Occasionally loose power steering - Vintage Mustang Forums
 7Likes
  • 2 Post By CHOCK
  • 1 Post By Nailbender
  • 1 Post By CHOCK
  • 1 Post By CHOCK
  • 1 Post By vegasloki
  • 1 Post By CHOCK
post #1 of 13 (permalink) Old 08-30-2019, 06:09 PM Thread Starter
Curious... Not everytime but occasionally when I lift the front of the car off the ground and simply cycle my steering wheel... Or if I cycle the steering wheel while on the ground without the engine running. The next time I start the car and go drive it, I won't have power steering for the first say minute to 5 minutes. Typically within about 5 minutes it kicks back in and starts working. I've figured out that if I simply start aggressively running the wheel back and forth while driving (slow safe speeds obviously) it'll usually kick back in after maybe 15-20 cycles. One time I was mid large clover leaf freeway on ramp in the midst of a steady turn and it kicked back in and took me deeper into the turn unexpectedly LOL Good wake up moment there!
But anyways, any idea what's potentially happening? Servo valve in the system gets stuck or something when I cycle the steering manually without the motor running? Is this just normal for that era of car or is it potentially signs of something heading towards the end of it's life?
'67 Mustang, power steering, nothing exotic or crazy going on with it...
Thanks,
Khris
'67 GT Coupe, 302, T5
sirhk100 is offline
post #2 of 13 (permalink) Old 08-30-2019, 06:29 PM
CHOCK's Avatar
Something is Screwed up!
It can be the valve, yes. Reaction valve?, stuck sleeve/ball stud/stop. etc.
Rear valve in pump.
What type of fluid are you using?
How old, miles is the system?
Woodchuck and myfirstcar66 like this.
CHOCK is offline
post #3 of 13 (permalink) Old 08-30-2019, 09:12 PM
myfirstcar66's Avatar
^^^ this guy has forgotten more about steering systems than I could ever learn. THE authority as far as I can tell.
My 1st car...
'66 Tahoe Turquoise/ Aqua coupe
•289 / 4100 •C4 Auto •Disc Brakes
•Dual Exhaust •Quick Manual Steering
•Rally Pac •Console •Deluxe Belts
•LOTS of Rotunda accessories
Older son's 1st car...
'66 Emberglo / Parchment deluxe coupe
•289 / 2100 •C4 Auto
•Dealer A/C • Console
•Dual Exhaust • Power Steering
Younger son's 1st car...
'66 Nightmist / Blue & white deluxe coupe
•Factory A/C •Console
WAITING FOR RESTORATION
myfirstcar66 is online now
post #4 of 13 (permalink) Old 09-03-2019, 02:54 PM Thread Starter
Rear valve in pump.
Nothing special fluid wise. Just off the shelf penzoil power steering fluid.
No clue on age of the system. I doubt it's original but it was on the car when I bought it. I've put roughly 10K on the car since I've owned it. But beyond that, it's a guess at best.
sirhk100 is offline
post #5 of 13 (permalink) Old 09-03-2019, 03:07 PM
Nailbender's Avatar
You must use type F transmission fluid with the stock PS setup!
sirhk100 likes this.
65 C Code hardtop from California still wearing it's original paint.
Roller 331, TW 170 heads, T-5z, FiTech EFI, FPA Headers, Arvinode exhaust, SoT Bilstien coilover front suspension, TJ on eBay 8" 3.40 Trac-Loc 3rd member. Mustang Steve 2008 GT bracketed 12.4" front disks
Nailbender is offline
post #6 of 13 (permalink) Old 09-03-2019, 04:19 PM
CHOCK's Avatar
Yes Sir, The best, highest priced fluid will kill a Ford Pump PDQ.
CHOCK is offline
post #7 of 13 (permalink) Old 09-04-2019, 05:17 PM Thread Starter
Lovely, now I learn this... Funny cause it's the same stuff I use in the steering system on my truck which is LIGHT years more expensive, strong, reliable and exotic! LOL
Figures that something as simple as the wrong fluid would kill the setup on a 50y/o pump system. I'll see about flushing it and getting it changed to see if by some chance that's what's causing this but other than that I NEVER have issues with the steering. It's only if I mess with it when the engine is off basically. And even then it's not every time... "Finicky" comes to mind! LOL
It's all still a million times simpler than my other specialty type of vehicle in the driveway at least
sirhk100 is offline
post #8 of 13 (permalink) Old 09-04-2019, 05:42 PM
CHOCK's Avatar
"When you mess with it without engine running"
--If you turn the steering without assist from the hydraulics, the FULL movement of the ball stud, brass bushing is achieved, way over movement with engine running.
(Engine running approx. 3/16 movement left or right).
If the brass bushing is worn, has ridges, is bent from ball stud excessive movement, sleeve bent (BIG ONE here) Bushing will STICK in the sleeve.
Just a thought.
Bottom line. If the system is a original, has not been rebuilt, I'm certain this could be the cause.
If the system has been addressed with new parts, then the problem is likely improper install--Yes another big one on why these don't work.
CHOCK is offline
post #9 of 13 (permalink) Old 09-04-2019, 05:54 PM
Not sure how similar the system might be ,but I've notice more than one breed of car (Older Ford Explorers the most) that when doing front end work on a lift and turning the suspension right and left to gain working room the power steering is full of air and has to be "worked" to regain power
2nd 66 is offline
post #10 of 13 (permalink) Old 09-06-2019, 12:08 PM Thread Starter
Just a thought.
Yeah, as far as I know I don't think anything on the system has been gone thru any year recently. I've owned the car probably 4 years now and I knew the previous owner and don't believe he ever did anything as far as the steering goes.
Am I right that you're the one on here that does full steering service/rebuilds? If so, would you mind shooting me a PM with cost to freshen up my whole system if I were to pull it and ship it your way? I don't plan to mess with it really soon, possibly this winter depending what average turn around time is. (I'm in Vegas so prime driving season LOL)
I thought about the air situation too but based on previous experience you usually can very obviously hear it working it's way thru the pump sounding like a disaster in the making as the pump whines and complains... I don't get the "sound" that I typically associate with air in the system like I used to hear on my old explorers or always make fun of my friends with older Rangers...
sirhk100 is offline
post #11 of 13 (permalink) Old 09-06-2019, 02:45 PM
vegasloki's Avatar
Yeah Kris Chock is you guy for steering on these cars. He’s still pretty analog best to give him a call. Many here will vouch. He did my box and I don’t normally send stuff out unless it needs a big time pro.
Classic Mustang Disc Brake Conversions and Power Steering
subpar63 likes this.
67 Hardtop, brought it back to a driver
http://desertratretro.com
vegasloki is offline
post #12 of 13 (permalink) Old 09-06-2019, 04:59 PM
CHOCK's Avatar
Be very glad to help with PS.
Yes, I'm old school. Telephone is my tool for communicating. No way I can one finger type the questions I need to ask to get a clear conscience of need .
CHOCK is offline
post #13 of 13 (permalink) Old 09-06-2019, 06:17 PM Thread Starter
Totally understand! I'll touch base with you here once I get my current garage project up and running. The steering still works fine as long as I don't screw with it without the motor running which is typically pretty easy to avoid obviously! But once I get in a position where I can justify having it down for a bit I'll touch base. Although, I'm dreading pulling that steering box! I've got the kind with the fixed shaft up thru the column so pulling it is kind of a pain. Wish it had a rag joint that's for sure!
Thanks for the link/contact Vegas
sirhk100 is offline
