No turn signals! Need help - Vintage Mustang Forums
post #1 of 11 (permalink) Old 07-13-2019, 09:59 PM Thread Starter
I'm putting my car back together (1970 mach 1) and I cannot figure out why my turn signals are not working. I have headlights and tails. I have power to ONE side of the First flasher. I have replaced the both flashers and traced all the wiring for damage.
I also bought a replacement turn signal switch from CJ's (switch is a POS and does not engage the left signal cam. Read the reviews.. its going back).
Thoughts?
What I don't have plugged in, does it matter??
- Gauge cluster plug (using dakota digital)
- AC/heater stuff (using vintage air)
- wiper switch (don't have one yet)
Thank you
ldouble619 is online now
post #2 of 11 (permalink) Old 07-13-2019, 10:34 PM
NEFaurora's Avatar
Did you add any non-stock Modern LED's to the car?!
If so, That's usually the issue nowadays...
Tony K.
Tony Kovar
1965 Mustang Convertible 200cid I6, 3spd Manual (Soon to be swapped for a '65 Date Coded C4!)
MCA#70001
Getting Ready for the 2020 Melbourne, FL MCA Nationals!
NEFaurora is online now
post #3 of 11 (permalink) Old 07-13-2019, 10:38 PM
sixtysevenGTconv's Avatar
Fuse ok?
Does hazard lights work?
If you borrow a tool more than twice, you need to own it You get what you pay for!
George email: <[email protected]>
sixtysevenGTconv is online now
post #4 of 11 (permalink) Old 07-13-2019, 11:04 PM
Ibcnul8r's Avatar
Make sure you're not over torqueing the steering wheel nut.
Ibcnul8r is offline
post #5 of 11 (permalink) Old 07-14-2019, 08:21 AM Thread Starter
Does the steering wheel need to be on? Right now its not. Anything else to check?
Do all the bulbs need to be installed and in the housings? I didn't think so on a 1970
post #6 of 11 (permalink) Old 07-14-2019, 09:04 AM
awhtx's Avatar
Do the brake lights work? If they do you have a problem in the turn signal mechanism. If you don't have enough bulbs installed the flasher won't operate.
awhtx is offline
post #7 of 11 (permalink) Old 07-14-2019, 03:52 PM Thread Starter
I put in all new bulbs. Still don't work. I'll hook up the brake light switch next.
Where are the grounds on a 1970?
I got one up front grounded to rad support. One under the dash grounded to the cowl. And one in the back tail lights ground to the battery.
post #8 of 11 (permalink) Old 07-14-2019, 05:16 PM Thread Starter
There is NO power at the brake line switch. There is power on one side of the first flasher.
thanks
post #9 of 11 (permalink) Old 07-14-2019, 07:29 PM
awhtx's Avatar
Power to the brake light switch comes from the headlight switch. Check for power coming out of the headlight switch.
awhtx is offline
post #10 of 11 (permalink) Old 07-14-2019, 08:52 PM Thread Starter
Awhtcx, thank you for your suggestion!
There is some whacking things going on.
With headlights ON - 10v to one side of the brake light switch
With headlights off - 0v
With headlights ON - right rear taillight lights brighter when turn signal is engaged. not the turn signal bulb but the brake light bulb.
Headlight switch is new from CJ pony.
post #11 of 11 (permalink) Old 07-14-2019, 08:59 PM
awhtx's Avatar
The rear bulbs are a dual filament 1157 bulb. One filament for taillight and the other filament for brake and turn signal.
Don't buy anything other than a genuine Motorcraft switch.
awhtx is offline
