Mustang Steve Brake Questions - Vintage Mustang Forums
 6Likes
post #1 of 23 (permalink) Old 07-10-2019, 09:30 AM Thread Starter
Big Perm's Avatar
I searched the various threads and wasn't able to find exactly what I was looking for. I purchased the Mustang Steve brackets to adapt the 99-04 Cobra brakes to my 1967 Mustang, and I have two primary questions:
1. Flex hoses
It seems like the instructions around this are purposely unclear or put towards the bottom, but will the standard Cobra flex lines thread directly to the existing 1967 hardline connection at the frame? These are the flex lines I purchased, and I really wasn't planning on having to make new hardlines just to adapt to the Cobra flex lines.
2. Wheel fitment
I am running 17x8 Torq Thrust Originals on my car with 4.5" backspacing and a 245 tire. Will this wheel clear the brake caliper? I am not willing to switch to a different wheel just to accommodate this brake, and I will not have room to add a spacer. If this type of brake requires the use of a newer-style wheel, it would be nice if that were called out somewhere.
"I immediately regret this decision."- Ron Burgandy
My 67' Coupe project...http://photobucket.com/lime67
Big Perm is offline
post #2 of 23 (permalink) Old 07-10-2019, 10:02 AM
1: it should fit, but you can either just try it out, maybe use adapters if you have to, or ask on Steve’s FYI Ford forum.
2: hard to know for sure, but in general, 17”s should fit.
cavboy78 and rpm like this.
The anvil of reality.
BlakeTX is online now
post #3 of 23 (permalink) Old 07-10-2019, 11:38 AM
cavboy78's Avatar
i have plenty of caliper-wheel clearance with 17's (4.5 bs). I would be hard pressed to think any 17 in a TT style would have clearance with the cobra calipers.
2012 Boss 302 (Rowdy) - Slowly becoming a track car...not stock
1970 Mustang Sportsroof (Roxy) - 357w roller block, T-5z, Global West Control Arms w/ QA-1's, Vintage Venom Disc Brakes
1966 Mustang Coupe (Rhonda) - 289 2V, PS/PB, Silver Blue
cavboy78 is offline
post #4 of 23 (permalink) Old 07-10-2019, 02:09 PM
70CoyoteStang's Avatar
The Cobra soft lines will not fit directly to the stock 67 hard lines. You will need adapters. The Cobra brakes use different size fittings on one side...
"94-04 Cobra hoses: Note they have a 3/8” SAE inverted flare on one hose and 7/16” inverted flare thread on the opposite side. (On frame end of the hose) Depending on the year of the calipers, the banjo bolts can be fine or coarse thread."
I ended up using braided stainless steel line with AN fittings.
1970 Mach 1
5.0L Coyote swap
Promotion T5 Trans
9" w/ 3.91 Eaton TruTrac
Mustangs to Fear IFS
TCI 4-link Rear Susp
SN95 Cobra disc brakes
70CoyoteStang is offline
post #5 of 23 (permalink) Old 07-10-2019, 02:45 PM Thread Starter
Big Perm's Avatar
This is where I get conflicting information from https://forums.vintage-mustang.com/m...questions.html
If you look a little ways down that thread, he states that he just ended up buying standard Cobra hoses and the bolted right up.
Big Perm is offline
post #6 of 23 (permalink) Old 07-10-2019, 02:55 PM
It's best to find out if the calipers need or course or fine thread banjo bolts once you have the calipers in your hands. These things get all mixed up sometimes by the time you get them. Also, the copper crush washers are different from many cars. They are thicker and seem to have 2 layers. Forget about trying to get this stuff at a local parts store. I would make new hard lines with the correct fittings and attaching position. Front brake lines are not hard to fabricate.
