gas sending unit - Vintage Mustang Forums
 12Likes
  • 1 Post By guitarman584
  • 2 Post By kenash
  • 3 Post By 66coupe289
  • 6 Post By Woodchuck
post #1 of 9 (permalink) Old 08-13-2019, 12:58 PM Thread Starter
pennsy's Avatar
gas sending unit
does the gas tank have to be completely empty in order to remove and replace sending unit on a 65 coupe?
pennsy is offline
post #2 of 9 (permalink) Old 08-13-2019, 01:38 PM
kenash's Avatar
Based on the location, the fuel level needs to be pretty low. However, I suppose if you jacked up the rear pushing any fuel left in the tank to the front, you could remove the sender.
KenA..
64 1/2 Poppy Red Cvt. Resto-Mod
333 Cu.in. T5z, 3:55, Dual 40 mm DCOE Webers
Performer RPM, CI cam, TFS/TWs, Tri-Ys, Discs w/Shelby Drums
Severna Park, Maryland
kenash is online now
post #3 of 9 (permalink) Old 08-13-2019, 01:48 PM
guitarman584's Avatar
Uh, don't you mean jack up the front of the car so the fuel goes to the back of the tank? The sending unit is in the front of the tank.
pennsy likes this.
1965 coupe w/ 302 out of a '68, Edelbrock 2027 top-end kit, Autolite 4100, Mustang II front end conversion, AAW wiring harness, rear-disc conversion, Dakota Digital dash
guitarman584 is offline
post #4 of 9 (permalink) Old 08-13-2019, 02:09 PM
kenash's Avatar
OOPS!, Yes, I stand corrected. I was looking at the sending unit in a spare tank I have on the shelf, not thinking of the orientation. Yes, jack up the front.
My apologies for any confusion.
pennsy and guitarman584 like this.
KenA..
post #5 of 9 (permalink) Old 08-13-2019, 02:14 PM
66coupe289's Avatar
Does it need to be empty, no, will it be empty shortly after you pull the sending unit...yes.
This is why a tank with a drain plug is so handy.
2nd 66, Woodchuck and guitarman584 like this.
Chris (Sussex, WI)
289 w/AFR 165, T-5z, 3.55T-loc, Granada Discs and 6 bolt Moto-Lita Steering Wheel
66coupe289 is offline
post #6 of 9 (permalink) Old 08-13-2019, 04:01 PM Thread Starter
pennsy's Avatar
My tank does have a drain plug....so I think I will drain it down...not sure how much gas is in tank
pennsy is offline
post #7 of 9 (permalink) Old 08-13-2019, 04:02 PM Thread Starter
pennsy's Avatar
Thanx for the replies.
pennsy is offline
post #8 of 9 (permalink) Old 08-14-2019, 08:49 AM
Hopefully yours will come out. The one in my '66 was stuck so badly that the welded nut on the inside broke free. The gas did drain out, just not the way it was supposed to. It wasn't a big deal in this case, since I was replacing the original old tank with a SS one.
reevescajr is offline
post #9 of 9 (permalink) Old 08-14-2019, 08:55 AM
Woodchuck's Avatar
Hint: To avoid an unwanted surprise, NEVER use a steel tool to spin the lock ring. Use a BRASS punch or drift.
Bart
What, me worry?
- Alfred E. Neuman
Woodchuck is online now
