Overheating issue finally SOLVED - Vintage Mustang Forums
 31Likes
post #1 of 24 (permalink) Old 09-07-2019, 02:49 AM Thread Starter
happystang's Avatar
Holy **** this has been driving me crazy. The 428 in my '68 fastback would always get hot only at idle and it was driving me insane. I tried literally everything and had just accepted that I need to keep the RPM's up at idle to prevent the temperatures from creeping up. It was only until I started researching pulleys for a power steering swap that I realized that there was an issue.
Turns out I had the wrong water pump pulley. The correct one is over an inch smaller in diameter. Now that the fan is spinning at the correct RPM at idle, my problem is solved!
IMG_1378.HEIC by armon7, on Flickr
1969 Convertible field find (450hp spaghetti noodle)
1968 Fastback (428 and a 4 speed)
www.SaveClassicCars.net
-Armon
happystang is online now
post #2 of 24 (permalink) Old 09-07-2019, 08:20 AM
I'm glad you fixed your issue. Perhaps it is because the water pump is spinning faster instead of the fan. Maybe it wasn't able to pump enough water with the larger (slower) pulley.
DonP and Quicksilver66 like this.
Rufus68 is offline
post #3 of 24 (permalink) Old 09-07-2019, 08:36 AM
kellysedars's Avatar
Interesting...I just posed a thread with a similar problem. You’re giving me something to think about. Mine’s a 289, but I wonder if pulley size could be a factor...
kellysedars is offline
post #4 of 24 (permalink) Old 09-07-2019, 08:58 AM
IndyFive-O's Avatar
That great that you reported back with the solution, most peeps with issues start a thread and you never hear how it turned out
I'm not sure if I have ever seen pulley size discussed on these overheating threads, nice job!
1967 Sports Sprint 289 Coupe
2007 GT/CS
IndyFive-O is offline
post #5 of 24 (permalink) Old 09-07-2019, 09:15 AM
mikeyhunts's Avatar
Good work figuring that one out.
Good learnings there for everyone.
Itís crazy when you have been chasing down this gremlin for a while and you feel like you have tried all the easy stuff so it MUST be something complicated!
Turns out it was a simple fix all along.
That crap will drive a person insane and frankly sometimes take some fun out of the hobby.
mikeyhunts is offline
post #6 of 24 (permalink) Old 09-07-2019, 09:37 AM
oscarnielsen's Avatar
You got to love this hobby and forum. Like IndyFive-O I appreciate the report on the solution to the issue. Well done and thanks for the info
oscarnielsen is offline
post #7 of 24 (permalink) Old 09-07-2019, 10:15 AM
GT289's Avatar
1" smaller in diameter is a lot faster in water pump rpm.....
Good catch. Wonder what the application was for the pulley you removed?
Can't quite make out that engineering number.
65coupei6_2 likes this.
- Douglas Adams
GT289 is online now
post #8 of 24 (permalink) Old 09-07-2019, 10:40 AM
coupster's Avatar
Iím feeling good about the cooling in my 390...finally. I, too had issues overtime. First I had a pin hole in a freeze plug. Then found the temporary rubber freeze plug was leaking, so I got lucky and tapped a metal freeze plug in the motor. Still was getting hot. Then I switched from brass to aluminum radiator. Still not quite right, but improved. Then I went with 7 blade BB fan and heavy duty clutch.(had a 6 blade n clutch) It ran cool, but would lose a little water overtime and get hot after a week of driving. I finally noticed that my stupid lever radiator cap was not fitting correctly on the Chinese aluminum radiator. It had a funky neck on it. Replaced the radiator cap and now itís humming along at 185-90* and constant, and Iím not losing any water. Next I need to install AC and see how cool it stays. This summer has been a thorough test as itís been hot as he** here in S.Texas. But if I can blast down highway, then get into traffic and the temps donít exceed 205 or so, I think Iím doing fine. Iím glad to hear you have yours resolved as well. I, too have pulleys that seem correct, but not 100% sure they are correct and matching. Can you post up the part numbers and sizes of you pulley arrangement? It would super helpful.
65 FB 289/3sp Rangoon Red/Red interior
68 Coupe 200/6 T-5 Diamond Blue/Blue interior
68 Coupe 302/C4 Black interior
69 Coupe 250/6 C4, Blue/Black interior
70 Coupe 390/C6 Auto Gold Metallic/Ginger interior
2010 Gold V6/Auto Sunset Gold/Black interior
65 Falcon Vintage Burgundy/Palomino interior
coupster is offline
post #9 of 24 (permalink) Old 09-07-2019, 11:44 AM
Don't forget that when you install the AC condenser, your best cooling will be with the gap between the condenser and the radiator around the edges sealed. This will keep the air flow through the radiator smooth. Leaving an open gap between them reduces the air flow through the radiator.
Rufus68 is offline
post #10 of 24 (permalink) Old 09-07-2019, 12:10 PM
GT289's Avatar
I hate cooling problems. Fortunately nothing Mustang-related for many years.
Dealing with these issues on my truck right now when an engine fan exploded on Monday....
- Douglas Adams
GT289 is online now
post #11 of 24 (permalink) Old 09-07-2019, 02:07 PM Thread Starter
happystang's Avatar
I think it's actually a case of the fan not spinning fast enough to move sufficient air at idle, although I'm sure the water pump turning slower didn't help either. I had an electric fan on the car for about 2 weeks that managed to prevent the car from overheating at idle until the fan(s) decided to seize up and leave me stranded.
Per Mustang Tek:
C8AE-8A528-B
Applications:
68 390 428 Ford Std., PS, XC
69 390 exc/PC Ford Std.
69 390GT Fairlane Std.& XC from_1/6/69
69 390GT Mustang std.&XC from_17-feb-69
71 390 Ford w/42amp
7 1/4" diameter
Overall depth : 2.40"
Ford Service Part Number ID C8AZ-8509-A
The replacement C6AE-8509-A pulley is 5.86" in diameter!
Holy crap!
1ofAMillion+ likes this.
-Armon
post #12 of 24 (permalink) Old 09-07-2019, 02:23 PM
That was a great catch on the wrong diameter pulley. I wouldn't have ever thought of that. I seem to recall under drive pulleys being all the thing for the 80's fox body cars to get moh powah out of them. Seems like they would be under turning the water pump and alternator at the least doing that.
roogie likes this.
65 2+2, 331, C4 presently apart for complete a restore
1979 Ford F150 custom, 302, C4, AC, tilt wheel, main transportation
macstang is online now
post #13 of 24 (permalink) Old 09-07-2019, 04:33 PM
Well done!
Tom
One thing great about getting older. A life in prison sentence is less of a deterrence
Huskinhano is offline
post #14 of 24 (permalink) Old 09-07-2019, 05:35 PM
When I got my car the belt setup was all screwed up. The crank pulley was only 2 groves and the belt for the Vintage Air was running off a third grove on the water pump. Very Rube Goldberg.
We put on a three grove crank pully, but never thought about the water pump pulley. Just went out in the garage and checked!! Mine is ~6 inches.
PS I've never had an overheating issue.
CJM68GT390 is offline
post #15 of 24 (permalink) Old 09-07-2019, 08:26 PM
I was wondering the same thing. I know a couple of my friends that had them and they would have to turn their headlights off at idle so the alternator would keep up.
Glad you got it fixed up HappyStang!
My first Mustang, 1965 hardtop, 200ci C4
My second Mustang, 1966 hardtop, 200ci 3spd
roogie is offline
