Power steeling slack - Vintage Mustang Forums
post #1 of 8 (permalink) Old 08-23-2019, 10:03 AM Thread Starter
oscarnielsen's Avatar
Question Power steeling slack
Morning
Stock 66 2DHT. The power steering has about 2" of play on the steering wheel. The fluid is at the proper level and the system does not leak and performs great. Would this be considered normal for a system this old or should I look at having it rebuilt this winter. Your thoughts are appreciated.
oscarnielsen is offline
post #2 of 8 (permalink) Old 08-23-2019, 10:12 AM
GT289's Avatar
Depends upon the definition of steering "play."
Check out your system to see where the play is.....
Post #3 of this thread-
https://forums.vintage-mustang.com/v...ay-1968-a.html
Keep in mind you don't have a steering shaft coupler on a '66.
ex-Global West GM
1991-1995
- Douglas Adams
GT289 is online now
post #3 of 8 (permalink) Old 08-23-2019, 11:32 AM
myfirstcar66's Avatar
BE SAFE ! !
1) make sure tire pressure is 32 or more and equal
2) try it with engine off and later with engine running, have a friend move the steering wheel from side to side at the limits of the play & look to see the steering shaft is turning a corresponding amount at the bottom of the column tube just before the steering box, look for movement under the steering box at the pitman arm, and at each piece and connecting point under the car.
3) remember wheel bearings impact how the car responds to steering movements, too.
My 1st car...
'66 Tahoe Turquoise/ Aqua coupe
•289 / 4100 •C4 Auto •Disc Brakes
•Dual Exhaust •Quick Manual Steering
•Rally Pac •Console •Deluxe Belts
•LOTS of Rotunda accessories
Older son's 1st car...
'66 Emberglo / Parchment deluxe coupe
•289 / 2100 •C4 Auto
•Dealer A/C • Console
•Dual Exhaust • Power Steering
Younger son's 1st car...
'66 Nightmist / Blue & white deluxe coupe
•Factory A/C •Console
WAITING FOR RESTORATION
myfirstcar66 is offline
post #4 of 8 (permalink) Old 08-24-2019, 05:17 PM Thread Starter
Myfirst66car: wheel bearing never crossed my mine.
GT289: so to tight up the play at the steering box, I should screw down/in the steering screw. First loosen bolt holding screw in place than tight screw 1/4 turn?
post #5 of 8 (permalink) Old 08-24-2019, 08:43 PM
CHOCK's Avatar
Is this a all original, never been tampered with, system? Yes, including the steering box- Is it original, not rebuilt?
CHOCK is offline
post #6 of 8 (permalink) Old 08-24-2019, 10:04 PM
FrankieThe69Kid's Avatar
NEVER mess with the steering box while it's in the car. Any adjustments to that screw need to be done on a workbench with the box connected to nothing. You can leave the arm on the box. Much easier to disconnect it from the linkage than it is from the box, and you'll need it on there to center it before re-installing... at least, that's how I did mine.
69 Convertible, 351W, T5, E-Brock Performer 351-W intake, Performer Plus cam, Holley 4160, power assist, dual exhaust, 4-wheel manual drums.
FrankieThe69Kid is offline
post #7 of 8 (permalink) Old 08-25-2019, 11:28 AM Thread Starter
Wow
CHOCK Yes, i believe it is all original and never tampered with.
FrankieThe69Kid I helped a friend last year and he just loosen the nut while holding the screw in place and then tighten the screw about 1/2 turn and when tighten the nut. He stated this helped the vehicle's steering.
post #8 of 8 (permalink) Old 08-25-2019, 08:04 PM
CHOCK's Avatar
Wow
Just be very careful--VERY careful. When folks shoot in the dark, using no gauge--IN the car adjusting, the risk of overtightening is high. If your box is bound by improper adjusting, this can result in reciprocating ball be ejected into the case.
ONE ball out of the tunnels can land in between the rack and sector, lock up the box. If going around a curve at 60 you will hit the next thing in your path---Tree, semi, child, you will have no choice.
CHOCK is offline
