water pump - Vintage Mustang Forums
 4Likes
  • 2 Post By vegasloki
  • 2 Post By Woodchuck
post #1 of 14 (permalink) Old Yesterday, 02:21 PM Thread Starter
water pump
Apparently there is a supply crisis for water pumps. NPD, CJ, etc. is out. I am putting in new A/C and want to go ahead and replace the original. Cast Iron '66 289. Any suggestions? Go ahead and install A/C? wait? or another option?
You never know until you ask.
kclark is offline
post #2 of 14 (permalink) Old Yesterday, 02:26 PM
check your local parts house ?
2nd 66 is offline
post #3 of 14 (permalink) Old Yesterday, 02:30 PM
vegasloki's Avatar
Unless you need a casting with the right numbers NAPA is a good source for them as is Rock Auto.
Huskinhano and myfirstcar66 like this.
67 Hardtop, brought it back to a driver
http://desertratretro.com
vegasloki is offline
post #4 of 14 (permalink) Old Yesterday, 02:51 PM
gjz30075's Avatar
pm sent to kclark...
Greg Z.
'66 GT
gjz30075 is offline
post #5 of 14 (permalink) Old Yesterday, 03:42 PM
1965GTFB's Avatar
Try Summit Racing. I'm in Nor-Cal and usually get parts in 1 day.
Also consider a FlowKooler https://www.flowkoolerwaterpumps.com...e%3A289%2F4.7L
'68 J code coupe back in H.S.1st car. Now 65 GTFB
Daughter & I built her a '66 coupe feature car in 8/04 MM & '05 Meguiar's winner see it @ Meguiars.com Made matching pedal car for her daughters.
Built a '68 j code coupe with oldest son. Made matching pedal car for his sons.
Built a '67 FB with youngest son. Yes I'll be making a matching pedal car when he has kids.
Future '74 TR6 Project for Wife
1965GTFB is offline
post #6 of 14 (permalink) Old Yesterday, 07:29 PM Thread Starter
I do have a question. I am certain that I need a cast iron and not an aluminum pump. I have read several places including on this forum that says that the aluminum pump has 3 "ribs" and the cast iron has 7 "ribs". What are the ribs? I can't seem to locate this terminology so I can double check mine before I take it off.
kclark is offline
post #7 of 14 (permalink) Old Yesterday, 07:36 PM
Sounds like that would be for a serpentine belt. Make sure your looking at the right year.
I usually try to go with ‘high flow’, myself. Always ran cooler.
ErnieIII is offline
post #8 of 14 (permalink) Old Yesterday, 07:40 PM
The original aluminum pump fits a different timing cover.
They make many 'cast iron style' pumps now in aluminum. I've got one on my car.
Rowdy is offline
post #9 of 14 (permalink) Old Yesterday, 09:27 PM
The ribs have nothing to do with the pump itself. The early 65 timing covers used with the aluminum pumps had 2 ribs on the top. The later timing cover for the cast iron pump had 7 ribs. Latter timing covers had no ribs. They don’t seem to serve a purpose other than to identify which version you have. Probably for the spassembly line workers.
There’s a picture showing the difference on page 5-32 of Bob Mannel’s book.
What’s important to remember is that you can’t mix a aluminum pump timing cover with a iron pump or vice versa
Also the timing covers and pumps have different boss thicknesses so you need different length bolts and spaces for any accessories.
Flade
68 289 convertible Candy-apple red & white
66 200 coupe Blue
94 GT convertible Red & black
98 GT convertible White & black
98 V6 convertible White & tan
Flade is offline
post #10 of 14 (permalink) Old Yesterday, 09:39 PM
Woodchuck's Avatar
There are also rebuild kits for your cast iron pump that include a new impeller/shaft/bearing assembly and seals.
If you want to replace your OEM cast iron pump with an aluminum version, Milodon has a nice one.
#16230
subpar63 and vegasloki like this.
Bart
What, me worry?
- Alfred E. Neuman
Woodchuck is offline
post #11 of 14 (permalink) Old Yesterday, 10:49 PM
bmcgc's Avatar
I bought a cast iron pump from Summit yesterday. it seems to be of good quality, but not near the quality of the one I removed.
The pump I removed is stamped Made in USA and has thicker webbing to support the snout.
Look at the top of your WP where it meets the timing cover. You will see the ribs on the timing cover, 2 or 7.
Your 66 289 will have 7 ribs if it is original.
I recommend the cast pump if you have 7 ribs on the timing cover, they seem to hold up better, at least the parts store offerings.
1965 Mustang Coupe 289/C4
1967 Mustang Coupe 200/C4
2017 Mustang EB Premium
bmcgc is offline
post #12 of 14 (permalink) Old Yesterday, 10:53 PM Thread Starter
Thanks, I'll look to double check. I may look into sending it off to be rebuilt.
kclark is offline
post #13 of 14 (permalink) Old Today, 12:24 AM
victor's Avatar
NAPA typically stocks good quality water pumps..
victor is offline
post #14 of 14 (permalink) Old Today, 03:21 AM
NEFaurora's Avatar
Summit also carries Edelbrock Water Pumps which are excellent as well...
Tony K.
Tony Kovar
1965 Mustang Convertible 200cid I6, 3spd Manual (Soon to be swapped for a '65 Date Coded C4!)
MCA#70001
Getting Ready for the 2020 Melbourne, FL MCA Nationals!
NEFaurora is online now
