So many 66 cooling options..what should I do? - Vintage Mustang Forums
 21Likes
post #1 of 18 (permalink) Old 08-05-2019, 03:53 PM Thread Starter
The car is a 66 C code auto with factory AC
Currently it has an old (Ford stamped tanks) 3 core copper rad and a 17" flex fan. No shroud. It runs hot in traffic and the AC isn't even operational now.
I plan to fix the AC so need proper cooling. I've read every cooling thread and I'm still not sure where to go. The car is quite original but not concours. I like originality but not if it doesn't work so open to all options.
Option 1
Recore the current rad, add a shroud and get a proper clutch fan. Maybe add an electric pusher fan if the AC needs it.
Option 2
New 3 core copper, add a shroud, keep flex fan.
Option 3
Go two core aluminum, add a shroud and keep the flex fan.
Option 4
What say you VMF?
Uncle Buck is offline
post #2 of 18 (permalink) Old 08-05-2019, 05:30 PM
I say new aluminum 2 row radiator, new six blade fan with thermal clutch and a shroud. At least that's the route I took on the 66.
poqman, elcam84 and myfirstcar66 like this.
1966 Convertible restomod in progress
cruising68 is online now
post #3 of 18 (permalink) Old 08-05-2019, 05:40 PM
bmcgc's Avatar
Ive got an original 2 core radiator, shroud, 6 blade fan on a 289 with AC in my 65. Hasnt overheated on 100 degree days.
myfirstcar66 likes this.
1965 Mustang Coupe 289/C4
1967 Mustang Coupe 200/C4
2017 Mustang EB Premium
bmcgc is offline
post #4 of 18 (permalink) Old 08-05-2019, 07:50 PM
You wanna never worry about overheating? With AC in an early mustang?
2 core Alum rad (ACP makes one that looks stock) with a shroud and 6 blade fan.. OR add a SPAL 16in electric fan off a thermostatic switch.
The shroud helps immensely at idle, as does a fan that can actually move some air.
I've got a 331 stroker in my '65. Factory AC. Power Steering and a couple other things that just add heat. I've only had it out in 90 degree temps a couple of times.
My setup? ACP 2 core. Fab'd shroud with a SPAL 16in fan, driven off the holley sniper EFI (comes on at 190 and off at 180), aluminum GMP water pump and 180 T-stat (drilled). Temp gauge never goes past the middle mark, even idling forever with the AC on. (195)
Caper50 and myfirstcar66 like this.
Rowdy is offline
post #5 of 18 (permalink) Old 08-05-2019, 10:18 PM
myfirstcar66's Avatar
I have 2 66s with the original "C6OE - G" 7-blade fan and thermostatic clutch, shroud, and brass / copper radiators. One is 3 row replacement HD cooling and the other is 2 row for Dealer-installed air and the only heat problem I've had on HOT days has been when I unknowingly let one get low on coolant on a long highway trip. Had a surprise leak and apparently one of the people waving at me wasn't because they liked the car - - it was because they could smell the coolant when they were behind me.
Grimbrand likes this.
My 1st car...
'66 Tahoe Turquoise/ Aqua coupe
•289 / 4100 •C4 Auto •Disc Brakes
•Dual Exhaust •Quick Manual Steering
•Rally Pac •Console •Deluxe Belts
•LOTS of Rotunda accessories
Older son's 1st car...
'66 Emberglo / Parchment deluxe coupe
•289 / 2100 •C4 Auto
•Dealer A/C • Console
•Dual Exhaust • Power Steering
Younger son's 1st car...
'66 Nightmist / Blue & white deluxe coupe
•Factory A/C •Console
WAITING FOR RESTORATION
myfirstcar66 is online now
post #6 of 18 (permalink) Old 08-05-2019, 10:33 PM
66#3's Avatar
You and I are alike: 66 C-code, auto, A/C. I went with your option 3, pulling the original brass and going with 2-core aluminum plus factory shroud and clutch fan. My car is VERY original looking, but that does me no good if I can't drive it.
I also did a couple of flushes with evaporust and added an inline coolant filter to protect the new radiator from rust flakes that the evaporust might have missed.