1994-04 MUSTANG FRONT BRAKE CALIPER BANJO BOLT - FINE THREAD
cougar70 is offline
post #7 of 23 (permalink) Old 07-10-2019, 03:18 PM
englishman's Avatar
I did the S197 rotor and caliper swap using Mustang Steve’s brackets. The flexi hoses I used were aftermarket SS braided ones and I made up new hardlines with a metric nut and bubble flare at the flexi end and a regular SAE nut and flare at the other. The SAE ends went into the distribution block on the drivers side and into a pre-existing union on the passenger side.
I’m running 17 x 7 front wheels with 4” backspacing (IIRC) and needed a 5/16” spacer for caliper clearance.
The kit is well engineered and straightforward to install in my opinion
1967 289 Coupe - AOD, Edelbrock heads, Victor Jr, EZ-Efi, roller front suspension, S197 front brakes, 3.55 gears
englishman is offline
post #8 of 23 (permalink) Old 07-10-2019, 06:02 PM
Budstoy's Avatar
1. Flex hoses
2. Wheel fitment
I have the same 04 Cobra brakes on my 66 and the TT's did hit the calipers since the spokes are curved. I test fit them myself and also asked the wheel manufacture and they replied they would not fit. I was able to adapt stock Cobra brake lines but I did have to cut one brake line and put a larger fitting on it. I had to file the stock 66 brake line brackets out using a small flat file but the Cobra lines fit the 66 brake line brackets. I attached some pictures showing how I ran the brakes lines and the one wheel (Rocket) that had less than .015 clearance between the wheel and caliper. Then my final choice (US Mags) I had to buy special valve stems plus I'm running 1/8 spacers. The face of the calipers were super close to the back of the wheel spokes. Both sets of wheels had zero offset. I hope the extra stopping power will justify the hassle the brakes caused!
2nd 66 likes this.
Budstoy is offline
post #9 of 23 (permalink) Old 07-10-2019, 07:14 PM
Nailbender's Avatar
As far as the flex hoses I made up my own on my Mustang Steve 2008 GT caliper setup. A deep search in the Summit website was all it took. I ended up swapping the 45º banjo fitting for 90º fittings for my setup. All Plug and play!
65 C Code hardtop from California still wearing it's original paint.
Roller 331, TW 170 heads, T-5z, FiTech EFI, FPA Headers, Arvinode exhaust, SoT Bilstien coilover front suspension, TJ on eBay 8" 3.40 Trac-Loc 3rd member. Mustang Steve 2008 GT bracketed 12.4" front disks
Nailbender is offline
post #10 of 23 (permalink) Old 07-10-2019, 07:16 PM
If you want to carry a spare tire, you might as well get 5 matching wheels and tires.
cougar70 is offline
post #11 of 23 (permalink) Old 07-10-2019, 07:42 PM
What were the rest of the specs on the wheels?
post #12 of 23 (permalink) Old 07-10-2019, 08:04 PM
DrStang's Avatar
What I used as well when I installed about 13 yrs ago. BTW, still working great.
Nailbender likes this.
"A good friend will help you move. A great friend will help you move a dead body"
September 2017 Mustang Monthly cover car
1965 A-Code Fastback
Built, September 14, 1964 (San Jose)
Viper red, White/red interior
TCP R&P, G Bar rear 4 link/w shockwaves
Global West Upper/Lower/Strut Rods
Ride-Tech Air ride
4 wheel Cobra disc brakes/Hydroboost
363 Stroker/Paxton Supercharger
Mass-Flo EFI
Owned since 1983
DrStang is offline
post #13 of 23 (permalink) Old 07-10-2019, 08:22 PM
Budstoy's Avatar
I tried to fit 17x8's on all corners but I had to put 17x7's on the front
Budstoy is offline
post #14 of 23 (permalink) Old 07-10-2019, 08:31 PM
Ok, so zero offset... does that mean wheels with 3.5in backspace on the front?
post #15 of 23 (permalink) Old 07-10-2019, 08:46 PM
Budstoy's Avatar
A 7in wheel with zero offset have a 4.0 backspace
Budstoy is offline
