3-Speed Clutch Fork - Vintage Mustang Forums
 2Likes
  • 1 Post By IndyFive-O
  • 1 Post By Westmus
post #1 of 10 (permalink) Old 09-12-2019, 01:17 PM Thread Starter
Fitch's Avatar
3-Speed Clutch Fork
The clutch fork on my 66 3 speed has a hole worn in the cup that the release rod rides in and Im afraid it will wear all the way through before too long. Can the fork be replaced without removing the transmission ? If not, I think I'll just weld the backside of the cup where the hole has worn.
Cliff
1966 Blue Hardtop. 200 CID with 3 Speed Trans
Fitch is offline
post #2 of 10 (permalink) Old 09-13-2019, 01:31 PM Thread Starter
Fitch's Avatar
Anyone know?
Cliff
Fitch is offline
post #3 of 10 (permalink) Old 09-13-2019, 01:38 PM
Im thinking it would come out OK but never go back in. The TO bearing clips to the fork on mine.
Saying if you remove the linkage and get it off of the fulcrum and anti-rattle spring and monkey with it enough to pull it out the TO bearing would turn on the shaft and you'd never get it back together right. Thats the way I see it happening anyway.
Maybe weld, even if it was just JB weld, a concave slug inside the cup
Verbose Vocabularian
1ofAMillion+ is offline
post #4 of 10 (permalink) Old 09-13-2019, 02:41 PM
awhtx's Avatar
I believe the release arm is hardened and welding on it will remove the hardening. Replacing it without removing the transmission can be done but getting the 2 clips on the back of the TOB hooked onto the arm can be frustrating to say the least.
Perhaps you could find a release arm with a good cup and cut it out. Then place it inside the existing cup.
awhtx is offline
post #5 of 10 (permalink) Old 09-13-2019, 03:30 PM Thread Starter
Fitch's Avatar
Thanks guys! I think I will weld it up and hope it last until my next clutch replacement.
Cliff
Fitch is offline
post #6 of 10 (permalink) Old 09-13-2019, 05:20 PM
Is the amount of money you will save worth the effort of doing it again if it doesn't work?
oldpaint is offline
post #7 of 10 (permalink) Old 09-13-2019, 06:55 PM
IndyFive-O's Avatar
It's not about the money I don't think. The whole trans has to come out to replace that $30 part, I think welding it and buying time until the clutch needs replaced is good option. Worst case you pull the trans anyway and replace it if the weld doesn't work out.
Fitch likes this.
1967 Sports Sprint 289 Coupe
2007 GT/CS
IndyFive-O is offline
post #8 of 10 (permalink) Old 09-14-2019, 09:04 AM
Welding done right are strong and usually harder than the sheet metal thats being welded. Repro parts are not necessarily as good a quallity as the orignal Ford Parts, just because they are new and shiny. The asian factorys likes to use softer steel to sheet metal parts because it makes the tools used for manufacturing last longer, or they can be done with less powerful machines. They have less focus on the durability of the parts, than they have on manufacturing the parts as cheap as absolutly possible. Ford also wanted cheap parts, but they also got all the problems it the parts they used didn't last or worked correctly.
Fitch likes this.
Westmus is online now
post #9 of 10 (permalink) Old 09-14-2019, 09:23 AM Thread Starter
Fitch's Avatar
Exactly! Like you said, worst case, I pull the trans to replace the clutch anyway. I dont know the history of this clutch, how old it is, how hard it was used. For all I know, its at the end of its life anyway although, it works fine now with the exception of a slight shutter on take-off.
Cliff
Fitch is offline
post #10 of 10 (permalink) Old 09-14-2019, 10:50 AM
I'd either weld it up until it's clutch time and then find a good used or NOS one. Alternatively, maybe you could weld/JBWeld something like a 4 speed shifter trunnion or something similar, which will accept the release rod and then adjust accordingly?
[/SIGPIC]67 Fastback GT -- original colour (Frost Turquoise), original 289 A code engine. Pic is of me and the Mustang taken in May of '67, with original F70-14 Wide Ovals. Same car is now restored to "as new" but 3 speed tranny swapped out for 4 speed back in the mid '80's, with tach dash, original Equalock rear, Koni's, Opentracker UCA, LCA, roller perches and idler arm, roller bearing pedal cluster, Cibie headlights, 4100 carb (old 4300 put in storage probably forever)
jfstang is offline
