1966 Mustang rear brake shoes not making full contact - Vintage Mustang Forums
 4Likes
  • 2 Post By RV6
  • 1 Post By Woodchuck
  • 1 Post By Grabber Blu
post #1 of 15 (permalink) Old 08-15-2019, 03:49 PM Thread Starter
Help !! I just had my 1966 A code's brakes redone. New m/c, new w/c, shoes, drums, brake kits, the works. After the garage replaced everything, when testing, they found that the rear shoes are making minimal contact with the drums. They are suspecting that the rear w/c are the wrong ones. The build date on the door plate shows May 66, but the plate is a repro. We ordered the post-April 66 w/c.
Question: Could this be the problem? I don't think so. From what I've read, if they didn't match the old w/c, the threads would be wrong. Even so, could the wrong w/c cause this problem?
If not, what else could it be? I don't think it can be the w/c, because the parking brake no longer holds the car on a grade. No w/c involved in that process. Can it be that the shoes are too thin? Or the drums too big?
Grasping at straws here.
gordandmichele is offline
post #2 of 15 (permalink) Old 08-15-2019, 04:15 PM
dblooseven's Avatar
Just a basic question. Are the self adjusters not spread as far as they will go? Anytime I do a brake job I always spread them out to where the drum just barely slides on.
dblooseven is online now
post #3 of 15 (permalink) Old 08-15-2019, 04:32 PM Thread Starter
The garage guys say yes, but I'm going to have them show me. I tried reversing and stopping a number of times to get them to "self adjust" but it didn't do anything.
post #4 of 15 (permalink) Old 08-15-2019, 05:27 PM
RV6
RV6's Avatar
Back in the day, when drum brakes ruled, a good shop would true the shoes to the drum. Not gonna happen in today's world.
Huskinhano and kenash like this.
Gary
Pine, CO
1967 Coupe, 289-4V, T-5
RV6 is offline
post #5 of 15 (permalink) Old 08-15-2019, 05:34 PM
CHOCK's Avatar
Take it to a garage that knows mechanics!
Corner tire store, big chains, startups do not have enough computers to fix a old Mustang. Most of them, the robotic arms are broken. Everyone is staring at the computer for next update.
CHOCK is online now
post #6 of 15 (permalink) Old 08-15-2019, 05:59 PM
That's how the shoes are when new.They just need to be broken in which will take a few thousand miles
shelby289s is offline
post #7 of 15 (permalink) Old 08-15-2019, 06:52 PM
Woodchuck's Avatar
Let's start here.... When you apply the parking brake does the handle come ALL THE WAY out to the end? That would be a good indication that the shoes aren't adjusted properly.
The other issues that could be in play are reversal of primary and secondary shoes and, yes, nobody knows anything about arcing rear brake shoes to match the radius of the drums. One more thing... many brake shoes have garbage for lining material. The parking brake should hold, but service brakes may require excessive pressure to properly apply.
CHOCK likes this.
Bart
What, me worry?
- Alfred E. Neuman
Woodchuck is offline
post #8 of 15 (permalink) Old 08-15-2019, 07:25 PM
sixtysevenGTconv's Avatar
Well here in southern NH, we have a local non chain auto parts store, and YES they have a brake lathe to turn drums and rotors. I've bought several new rotors that not true, not uncommon, for ~ $15 they'll clean them up..
If you borrow a tool more than twice, you need to own it You get what you pay for!
George email: <[email protected]>
sixtysevenGTconv is offline
post #9 of 15 (permalink) Old 08-15-2019, 08:14 PM
Grabber Blu's Avatar
Back in the day a real auto parts store you purchased brake shoes and had the drums cut the shoes would be arced and placed in each drum.
A brake job done this way assured a firm pedal that stopped straight.
The shop I worked in the 80's we had a lathe that had the arcing machine on it and we would arc the shoes
Huskinhano likes this.
Larry
Grabber Blu is offline
post #10 of 15 (permalink) Old 08-15-2019, 09:34 PM
This ∆∆∆∆ before days of big impersonal chain shops the local independent shoes took the time to do the job right. They would cut the drums and the shoes would be arc ground to make full contact with the drum.
Tom
One thing great about getting older. A life in prison sentence is less of a deterrence
Huskinhano is offline
post #11 of 15 (permalink) Old 08-15-2019, 11:41 PM
awhtx's Avatar
I remember reading somewhere that "arcing" brake shoes has been outlawed by the EPA or OSHA due to the dust being declared HazMat. Maybe that was back when shoes actually had asbestos in the lining material.
Maybe somebody has more knowledge of this.
awhtx is offline
post #12 of 15 (permalink) Old 08-16-2019, 06:55 AM
NEFaurora's Avatar
" I tried reversing and stopping a number of times to get them to "self adjust" but it didn't do anything. "
It sounds like you didn't do it enough.. or you brought your self adjusters in way to far... That's why it's taking you longer to bring them all the way out..
Tony K.
Tony Kovar
1965 Mustang Convertible 200cid I6, 3spd Manual (Soon to be swapped for a '65 Date Coded C4!)
MCA#70001
Getting Ready for the 2020 Melbourne, FL MCA Nationals!
NEFaurora is offline
post #13 of 15 (permalink) Old 08-16-2019, 07:11 AM
bmcgc's Avatar
Make sure the adjusters are on the right wheel.
1965 Mustang Coupe 289/C4
1967 Mustang Coupe 200/C4
2017 Mustang EB Premium
bmcgc is offline
post #14 of 15 (permalink) Old 08-16-2019, 07:42 AM
NEFaurora's Avatar
"Make sure the adjusters are on the right wheel. "
Great suggestion!
The RIGHT SIDE Adjusters are labeled "R" under the end caps and the LEFT SIDE Adjusters are labeled "L" under the end caps. They are not the same and NOT INTERCHANGEABLE either!
Make sure that each wheel has its correct side adjusters! A common mistake for people to make! Again, Thanks for that suggestion "bmcgc"...
Tony K.
Tony Kovar
MCA#70001
post #15 of 15 (permalink) Old 08-16-2019, 10:07 AM
I have two old brake shoe 'resetting gauges' that you measure the I.D. of the drum with and lock it in place.
You then place the other end over the shoes and adjust them as close as possible before putting the drum on.
After that, the self-adjusters or brake spoon will complete the adjustment.
Here's a link to one: https://www.amazon.com/GEARWRENCH-33...SIN=B0002SQUJ0
Wiseguy59 is offline
