Replacement Battery - Vintage Mustang Forums
 3Likes
post #1 of 19 (permalink) Old 08-17-2019, 03:17 PM Thread Starter
Replacement Battery
In doing work redoing the heater core, I guess I left the door ajar for too long and ran the battery down. The battery was put in by the Previous Owner in 2012 so I decided to just replace the battery. Anyway, I went to Oreilly's to get a new battery and picked up one of theirs that would work. The battery does work but does not fit the battery locking clamp on the side of the battery. What do you guys do for a replacement battery that will work with the battery mount?
You never know until you ask.
2nd owner 1966 Mustang Coupe V8.
kclark is offline
post #2 of 19 (permalink) Old 08-17-2019, 03:30 PM
myfirstcar66's Avatar
This is a common topic. Very few battery manufacturers include the notch on the side for the clamp anymore. Some have found one at Tractor Supply I heard. What kind was your old one that had the notch? Some people have installed a 67-68 battery tray in the 65-66 and used the 67-68 style clamp. Some spend several hundred dollars on a concours reproduction Autolite battery. Some use a bungee cord to hold in the Brand X. There is little in between.
My 1st car...
'66 Tahoe Turquoise/ Aqua coupe
•289 / 4100 •C4 Auto •Disc Brakes
•Dual Exhaust •Quick Manual Steering
•Rally Pac •Console •Deluxe Belts
•LOTS of Rotunda accessories
Older son's 1st car...
'66 Emberglo / Parchment deluxe coupe
•289 / 2100 •C4 Auto
•Dealer A/C • Console
•Dual Exhaust • Power Steering
Younger son's 1st car...
'66 Nightmist / Blue & white deluxe coupe
•Factory A/C •Console
WAITING FOR RESTORATION
myfirstcar66 is online now
post #3 of 19 (permalink) Old 08-17-2019, 03:34 PM
New2me's Avatar
There are very few battery manufacturers that have the hold down foot you need molded into the battery. The only one that I've seen lately was an AC Delco battery at my local menards. My battery doesn't have the foot molded into the case so I split a piece of fuel line and slid it over the edge of the hold down, then I got the hold down as tight to the battery as I could before I tightened it down. It's not a perfect solution but the battery is secure in the tray.
Early 65
1998 5.0, fitech efi, holley in tank returnless pump
4R70W transmission with USShift quick 2 controller
3.00:1 8" open rear end
New2me is online now
post #4 of 19 (permalink) Old 08-17-2019, 04:31 PM
bmcgc's Avatar
I bought the 67 style tray made for a 65 and used the 67 hold down.
That option gives you the most choices for a battery.
I bought a AGM battery, painted it black, put a repop Autolite top on it with repop cables. It doesnt look original by any means but its nice and clean and looks period correct-ish.
vegasloki likes this.
1965 Mustang Coupe 289/C4
1967 Mustang Coupe 200/C4
2017 Mustang EB Premium
bmcgc is online now
post #5 of 19 (permalink) Old 08-17-2019, 04:31 PM
carlite65's Avatar
carlite65 is offline
post #6 of 19 (permalink) Old 08-17-2019, 07:42 PM
awhtx's Avatar
I have a Group 48 in my '65 and it has the lug on the end for the original style clamp. The posts are recessed into the case so that the top of the post is flush with the top of the battery. As you are looking at the battery in the attached link the + post is on your right, same as the Group 24F battery.
https://www.oreillyauto.com/search/1...ustang?q=48prm
awhtx is offline
post #7 of 19 (permalink) Old 08-17-2019, 08:43 PM Thread Starter
According to the O'Reilly site, that battery doesn't go with a '65 or a '66.
kclark is offline
post #8 of 19 (permalink) Old 08-17-2019, 09:21 PM
Woodchuck's Avatar
The BCI Group 46/H6 battery lists the same dimensions as the 24F... 10-3/4 x 6-13/16 x 9... and it looks like Advance Auto has a variety... Also, WalMart lists a group H6 in the EverStart brand but I'd want to put a tape measure on it first...
Bart
What, me worry?
- Alfred E. Neuman
Woodchuck is offline
post #9 of 19 (permalink) Old 08-17-2019, 09:37 PM
kenash's Avatar
Yeah, this subject received a lot of hits and recent as a few months ago. I reported, at that time, in June 2018 I purchased a GRP 24F battery from Battery warehouse. It had the base extension. My previous was an Exide MT-24F, it too, had the base extension for the base clamp.
Either if these two Companys near you?
KenA..
64 1/2 Poppy Red Cvt. Resto-Mod
333 Cu.in. T5z, 3:55, Dual 40 mm DCOE Webers
Performer RPM, CI cam, TFS/TWs, Tri-Ys, Discs w/Shelby Drums
Severna Park, Maryland
kenash is offline
post #10 of 19 (permalink) Old 08-17-2019, 09:52 PM Thread Starter
No battery warehouse. Not sure who your second company is.
kclark is offline
post #11 of 19 (permalink) Old 08-17-2019, 09:55 PM
kenash's Avatar
My Exide battery brand was purchased from an Interstate Battery company. If this helps.
KenA..
kenash is offline
post #12 of 19 (permalink) Old 08-17-2019, 10:19 PM Thread Starter
I might give this one a try for $160
https://www.samsclub.com/p/auto-grou...lp_product_1_7
and if anyone still wants a Lead Acid they have this one for $116
https://www.samsclub.com/p/duracell-...lp_product_1_4
kclark is offline
post #13 of 19 (permalink) Old 08-17-2019, 10:42 PM
kenash's Avatar
If you chose the AGM, do your research regarding maintaining it during a long term off season storage. AGM's require special charging equipment, especially, if the charge falls below a certain minimum believed to be 10Vs or less.
I would purchase a high quality battery maintainer designed to cover AGMs in addition to wet cell batteries. This is my current maintainer.....
KenA..
kenash is offline
post #14 of 19 (permalink) Old 08-17-2019, 11:02 PM Thread Starter
I like the NOCO Genius models. I have a couple that I use for a 1929 Studebaker (6V) and a 1954 Chevy Truck.
kclark is offline
post #15 of 19 (permalink) Old 08-17-2019, 11:59 PM
awhtx's Avatar
They say it doesn't fit because the "books" only show a 24F for the '65 Mustang. I can tell you from personal experience that it does fit. If you're not concerned about Concours appearance it works just fine.
I have looked at 24F batteries just about everywhere and all of them that I have seen no longer have the hold down lugs on the ends. Exide recently discontinued the lugs on their 24F. That is the battery most guys were buying because it was easy to peel the Exide sticker off of the side and replace it with an Autolite sticker that along with the replica top piece gave it a Concours appearance.
awhtx is offline