A consolation to going with option 3 over the pure stock solution is that it is completely reversible. It's only nuts and bolts.
Bill
6F07C
Color: Y
Trim: 22
Axle: 6
Trans: 6
Build Date: July 18, 1966
66#3 is offline
post #7 of 18 (permalink) Old 08-05-2019, 10:41 PM
Woodchuck's Avatar
In '66 with a 289 and air conditioning you got the following:
a. A 3-core radiator with 11 fins per inch spacing.
b. A THERMAL fan clutch and 6-blade fan.
c. A radiator shroud.
d. A carburetor Hot Idle Compensator.
Back in "the day", these cars didn't overheat. They shouldn't, today, if all your pieces and parts are up to the OEM standard AND your state of tune takes into account any modifications you've made AND the fuel you are using.
Bart
What, me worry?
- Alfred E. Neuman
Woodchuck is online now
post #8 of 18 (permalink) Old 08-06-2019, 01:05 AM
NEFaurora's Avatar
ACP MAX-CORE Two Row Aluminum Radiator (From Virginia Classic Mustang (VCM or NPD) and 2 cans of Eastwoods Radiator Black.....Six Blade Fan (clutch optional)..... All day long.....
If your radiator is original (Has Original FORD STAMPINGS)....Re-core it and keep it or sell it to someone who needs it.... Do not throw away..
Tony K.
Tony Kovar
1965 Mustang Convertible 200cid I6, 3spd Manual (Soon to be swapped for a '65 Date Coded C4!)
MCA#70001
Getting Ready for the 2020 Melbourne, FL MCA Nationals!
NEFaurora is offline
post #9 of 18 (permalink) Old 09-17-2019, 03:34 PM
tmadden's Avatar
I like this setup - just wanted to know the fabing of the shroud over the Spal 16in fan. I have the Sniper EFI AC PS AT - trying to keep my car cooler down here in Texas.... Thought I'd go with the 3 core Aluminum ACP - Thoughts
Warm Regards
Todd
tmadden is offline
post #10 of 18 (permalink) Old 09-17-2019, 06:25 PM
18" GM fan and 75 Chevy thermostatic fan clutch and 2 row aluminum radiator. While it really should have a shroud, it cools fine even idling
Rowdy likes this.
Huskinhano is offline
post #11 of 18 (permalink) Old 09-17-2019, 08:48 PM
Quicksilver66's Avatar
da. A carburetor Hot Idle Compensator.
I’m curious what you mean when you talk about tuning for the fuel you’re using. Thanks.
Woodchuck likes this.
1966 GT 2+2 - 347, Edelbrock carb, Tremec TKO 600 5 speed, 9” rear and a bunch of other cool stuff.
Follow me on Instacart
Quicksilver66 is offline
post #12 of 18 (permalink) Old 09-17-2019, 08:58 PM
Woodchuck's Avatar
Today's gasoline isn't formulated the same as it was back "in the day". Fuels containing ethanol as an oxygenator don't burn at the same rate as "pure" gasoline so it's necessary to experiment with carburetor jetting and ignition timing in order to find the settings that work best for any particular build.
Huskinhano and Quicksilver66 like this.
Bart
What, me worry?
- Alfred E. Neuman
post #13 of 18 (permalink) Old 09-17-2019, 11:53 PM
Feethurt's Avatar
I have some old aftermarket (stock replacement) radiator, a 302, flex fan, and no shroud. My car never overheats. I'm thinking about adding a shroud just for safety, I'm a scatter-brained idiot and sooner or later I'll lose a hand to that thing.
Feethurt is offline
post #14 of 18 (permalink) Old 09-18-2019, 12:07 AM
Then you better add something besides the stock shroud or put a guard over it, because the stock one is not very wide and the fan only sits half inside it.
I can relate to being scatterbrained.
My 1st car...
post #15 of 18 (permalink) Old 09-18-2019, 12:13 AM
I had a local tin shop just bend up a small shroud that the SPAL fan now mounts to and it mounts to the rad mounts. Pretty simple.
Either the two or three core ACP rads work.
If I was in a hotter climate, I'd probably consider doing the swap to the bigger +67 rad..
tmadden likes this.
Rowdy is offline
