Engine swap on a 67 Mustang Coupe I6 - Vintage Mustang Forums
post #1 of 6 (permalink) Old Today, 09:25 AM Thread Starter
jaredlgoldman's Avatar
I have been on the forums with engine trouble on my 67 coupe I6. I debated swapping out for a V8, but that is too big of a project right now for me. From the advice I have gotten, I have two choices, rebuild the engine I have to try to figure out the problems I am having, low compression on cylinder #3 and oil blow back or buy another I6 engine and drop it in.
After some research I found, what I think is a matching engine to drop in. It is only $350 and looks in good shape, form the outside. i know that does not mean much
I have a few questions ?
1. I have a 67 coupe I6 (engine #C6DE). The purchased engine is from a 65 Mustang (engine #C5DE). Will this fit with my 3 speed transmission ?
2. The purchased engine is out the car. The seller says it runs and is in good shape. What can I do to inspect the engine before I buy it ?
3. I read that there are two different bolt patterns for the 60's mustangs. 8.5" and 9". How do I confirm this and does it matter, can a converter be used
Attached are some pics of both engine.
The clean engine on the stand is the one I am looking to purchase
The other one, in the car is my engine with issues
Thanks in advance
File Type: png Screen Shot 2019-09-12 at 8.58.54 AM.png (1.16 MB, 3 views)
File Type: jpg Screen Shot 2019-09-12 at 8.58.40 AM.jpg (435.6 KB, 3 views)
File Type: png Screen Shot 2019-09-12 at 9.01.05 AM.png (1.30 MB, 3 views)
File Type: png Screen Shot 2019-09-12 at 9.01.33 AM.png (1,016.2 KB, 3 views)
File Type: png Screen Shot 2019-09-12 at 9.01.20 AM.png (1.47 MB, 3 views)
File Type: png Screen Shot 2019-09-12 at 9.00.58 AM.png (1.27 MB, 3 views)
File Type: png Screen Shot 2019-09-12 at 8.58.34 AM.png (1.14 MB, 3 views)
jaredlgoldman is online now
post #2 of 6 (permalink) Old Today, 10:57 AM
Woodchuck's Avatar
You're SOL. From the photo's I can see that you have the 9" spacing (the top bellhousing bolts are near the cylinder head parting line). The block you are thinking of purchasing is an 8.5" spacing. A pix below shows the "dual pattern" block, which you probably have in the car, and the location of the upper bolts. Your existing bellhousing will not fit and, most likely, neither will the flywheel and clutch assembly. While the motor you're looking at is a 7 main bearing block, it's also an early one with a road draught tube for crankcase ventilation instead of a PCV system and if it has never been rebuilt it's most likely full of sludge.
Bart
What, me worry?
- Alfred E. Neuman
Woodchuck is online now
post #3 of 6 (permalink) Old Today, 10:57 AM
wicked93gs's Avatar
Looking at the pictures, it does look like your block has the dual bolt pattern(try to get a pic of the back of yours) while the other one is the single bolt pattern. From the pictures it looks like your bellhousing uses the later bolt pattern...which means that earlier engine will NOT bolt up to your transmission(notice in the pictures of the 65 engine the bolt holes are several inches from the deck while your bell is bolted up right below the deck)...on a side note...your bellhousing WOULD bolt up to a v8. Too bad you aren't closer, then you could take my dual pattern I6 that came out of my car off my hands. One place you can try is search-tempest.com. Its a craigslist search engine that goes by distance...lets you easily search craigslist over the entire nation or just within x miles. Another thing to consider...you could always upgrade to a 250CI I6...not sure what is involved, but those engines are pretty common, being used in Ford trucks all the way into the 80s
Too bad you couldnt pick this up...its the holy grail for I6 guys:
https://www.ebay.com/itm/Ford-4-1-L-...QAAOSwblVddUKa
wicked93gs is online now
post #4 of 6 (permalink) Old Today, 11:23 AM
Woodchuck's Avatar
No, the bellhousing will NOT bolt up to a V8. It is only the very late sixes with the low-mount starter that have "2/3" of a small block bellhousing pattern. Also, 250's in trucks, other than the >'77 Bronco are relatively rare....most came with either the 240 or 300 "big" six.
Bart
What, me worry?
- Alfred E. Neuman
post #5 of 6 (permalink) Old Today, 11:33 AM
wicked93gs's Avatar
Ah, I stand corrected. The 250 did come in a variety of Ford cars into the early 70s at least though correct?
post #6 of 6 (permalink) Old Today, 12:01 PM
Woodchuck's Avatar
Typically compact and intermediates... Fairlane/Torino, Maverick/Comet, Granada/Monarch and Fox-bodies.
Bart
What, me worry?
- Alfred E. Neuman
