Need Help With 68 4-speed Shifter - Vintage Mustang Forums
post #1 of 12 (permalink) Old 08-25-2019, 04:05 PM Thread Starter
I bought the Scott Drake shifter lever repair kit with shoulder bolts. It came with no instructions and I’ve searched all over the interweb with no luck. I’m a bit of a newbie to ancient Mustangs. Would anyone have instructions or better yet, a picture or diagram of what to do with this kit?
Roadglider09 is offline
post #2 of 12 (permalink) Old 08-25-2019, 04:37 PM
NEFaurora's Avatar
Which SD kit??
Pics help greatly...
Otherwise, We could be guessing 'til hell freezes over..
Tony K.
Tony Kovar
1965 Mustang Convertible 200cid I6, 3spd Manual (Soon to be swapped for a '65 Date Coded C4!)
MCA#70001
Getting Ready for the 2020 Melbourne, FL MCA Nationals!
NEFaurora is offline
post #3 of 12 (permalink) Old 08-25-2019, 04:59 PM Thread Starter
This one...C5ZZ-7208-AK
File Type: jpg 6D01DC45-25C9-46CE-AFD1-1AF9695FF1E3_1566766700367.jpg (458.3 KB, 8 views)
post #4 of 12 (permalink) Old 08-25-2019, 05:52 PM Thread Starter
Here’s the part number.
File Type: jpg 51F09937-F4AB-4DEE-A87D-245F1083DEB7_1566769905388.jpg (390.9 KB, 2 views)
post #5 of 12 (permalink) Old 08-25-2019, 06:46 PM
Remove the upper shift boot and you will see the two hex heads of the shoulder bolts. All those parts go in the top part of the shifter.
Everybody has to start some place
Asm109 is offline
post #6 of 12 (permalink) Old 08-25-2019, 07:33 PM Thread Starter
So they all go in the holes that the shoulder bolts came out of?
post #7 of 12 (permalink) Old 08-25-2019, 07:53 PM
The cups and springs go in the side of the shifter to keep it firm and centered in its place. One spring goes inside the cup (with grease of course) on the right hand side of the chrome shift lever (which has the shift knob atop of it), and one spring fits in the other cup which goes on the left side of the shifter lever. The big washers (which are unique washers to the gear shifter, not regular washers) go under the hex-head shoulder bolts which attach the shifter to the base. Look at the Ford shop manual if you have one, for a good pic of the whole thing. And if you don't have a Ford shop manual yet, get one ASAP.
[/SIGPIC]67 Fastback GT -- original colour (Frost Turquoise), original 289 A code engine. Pic is of me and the Mustang taken in May of '67, with original F70-14 Wide Ovals. Same car is now restored to "as new" but 3 speed tranny swapped out for 4 speed back in the mid '80's, with tach dash, original Equalock rear, Koni's, Opentracker UCA, LCA, roller perches and idler arm, roller bearing pedal cluster, Cibie headlights, 4100 carb (old 4300 put in storage probably forever)
jfstang is offline
post #8 of 12 (permalink) Old 08-25-2019, 07:59 PM Thread Starter
Thanks. I’ll give it a try. Yes , I have a shop manual, but didn’t see a good pic of the shifter.
post #9 of 12 (permalink) Old 08-25-2019, 07:59 PM
IndyFive-O's Avatar
Originally Posted by Roadglider09 View Post
I bought the Scott Drake shifter lever repair kit with shoulder bolts. It came with no instructions and Iíve searched all over the interweb with no luck. Iím a bit of a newbie to ancient Mustangs. Would anyone have instructions or better yet, a picture or diagram of what to do with this kit?
This should help you. It's pretty easy to figure out when you get it apart.
http://www.mustangandfords.com/how-t...anual-shifter/
1967 Sports Sprint 289 Coupe
2007 GT/CS
IndyFive-O is offline
post #10 of 12 (permalink) Old 08-25-2019, 08:09 PM
Woodchuck's Avatar
Hope this helps!
Bart
What, me worry?
- Alfred E. Neuman
Woodchuck is offline
post #11 of 12 (permalink) Old 08-25-2019, 08:19 PM Thread Starter
That’s what I’m looking for. Thanks.
post #12 of 12 (permalink) Old 08-26-2019, 09:04 PM Thread Starter
Well hell, that was easy....
