Oil pan problems - Vintage Mustang Forums
 2Likes
  • 1 Post By dobrostang
  • 1 Post By geicoman58
post #1 of 9 (permalink) Old 07-26-2019, 12:04 PM Thread Starter
Oil pan problems
My center link is hitting the pan where the slave cylinder bolts on. This is a 66 with a repop oil pan {I don't who made it} and Everything is new on the steering. So my question is Who makes a good pan or do I need to find a OEM pan?
BW66 is online now
post #2 of 9 (permalink) Old 07-26-2019, 02:52 PM
cmefly's Avatar
I use this pan on my 65 Falcon. It fit perfect with no issues. It is a Scott Drake product so I may have just got a good one. I would make sure your engine mounts are in good shape. https://www.cjponyparts.com/scott-dr...9-302/p/OPK14/
cmefly is online now
post #3 of 9 (permalink) Old 07-26-2019, 03:10 PM
HoosierBuddy's Avatar
Take a look at your motor mounts before you go to crazy over this. If your motor mounts are past it, it will move your pan closer to your steering.
To answer your question though...I just put in the scott drake 6 quart pan below...and it had gobs of room in my 1965 with power steering.
https://www.summitracing.com/parts/SDK-C5ZZ667522K
It comes unpainted...so I did have to prep it/prime it/paint it before installing it...which added some time to the job.
Phil
"Two barks means faster!" Enzo
HoosierBuddy is offline
post #4 of 9 (permalink) Old 07-27-2019, 08:53 AM Thread Starter
HoosierBuddy I'm not sure what you mean when you say if my motor mounts are past it. Can you give me some more info. Thanks
BW66 is online now
post #5 of 9 (permalink) Old 07-27-2019, 08:55 AM
dobrostang's Avatar
BFH
geicoman58 likes this.
Heavy Metal Thunder Video http://www.youtube.com/watch?v=cW3L_O7N_xs
dobrostang is online now
post #6 of 9 (permalink) Old 07-27-2019, 09:35 AM
geicoman58's Avatar
whack whack...done
dobrostang likes this.
geicoman58 is offline
post #7 of 9 (permalink) Old 07-28-2019, 07:45 AM
Hemikiller's Avatar
Phil
That's not a 6 quart pan, it's a stock replacement with a 5 quart capacity and the bonus of a Boss 302-style baffle.
If your mounts are incorrect, loose, worn, or damaged, it could drop the engine down enough for the pan to interfere with the steering linkage. You also will want to check your transmission insulator and crossmember.
You could also loosen the idler arm through-frame bolts and pull the linkage down as far as it'll go. That might get you the clearance you need. There's also a chance you have the wrong idler arm?
Nothing worthwhile is ever quick, cheap or easy, those that can't do, complain
71 Mach 1
HOLLEY TECH PAGES
FORD OE TACH HOOKUP FORD OE TACH HOOKUP w/MSD (pg 7)
Hemikiller is offline
post #8 of 9 (permalink) Old 07-28-2019, 10:39 AM Thread Starter
They are new motor and trans mounts. I loosen the idler arm and pulled down on it, I got a little then I put a small in the pan. Now I have just under a 1/8 of a inch I don't think that's enough but maybe it is.
It's a new two piece idler arm I don't know if that is right, I will look in to it.
BW66 is online now
post #9 of 9 (permalink) Old Today, 09:54 PM Thread Starter
Update, I bought a new oil pan from rock auto it's made in Canada by Spectra, I think they also make gas tanks. It fits great and I now have plenty of room. Just in case someone is looking for a pan.
BW66 is online now
