Break in question - Fuel in carb bowl vs priming line - Vintage Mustang Forums
 1Likes
  • 1 Post By Klutch
post #1 of 3 (permalink) Old Today, 11:32 AM Thread Starter
Tallguy's Avatar
I will pre-fill the bowl on the Autolite 2100 carb I am using before cam break in. Is that amount of fuel enough to allow the stock style mechanical fuel pump to get fuel through the empty lines to the carb (I am actually running from a gas can so only about 5-6 feet of hose to the fuel pump? I can figure out a way to prime the fuel hoses/pipes but not sure it is necessary.
At 2000-2500 RPM - I did some rough calcs and am guessing about 9.2 ounces per minute of fuel needed (14 MPG @ 60 MPH = 4.3 GPH = 9.2 oz/min). Again just an estimate. I am guessing the bowl hold 4-6 oz, but just eyeballing it.
66 Convertible. Full restoration in the works
Tallguy is online now
post #2 of 3 (permalink) Old Today, 03:00 PM
For initial startup of my rebuilt Cleveland, I poured a little gasoline into the vent tube from a Dixie cup. It was just enough to fire the engine and pull gas from the tank, through the fuel pump and into the carb.
Tallguy likes this.
Currently working on a 1970 Mach 1 project. See it here: http://forums.vintage-mustang.com/vi...ode-build.html
Klutch is offline
post #3 of 3 (permalink) Old Today, 06:46 PM Thread Starter
Tallguy's Avatar
I was able to fill my fuel hose with a "bottle" (OK an old mustard bottle). Held it up higher than the carb and actually got fuel through the fuel pump and into the carb. So I should have fuel almost immediately.
Probably overkill, but not like I build do this every day so whats a little time to ease my overactive/overthinking mind....
