Headers and heat - Vintage Mustang Forums
 5Likes
  • 1 Post By j persons
  • 1 Post By GT289
  • 1 Post By kenash
  • 1 Post By 2nd 66
  • 1 Post By kenash
post #1 of 11 (permalink) Old 07-15-2019, 03:16 PM Thread Starter
Headers and heat
I aded headers and dual exhaust to my 65 with a 200 6 cyl. The question I have is since I failed to wrap the headers before installing them (rookie mistake) does anyone have ideas on how or what I should do now? The heat being displaced gets all the heater and AC hoses to a temp I am not comfortable with. I have wrapped the hoses in that reflective aluminum tape; but dont like the look to be honest
Bubmullen is offline
post #2 of 11 (permalink) Old 07-15-2019, 03:28 PM
69GT350H's Avatar
https://www.enginelabs.com/engine-te...u-should-know/
VMF Build Thread - 1969 Shelby GT350 Hertz rebuild Gallery
Used by Hertz for the 1969 "Rent-A-Racer" program at Miami Internation Airport.
69GT350H is online now
post #3 of 11 (permalink) Old 07-15-2019, 03:33 PM
j persons's Avatar
Wrapping your headers can be a mistake if they are not stainless. Wrapped headers have been known to trap moisture and that can promote rust. If you are concerned about radiant heat, a heat deflector or shroud can be made from thin gauge aluminum. Position it within a 1/2" of the header and it will eliminate some of the radiant heat.
Huntingky likes this.
F-150 SCab daily driver
j persons is online now
post #4 of 11 (permalink) Old 07-15-2019, 03:44 PM
+1 Wrapping a mild steel header will destroy it . The wrap does it's job fine but it also absorbs moisture when the engine is shut off after running. The "heat shield" is a great idea that works. If you keep the heater hoses at least 6"s away from the header tubes you won't have any issue with them.
Randy
'66 GT350H-3 time cover car - Car Craft July'77,Modified Mustangs and Fords Feb2011 ( w/article), Mustang Monthly June 2014. Bracket raced by me for the last 44 years. Yes it is a real one.
'68.5 R code GT fastback
'67 Ranchero 408W -427 glass hood
'78 F350 "Oleynik" car hauler
Ford Experimental parts collector
GT350HR is offline
post #5 of 11 (permalink) Old 07-15-2019, 04:51 PM
65coupei6_2's Avatar
Remove the headers and have them ceramic coated. On a 6 you have plenty of room to remove and reinstall them.
Or do the above heat shield.
Or get Heat Shield Products Hose Sleeve It looks better than tape.
...Marco
'65 Mustang Inline 200. CI Aliminum Head, Holley 350,
Schneider 264/274 cam, Headers, Recurved DSII, MSD 6A, and a whole lotta other stuff!
65coupei6_2 is offline
post #6 of 11 (permalink) Old 07-15-2019, 06:23 PM
GT289's Avatar
Never wrap headers, regardless of what they are made of.....
Cermacoat headers and exhaust inside and out. That is the solution.
That's what we did at JBA back in the day. I just had a set of headers re-coated that
were originally done in 1990. (Coating was starting to show some signs of failure)
Nice and cool all these years and non-rusty headers.
kenash likes this.
- Douglas Adams
GT289 is offline
post #7 of 11 (permalink) Old 07-17-2019, 01:51 PM Thread Starter
Thanks guys I am looking at the heat shield products now as that seems to be an easy but clean presentation
post #8 of 11 (permalink) Old 07-17-2019, 01:58 PM
Trapped heat ? let it out
2nd 66 is offline
post #9 of 11 (permalink) Old 07-17-2019, 02:07 PM
kenash's Avatar
What's hood look like down? I kinda like the louvered look.
2nd 66 likes this.
KenA..
64 1/2 Poppy Red Cvt. Resto-Mod
333 Cu.in. T5z, 3:55, Dual 40 mm DCOE Webers
Performer RPM, CI cam, TFS/TWs, Tri-Ys, Discs w/Shelby Drums
Severna Park, Maryland
kenash is offline
post #10 of 11 (permalink) Old 07-17-2019, 02:31 PM
Cut the louvers out of an old MTD lawn tractor hood
2nd 66 is offline
post #11 of 11 (permalink) Old 07-17-2019, 02:47 PM
kenash's Avatar
That's a nice induction and heat exhaust system you have going on there. The Etype had this idea in the early 60s. louvered hood. They are a hot blooded type, anyway.
2nd 66 likes this.
KenA..
kenash is offline
