Rear Drum Brake Adjuster not aligning correctly - Vintage Mustang Forums
 1Likes
  • 1 Post By Redneckgearhead
post #1 of 8 (permalink) Old Yesterday, 06:07 PM Thread Starter
1968 Mustang Mach I.
Replaced the brake pads on the rear drums (hadware/springs were kept, they were replaced not too long ago). Passenger side went fine and is all back together. Driver side went together fine, but the brake adjuster metal piece that goes into the gear of the adjuster to keep it from turning on it's own isn't aligning where it needs to be. Should be about 1/2" higher than where it's at. No idea why.
Took it all apart again and re-assembled the brakes, but same result. I had photos of the before and everything appears to be in the same exact spot.
Any idea on what might have caused this? Or how to fix it?
THANK YOU!!
FastTrack38 is offline
post #2 of 8 (permalink) Old Yesterday, 06:09 PM Thread Starter
Here's a photo of it before taking it off.
post #3 of 8 (permalink) Old Yesterday, 07:31 PM
Try reversing the brake shoes, I think the larger one belongs towards the rear. Compare your first pic to your before shot, you can see the brake material is longer on the rear facing shoe in before, and shorter in the after.
George
1966 Sprint 200
George.Galo is online now
post #4 of 8 (permalink) Old Yesterday, 07:50 PM
Redneckgearhead's Avatar
Yep shoes on backwards. A 68 mach? That is a rare pony indeed.
awhtx likes this.
Scott
Never let the truth get in the way of a good story
Redneckgearhead is online now
post #5 of 8 (permalink) Old Yesterday, 11:19 PM
NEFaurora's Avatar
The Larger Brake Shoe ALWAYS goes to the Rear...The Shorter Brake Shoe ALWAYS goes to the Front.
I was watching an episode a few months ago of "Restoration Garage" (Made in Ontario Canada with David Grainger?..and his wife Janice) and they were doing the Front Drum Brakes on a Series 1 XKE Jaguar.... The guy (One of their best workers) doing the Front Drum Brakes actually put the Drum Brake Shoes on backwards....I could not believe it. I was yelling at my TV Screen and even rewound it a few times to see if I was seeing things.....I wasn't. ...lol.. Unreal... Total Fail.
Tony
Tony Kovar
1965 Mustang Convertible 200cid I6, 3spd Manual (Soon to be swapped for a '65 Date Coded C4!)
MCA#70001
Getting Ready for the 2020 Melbourne, FL MCA Nationals!
NEFaurora is online now
post #6 of 8 (permalink) Old Today, 04:50 PM Thread Starter
Thank you all for the fast... and accurate responses. Sure enough, that's what it was. I laid the pads out to compare to the old ones before putting them on and didn't even notice the pads were different sizes. I was looking at the holes, which appeared to be identical until after posting and saw they were just ever so different spaced.
Thanks again, you guys are awesome!
post #7 of 8 (permalink) Old Today, 05:12 PM
NEFaurora's Avatar
Anytime!
Tony Kovar
MCA#70001
post #8 of 8 (permalink) Old Today, 07:38 PM
awhtx's Avatar
Just an FYI- "pads" are used on disc brakes and "shoes" are used on drum brakes. I am a part-time auto parts counter person and I have been baffled a couple of times when a person asks for pads when they mean shoes or shoes when they mean pads.
awhtx is offline
