I6 to V8 Engine Swap - Page 4 - Vintage Mustang Forums
 16Likes
post #46 of 49 (permalink) Old 09-11-2019, 08:11 PM
Just some guy
GypsyR's Avatar
Actually I used Granada spindles on the '67 and grafted SN95 PBR calipers onto them. But anyway...
What, no definitive description of 7.25" rear end applications?
GypsyR is offline
post #47 of 49 (permalink) Old 09-11-2019, 08:21 PM Thread Starter
jaredlgoldman's Avatar
Here is some more information that might help
My current engine #
C6DE
6015-D
Ebay engine for sale
C5DE
6015-H
Does it matter if I have a manual or automatic transmission ? I have a 3 speed manual.
jaredlgoldman is offline
post #48 of 49 (permalink) Old 09-11-2019, 09:02 PM
Woodchuck's Avatar
My current engine #
C6DE
6015-D
C5DE
6015-H
Do NOT buy that engine without verifying your bellhousing pattern. That's an "early" 200 that only has the 8.5" bellhousing spacing. The later blocks (65-68) are drilled for both 8.5 & 9" spacing and the '69-79's only the 9" spacing. You want to be darn sure which bellhousing you have before pulling the trigger or you could end up with a real headache.
No, it doesn't matter if you have a manual or automatic transmission, other than either removing, or adding, a pilot bushing to the end of the crank prior to installing the clutch assembly.
Also, beware of early 200's (and 144/170 imposters) which are easy enough to spot if the head is off and you can measure the bore, but the early 200's had 5 main bearings vs. 7 mains in the later versions. They are easily ID'd as having only 3 freeze plugs down the side of the block vs. the later 200's which have 5 freeze plugs.
Bart
What, me worry?
- Alfred E. Neuman
Woodchuck is offline
post #49 of 49 (permalink) Old 09-11-2019, 09:02 PM
wicked93gs's Avatar
My current engine #
C6DE
6015-D
C5DE
6015-H
Not an expert on the engine codes, but I am assuming the C6DE means 66 and the C5DE means 65...and if I remember correctly the 66 block has dual transmission bolt patterns while the 65 only has one, I don't know offhand which bolt pattern the 3-speed MTX on a 66 I6 optioned car is though
https://www.moderndriveline.com/Tech...h_Match-up.htm
read this from the experts though....and check to see whether you have 2 holes exposed at the top of your block...and whether the ebay engine you are referencing does as well.
Woodchuck likes this.
wicked93gs is offline
