is either MIG (Metal/Inert Gas) or TIG (Tungsten/Inert Gas). MIG is the easier of the two. A 120v MIG with a bottle of C25 gas will handle just about all the welding you'll need to do on your car.
kenash likes this.
69 Convertible, 351W, T5, E-Brock Performer 351-W intake, Performer Plus cam, Holley 4160, power assist, dual exhaust, 4-wheel manual drums.
FrankieThe69Kid is offline
post #9 of 30 (permalink) Old 07-06-2019, 09:06 PM
kenash's Avatar
Ditto for what "Frankie......." stated, as the gas MIG is a much better combo. The gas shields the arc and keeps it clean. It just takes practice to get the heat, the speed, and the feed correct, but, you will get it. I've always used a gas MIG, so not sure if you can add a bottle to your rig? Maybe someone here can chime in ......?
KenA..
kenash is offline
post #10 of 30 (permalink) Old 07-06-2019, 09:08 PM
bbmach's Avatar
Get yourself a metal plate, and practice making puddles. As 2nd 66 mentioned, start playing with the adjustments for power and wire speed so you see what it does. This way, when you run into a situation you know what it calls for. Too much power/not enough wire produces very different results than shoving too much wire at a unheated workpiece.
Practice practice practice. Good welding is an art form.
FrankieThe69Kid likes this.
1969 Mach-1 Mustang
460 / C6 / 9"
Back in Dixie DSO 22 (Charlotte)
bbmach is offline
post #11 of 30 (permalink) Old 07-06-2019, 11:41 PM
So Oxy acetylene?
MIG, Mixed Inert Gas, Gas Wire welder
2nd 66 is offline
post #12 of 30 (permalink) Old 07-07-2019, 07:16 AM
Hemikiller's Avatar
MIG = Metal Inert Gas aka GMAW - Gas Metal Arc Welding
Either way, a flux core will do the job, but makes a mess. I welded one time with a flux unit, did a pass and went to get my MIG.
Regarding the bolt, you want a slow wire feed speed with the heat set as high as you can get it without causing the wire to melt back into the electrode tip. You need to put heat into the parts to get a good weld and break the rust bond. If you have trouble with it snapping off the bolt, try welding a washer to the bolt, then a nut to the washer.
Huskinhano and kenash like this.
Nothing worthwhile is ever quick, cheap or easy, those that can't do, complain
71 Mach 1
HOLLEY TECH PAGES
FORD OE TACH HOOKUP FORD OE TACH HOOKUP w/MSD (pg 7)
Hemikiller is offline
post #13 of 30 (permalink) Old 07-07-2019, 08:11 AM
dobrostang's Avatar
You tube has some very good videos on welding with a mig. WOrth the time!
Heavy Metal Thunder Video http://www.youtube.com/watch?v=cW3L_O7N_xs
dobrostang is offline
post #14 of 30 (permalink) Old 07-07-2019, 03:28 PM
Using that "gas welder" term confused me too. BTW you certainly can weld with an O/A torch. In fact it's how Chromoly tube aircraft were fabricated before TIG welding replaced it. My first Mustang repairs and fabricated exhaust were done with an O/A rig. The process is the same as TIG, but the flame replaces the electric arc as the heat source.
'65 A-code coupe, T-10 4-speed, 8" 3.25 limited slip
stephen_wilson is online now
post #15 of 30 (permalink) Old 07-07-2019, 04:04 PM Thread Starter
Thank you all for your help!!
File Type: jpg 87948F1F-F753-437A-B14E-62E4F98579E6_1562529866987.jpg (725.7 KB, 12 views)
TAG1966 is offline
