Car hasn't ran for 20ish years...Drum Brakes? - Vintage Mustang Forums
 8Likes
post #1 of 20 (permalink) Old 09-06-2019, 06:31 PM Thread Starter
Good afternoon all.
A bit slow day at work, so just wanted to look into the next step.
This weekend, if all goes according to plan...I plan to fire up my mustang that has been sitting for nearly 20 years.
Next step? Should I work on the drum brakes? Should I invest in a drum rebuild kit, I see those going on cjponyparts for almost $300? Though thats almost half of a front disc brake conversion from Chocko.
Per my previous post, this car was pretty much a daily before being trapped in my moms garage for 20 years. The only reason it was stopped being used, is because my father passed away unexpectedly...so no one was able to care/maintain it. The odometer has 493,XXX on it...so it kinda shows that my dad did truly care for it.
Are there any youtube videos or guide that will help me just kinda make sure the drum brakes are in ok and working condition?
All is appreciated! thanks,
apalacpac is offline
post #2 of 20 (permalink) Old 09-06-2019, 06:39 PM
Turnall's Avatar
That may be a tougher task than expected if it's been sitting that long. I would try to get over that hurdle before worrying about what to do next, especially this weekend. It took me about 3 weeks to get one started that had been sitting 15 years...
Allen
Turnall is offline
post #3 of 20 (permalink) Old 09-06-2019, 06:44 PM Thread Starter
Allen
Word.
I've been working on that for the past 2- weeks.
I've squirted MMO into the spark plug holes, and eventually got the engine turning by the crankshaft...after about a week.
Changed Coolant and radiator hoses
Changed Oil and filter
Changed Fuel Filter
Bought new spark plugs
Dropped the oil pan and cleaned that out
Bought a new battery
All thats left is to pour in the new oil, prime the oil pump and hook up the battery. But yea...I'm hoping that should be enough. Just kinda wanted to get a overview of what to do with the brakes for this post?
Turnall likes this.
post #4 of 20 (permalink) Old 09-06-2019, 07:03 PM
Turnall's Avatar
If you're looking to upgrade to disc anyway, then Chock, Dan, is the man. My 66 GT had front disc brakes and I bought Chock's instead of trying to rebuild what I had...
Of course, it's more money, but to spend half of the cost to rebuild the drum brakes only to want disc later? I would splurge. After all, it's the most important part of the car, my opinion...
Allen
Israel and apalacpac like this.
Turnall is offline
post #5 of 20 (permalink) Old 09-06-2019, 08:32 PM
22GT's Avatar
If it was stored in a dry space where rust did not form all over everything, you could pull each drum, make sure the contact points on the plate are greased, as well as certain pivot points. Examine all the hoses for checking, and the lines for rust. Then install the drums, adjust the front bearings, and thoroughly bleed the brakes.
If there is any doubt about any line, hose, or cylinder, replace it.
kenash likes this.
Amateur restorer. Well, sometimes I have been paid for it. But not right now.
22GT is offline
post #6 of 20 (permalink) Old 09-06-2019, 09:14 PM
NEFaurora's Avatar
You can buy all the parts on Rockauto.com and and a lot cheaper probably than $300... and you can even pick what brands you want...
I get all of my Brake parts from Rockauto.com for the last 25 years...
Tony K.
Huskinhano likes this.
Tony Kovar
1965 Mustang Convertible 200cid I6, 3spd Manual (Soon to be swapped for a '65 Date Coded C4!)
MCA#70001
Getting Ready for the 2020 Melbourne, FL MCA Nationals!
NEFaurora is offline
post #7 of 20 (permalink) Old 09-06-2019, 09:26 PM
mikeyhunts's Avatar
I saw this today and it made me laugh...
Maybe it helps in your decision!!
BigKoppa, ophthos and Fitch like this.
mikeyhunts is offline
post #8 of 20 (permalink) Old Yesterday, 01:39 PM Thread Starter
Tony K.
This was kind of the answer I was looking for...Something to get my drum breaks up to par but not to cost heavy. Thanks I'll look into it!
post #9 of 20 (permalink) Old Yesterday, 01:49 PM
kenash's Avatar
Don't "buy, before you try". As 22GT stated, unless they were submerged, a thorough cleaning would be my first choice. Obviously, if the shoes are worn, they are cheap and easy to replace.
I'd focus on getting the engine starting and running smoothly.
It depends on your budget?
KenA..
64 1/2 Poppy Red Cvt. Resto-Mod
333 Cu.in. T5z, 3:55, Dual 40 mm DCOE Webers
Performer RPM, CI cam, TFS/TWs, Tri-Ys, Discs w/Shelby Drums
Severna Park, Maryland
kenash is offline
post #10 of 20 (permalink) Old Yesterday, 02:11 PM Thread Starter
Roger that. I'll do that, thank you!
Engine...Ugh I ordered the wrong oil pump prime tool. Correct one should be coming in today! So if all goes well...we will see.
Budget wise. Just trying to get it started and then moving/braking on a budget. Then from there assess what needs to be worked on.
post #11 of 20 (permalink) Old Yesterday, 02:14 PM
jdub's Avatar
If the wheel cylinders aren't visibly leaking; and the MC is functional and the lines aren't leaking it either (bleeding will show this), just drive it.
1965 Mustang
jdub is offline
post #12 of 20 (permalink) Old Yesterday, 02:18 PM
I'm thinking after 20 years of sitting, it's pretty much a given every wheel cylinder will leak. Guess it can't hurt to bleed the brake system and find out. It will cost only some time and brake fluid.
Currently working on a 1970 Mach 1 project. See it here: http://forums.vintage-mustang.com/vi...ode-build.html
Klutch is offline
post #13 of 20 (permalink) Old Yesterday, 02:48 PM
When I rebuilt the front drums on my 66 years ago I noticed small and big block cars used the same finned drum. Small blocks used a 2.25" wide shoe while big blocks used a 2.50" wide shoes from 67 & up. So I put the big block shoes on. They worked very well! I never had any brake fade that I noticed. When I switched to discs, I really didn't notice much if any improvement. A cheap drum upgrade that is effective.
Tom
One thing great about getting older. A life in prison sentence is less of a deterrence
Huskinhano is offline
post #14 of 20 (permalink) Old Yesterday, 02:56 PM Thread Starter
I've talked to some people and heard the same as well. They did mention that power brakes were worth it though. Maybe I'll stay with drums all around and go with a power brake conversion instead.
post #15 of 20 (permalink) Old Yesterday, 04:44 PM
66coupe289's Avatar
In 36 years I have maintained my rear drums but never found a need to "re-build" them. Other than shoes wearing, cylinders leaking and the adjuster rusting there is not much else to go bad. Granted, my car was from California, so not much rust. New shoes are about $30, new wheel cylinders are about $10/ea and adjusting screws are $5/ea at Rock Auto. Add in $5 for some brake fluid and you should be good to go for well under $100 for the rear brakes. That assumes drums are okay. Remember, use a flare wrench on the lines (well worth the money). A little MightyVac helps with the bleeding.
In order of priority I would go with a dual reservoir master cylinder before power brake booster.
Chris (Sussex, WI)
289 w/AFR 165, T-5z, 3.55T-loc, Granada Discs and 6 bolt Moto-Lita Steering Wheel
66coupe289 is offline
