Timing chain gears - Vintage Mustang Forums
 3Likes
  • 1 Post By New2me
  • 2 Post By awhtx
post #1 of 10 (permalink) Old 07-20-2019, 09:45 PM Thread Starter
Timing chain gears
Ok so I got the broken bolt out and I bought the double roller timing chain set. Is there an easy way to get the crank gear on. Seems like it need to be pressed on. Very tight.
TAG1966 is offline
post #2 of 10 (permalink) Old 07-20-2019, 09:54 PM
New2me's Avatar
The crank gear should go on fairly easily. I'd polish the end of the crank where the gear goes on with some good Emery cloth and get it shiny and smooth.
Woodchuck likes this.
Early 65
1998 5.0, fitech efi, holley in tank returnless pump
4R70W transmission with USShift quick 2 controller
3.00:1 8" open rear end
New2me is online now
post #3 of 10 (permalink) Old 07-20-2019, 10:28 PM
awhtx's Avatar
Once you get the crank sprocket started onto the snout you must install both sprockets and the chain at the same time with everything lined up for cam timing.
FrankieThe69Kid and Woodchuck like this.
awhtx is offline
post #4 of 10 (permalink) Old 07-21-2019, 09:58 AM
FrankieThe69Kid's Avatar
I'll ditto awhtx on this. When both sprockets and the chain are lined up perfectly vertically, both should slide on easily. That way the tension on the chain is where it should be. There's no adjusting tension on the chain so there's not much play getting the gears in place.
69 Convertible, 351W, T5, E-Brock Performer 351-W intake, Performer Plus cam, Holley 4160, power assist, dual exhaust, 4-wheel manual drums.
FrankieThe69Kid is offline
post #5 of 10 (permalink) Old 07-21-2019, 11:16 AM
Tallguy's Avatar
My new crank sprocket did not want to go on the end of the crank either. Like others suggested I found a little burr on the end of the crank. Once I took care of that then it went on freely. Also as already stated, when doing both sprockets together they really have to go on at the same time.
66 Convertible. Full restoration in the works
Tallguy is offline
post #6 of 10 (permalink) Old 07-22-2019, 11:25 PM Thread Starter
So, I bought 180 and 320 grit any suggestions on which to use to polish the crank?
TAG1966 is offline
post #7 of 10 (permalink) Old 07-22-2019, 11:37 PM
kenash's Avatar
The 320 should do, just know, as been advised, to apply the chain to was sprocket and push each the same onto their respective positions. They will go, it's just a tedious process.
KenA..
64 1/2 Poppy Red Cvt. Resto-Mod
333 Cu.in. T5z, 3:55, Dual 40 mm DCOE Webers
Performer RPM, CI cam, TFS/TWs, Tri-Ys, Discs w/Shelby Drums
Severna Park, Maryland
kenash is offline
post #8 of 10 (permalink) Old 07-22-2019, 11:41 PM Thread Starter
Thanks I will give it a shot.
TAG1966 is offline
post #9 of 10 (permalink) Old 07-23-2019, 07:28 AM
After sanding make sure and wipe down the crank snout really well with solvent because the sandpaper will leave grit behind. Another thing that can cause the crank gear to hang up is the woodruff key may also have some edges on it. I have had to lightly touch up the edges of a key with a fine file or a stone in the past.
65 2+2, 331, C4 presently apart for complete a restore
1979 Ford F150 custom, 302, C4, AC, tilt wheel, main transportation
macstang is offline
post #10 of 10 (permalink) Old 07-23-2019, 08:06 AM
awhtx's Avatar
After you've polished and cleaned the crank snout apply a thin film of oil or grease to the inside of the crank sprocket to help it slide on.
awhtx is offline
