65 coupe Engine bay gauge feed wiring harness help Verify wire - Vintage Mustang Forums
 1Likes
  • 1 Post By NEFaurora
post #1 of 5 (permalink) Old 07-18-2019, 09:42 AM Thread Starter
One wire not identified in the wiring diagrams, its a black wire with a ring terminal, it runs along with the red/blue and brown wires that go to the starter solenoid. Guessing this black wire might go to frame ground?
File Type: jpg 4242F00F-9A8B-4A38-B08B-B8DCFB09C4F8.jpg (269.3 KB, 5 views)
File Type: jpg D157B751-C45B-4D64-B997-00C5FE556F27.jpg (241.3 KB, 5 views)
Navyflyer72 is offline
post #2 of 5 (permalink) Old 07-18-2019, 10:55 AM
NEFaurora's Avatar
No, It also goes on the Starter solenoid.
It goes on the Forward most terminal that the Positive Battery cable is on, on the Starter Solenoid. It goes on BEFORE the Positive Battery cable. Pictures speak louder than words. The Terminal is not just black, but its Black with a Yellow stripe.
Tony K.
Navyflyer72 likes this.
Tony Kovar
1965 Mustang Convertible 200cid I6, 3spd Manual (Soon to be swapped for a '65 Date Coded C4!)
MCA#70001
Getting Ready for the 2020 Melbourne, FL MCA Nationals!
NEFaurora is offline
post #3 of 5 (permalink) Old 07-18-2019, 11:58 AM Thread Starter
Tony K.
So Ill bet thats what smokechecked my black yellow alternator wire the other day I had that hooked to ground.
On this gauge feed harness from Scott Drake, its a plain black wire with a large ring terminal on it. The only black/yellow wire i have is on the alternator harness going to the voltage regulator and the Starter Solenoid?
post #4 of 5 (permalink) Old 07-18-2019, 12:50 PM
Either:
1. Using an ohm meter, determine where the wire goes in the harness (it's not appear to be that complicated a harness) and then "reverse engineer" to determine what it goes to at the other end. a wiring diagram will point you in the right direction.
2. Call CJP! It should have come with instructions to make the set up easy.
CJM68GT390 is offline
post #5 of 5 (permalink) Old 07-18-2019, 03:22 PM
stangtim22's Avatar
That black wire, which is usually black with a yellow stripe is how the ignition switch gets power. It runs from the positive side of the solenoid as a black-yellow and turns into the yellow wire going into your ignition switch. Even if you grounded that wire instead of hooking it to the positive side of the solenoid, I don't believe that would necessarily harm anything. It's only hot from the battery and doesn't get power from anywhere else.
Tim
stangtim22 is offline
