1967 289 w/AC San Jose correct heater hose Strip color? - Vintage Mustang Forums
post #1 of 6 (permalink) Old 09-10-2019, 04:02 PM Thread Starter
Nee to replace my heater hoses on my 67 289 san jose car with AC. Looking at parts suppliers I see black hoses, hoses with white stripes and red stripes.
What color strip do I need to be correct?
thanks
ddaytona1 is offline
post #2 of 6 (permalink) Old 09-10-2019, 04:28 PM
67gta289's Avatar
White or red stripes are acceptable. We made an attempt to determine patterns over on the CMF web site but failed to draw conclusions. Unrestored cars with documented original hoses are too scarce I’m afraid.
67 289 GTA Dec 20 1966 San Jose
67gta289 is offline
post #3 of 6 (permalink) Old 09-10-2019, 08:09 PM Thread Starter
Originally Posted by 67gta289 View Post
White or red stripes are acceptable. We made an attempt to determine patterns over on the CMF web site but failed to draw conclusions. Unrestored cars with documented original hoses are too scarce Iím afraid.
thanks White it is then.
Did the "S" hose from the heater control valve to the heater core have a stripe?
post #4 of 6 (permalink) Old 09-10-2019, 08:54 PM
NEFaurora's Avatar
'65-'66 A/C cars had either One White and One Yellow Stripe Hoses.....or Two Yellow Striped hoses....
I'm certainly no expert on '67-'68 cars, but I would check over on the "Concours-Mustang" website forum again anyway before buying or installing any hoses...just to be sure Just a tip..
"Unrestored cars with documented original hoses are too scarce I’m afraid."
I find it hard to believe that they could not find any Original '67 examples as even Original '65-'66 Examples still exist...(Unrestored Original cars)
ConcoursMustang Forums - Index
Tony K.
Tony Kovar
1965 Mustang Convertible 200cid I6, 3spd Manual (Soon to be swapped for a '65 Date Coded C4!)
MCA#70001
Getting Ready for the 2020 Melbourne, FL MCA Nationals!
NEFaurora is offline
post #5 of 6 (permalink) Old 09-10-2019, 09:12 PM
NEFaurora's Avatar
I did a search over at CMF... and found this below..
Found an answer to your question... right from Bob Gaines... MCA/Shelby/SAAC Judge....
Here is the best answer found concerning '67-'68 A/C Heater Hose Stripes....
"Go with the redish stripe hoses because it is more common but yellow would be the other possibility. A late car would typically be June or July right before shut down. "
Tony K.
Tony Kovar
MCA#70001
post #6 of 6 (permalink) Old 09-11-2019, 06:12 AM
67gta289's Avatar
Tony K.
Tony, that reference is taken from this post:
(from 2011) 67 390 W/AC Heater Hose Question?.
However, in the following post (from 2015) it appears that the take was early white stripes were predominant before March 67, after that red and yellow were introduced.
Heater hoses
The there is some conflicting thoughts between the two, especially with the reaffirmation of the 2011 post in 2017.
Since we don't know the build date of the OP referenced car, I would recommend that the OP read those two posts and then decide, or if needed, ask follow up questions.
To answer the OP regarding the "S" hose I don't recall seeing an answer to that one. I did a search and did not see it. I recommend that you consider joining that forum and posting the question!
67gta289 is offline
