Gas Cap Question - Vintage Mustang Forums
 10Likes
post #1 of 16 (permalink) Old 08-11-2019, 10:48 PM Thread Starter
Gas Cap Question
Maybe this is a dumb question but how to you fix the alignment of a 1966 gas cap
When my cap is tight, it's clocked about 90 deg past where it should so the emblem is sideways.
I think it's an original cap.
Uncle Buck is offline
post #2 of 16 (permalink) Old 08-11-2019, 11:02 PM
NEFaurora's Avatar
Baiscally, You make the Gas cap as tight as you can, and then back it up to make the emblem look straight...
How's that for an answer!.....lol....
It's the Truth!
They are all like that since day 1. Some align better than others...
Tony K.
Tony Kovar
1965 Mustang Convertible 200cid I6, 3spd Manual (Soon to be swapped for a '65 Date Coded C4!)
MCA#70001
Getting Ready for the 2020 Melbourne, FL MCA Nationals!
NEFaurora is offline
post #3 of 16 (permalink) Old 08-11-2019, 11:03 PM
kenash's Avatar
Here's what I have......
Now, has the tank filler pipe been changed in some way?
Sorry, not sure why it's oriented incorrectly.
KenA..
64 1/2 Poppy Red Cvt. Resto-Mod
333 Cu.in. T5z, 3:55, Dual 40 mm DCOE Webers
Performer RPM, CI cam, TFS/TWs, Tri-Ys, Discs w/Shelby Drums
Severna Park, Maryland
kenash is offline
post #4 of 16 (permalink) Old 08-11-2019, 11:11 PM
watto1's Avatar
So, the first picture.. the gas cap is not tightened yet?
The slots on the filler neck seem correct, really can only go one way..
Next, check your cap..
Sent from my SM-G950F using Tapatalk
watto1 is online now
post #5 of 16 (permalink) Old 08-11-2019, 11:46 PM Thread Starter
Looking at the cap, I see there's no obvious gasket. I guess using one of the rubber gaskets I see at CJ's would make it tighten up sooner and align better?
post #6 of 16 (permalink) Old 08-12-2019, 12:35 AM
NEFaurora's Avatar
I know why. It's not an Original Pipe. It's a Reproduction one....and a cheap one at that. Original '65-'66 Gas Fill Tubes have (5) bosses on the front lips of the Filler Tube. Yours has none....because its a Cheaper Taiwan Repro filler tube. ACP makes good repro ones...like the originals.... or just buy a darn Original one here...
https://www.ebay.com/itm/1964-5-1965...-/152552251048
But that's not your biggest problem... You have the wrong year Gas Cap. You have a 1964 1/2 Gas Cap....with no security bail wire.
Here's what the "correct" 1966 Gas Cap should look like below.. It's what should be on your 1966 year Mustang. Are you sure that you have a 1966 Mustang?!?? Let's see the front and sides and dash of your car!
https://www.ebay.com/itm/NEW-1966-Fo...EAAOSwcwhVN-xs
Tony K.
Josep likes this.
Tony Kovar
MCA#70001
post #7 of 16 (permalink) Old 08-12-2019, 12:39 AM
watto1's Avatar
You should have that seal, but I suspect it won't solve your issue. From memory, the cap only rotates about 90° once engaged into the neck slots.. so for your cap to come back 90°, there will be minimal bite.
post #8 of 16 (permalink) Old 08-12-2019, 08:41 AM Thread Starter
My cap cap rotates at least 180 so maybe a gasket will help it snug up sooner and still have a good amount of engagement.
I'm in Canada so a bit of a pain getting a gasket. $5 part and $25 shipping from CJ. I'll keep looking...
post #9 of 16 (permalink) Old 08-12-2019, 08:51 AM
myfirstcar66's Avatar
Check with National Parts Depot for the correct gasket and ask them to just mail it in a regular envelope, or purchase a correct cap for your car that includes the gasket and attaching bailing wire.
'66 Tahoe Turquoise/ Aqua coupe
•289 / 4100 •C4 Auto •Disc Brakes
•Dual Exhaust •Quick Manual Steering
•Rally Pac •Console •Deluxe Belts
•LOTS of Rotunda accessories
...my first car
'66 Emberglo / Parchment deluxe coupe
•289 / 2100 •C4 Auto •Disc Brakes
•Dual Exhaust •Power Steering
•Dealer Air Conditioning •Console
'66 Nightmist / Blue & white deluxe coupe
•Factory Air Conditioning •Console
WAITING FOR RESTORATION
myfirstcar66 is offline
post #10 of 16 (permalink) Old 08-12-2019, 09:50 AM
Turnall's Avatar
Seems everyone thinks Uncle Buck and kenash own the same vehicle...
Allen
65coupei6_2, Joe, subpar63 and 2 others like this.
Turnall is online now
post #11 of 16 (permalink) Old 08-12-2019, 10:03 AM
kenash's Avatar
Allen
Thanks Allen, I was waiting for that shoe to drop.
BTW, for those that missed the details of this,......
Yes, I do have a gasket behind the flange and it is the original filler pipe. Being an early style, it does not have the bailing attachment.
KenA..
kenash is offline
post #12 of 16 (permalink) Old 08-12-2019, 02:31 PM
where are you? I am coming to Toronto in a few weeks and have no problem throwing a cap in my suitcase
Bubmullen is offline
post #13 of 16 (permalink) Old 08-12-2019, 03:55 PM
NEFaurora's Avatar
1965 (Not '64 1/2) and 1966 Gas caps are set up like this below... The diagram below shows you how to set up the Wire Bail Security wore on 1965 and 1966 Gas caps.
kenash likes this.
Tony Kovar
MCA#70001
post #14 of 16 (permalink) Old 08-12-2019, 05:15 PM Thread Starter
Im about an hour north of a Toronto. Thanks for the offer but all I need is the gasket so will call and try and get one dropped in the mail.
post #15 of 16 (permalink) Old 08-12-2019, 05:20 PM Thread Starter
Allen
Lol, my gas cap question sure seemed to create some confusion.
So the record is straight, my car is a 66. It has the original filler neck, gas cap and cable. It is also red though...
Thanks all for the info.
