Bracket help! 3G 1-wire Alt from PA Performance - Vintage Mustang Forums
 1Likes
  • 1 Post By Rufus68
post #1 of 9 (permalink) Old 08-18-2019, 05:45 PM Thread Starter
Mustmatt's Avatar
Does anyone know if the standard bracket works with this or do we need to use a different bracket?
PA Performance 1704, 130amp 3G
Thank you!
Matt
Matt
Brea, CA
1965 Mustang Coupe 289 a/t Build Thread
1967 Firebird 400 4sp
1967 GTO 400 a/t
2015 Hyundai Santa Fe
Mustmatt is offline
post #2 of 9 (permalink) Old 08-18-2019, 05:59 PM
I seem to recall it fits the 95 amp no problem. For the 130 amp, lengthen the flat portion of the bracket by, I think, 3".
289vert is offline
post #3 of 9 (permalink) Old 08-18-2019, 08:17 PM
Here ya go.
289vert is offline
post #4 of 9 (permalink) Old 08-18-2019, 08:52 PM
Looking at that photo, that alternator body is the same size as the 95 amp body. I'm basing this on the 4 holes inside each of the 3 spokes in the casting. The larger body has 2 holes. This is assuming I'm remembering correctly back when I got my 3g.
65coupei6_2 likes this.
Rufus68 is offline
post #5 of 9 (permalink) Old 08-18-2019, 10:18 PM
Woodchuck's Avatar
I believe that's a "Large Case" unit. You should have got a #1619 which should be a direct bolt in. Here's a link to an eBay ad for the bigger unit that talks about the modifications needed....
https://www.ebay.com/itm/FORD-MUSTANG-ALTERNATOR-One-WIRE-3G-LARGE-CASE-65-66-70-72-75-79-89-93-HIGH-AMP-/362611074671
Bart
What, me worry?
- Alfred E. Neuman
Woodchuck is offline
post #6 of 9 (permalink) Old 08-18-2019, 11:16 PM
65coupei6_2's Avatar
Rufus68 is correct about the holes in the casting.
That is the small case which should fit with no bracket mods.
Here is a small case for reference:
https://www.ebay.com/itm/65-85-FORD-...53.m1438.l2649
...Marco
'65 Mustang Inline 200. CI Aliminum Head, Holley 350,
Schneider 264/274 cam, Headers, Recurved DSII, MSD 6A, and a whole lotta other stuff!
65coupei6_2 is offline
post #7 of 9 (permalink) Old 08-18-2019, 11:21 PM
Woodchuck's Avatar
If you Google the alternator he references you see it shows.........
Applications: 1994-1995 5.0L V8 and 1994-2000 3.8L V6
Bart
What, me worry?
- Alfred E. Neuman
post #8 of 9 (permalink) Old 08-18-2019, 11:30 PM
He posted a picture and a part number. I am saying that picture is a small case. The same answer as posted earlier about castings.
Best thing to do is call PA in the morning.
...Marco
post #9 of 9 (permalink) Old 08-19-2019, 03:34 AM
Both the small case 95A and the 130A large case, share a 7" bolt spacing. There's also a large case with an 8 1/4" bolt spacing, it would probably need the extension.
The pic of the black alt, is a 95A, but the part # is a 130A
289vert is offline
