1966 mustang power brake booster install - Vintage Mustang Forums
 5Likes
post #1 of 17 (permalink) Old 09-18-2019, 08:53 PM Thread Starter
shelby1969's Avatar
Anyone added a power brake booster with dual bowl master cylinder to 66 mustang cylinder automatic and kept your stock drum brakes up front ? any issues with doing that ? what parts supplier did you use for the booster ?
shelby1969 is offline
post #2 of 17 (permalink) Old 09-18-2019, 08:56 PM
Seems like we talk about this every week. Is there a particular reason you feel you need or want a power brake booster in your car? There are probably several here that have done it. There are probably just as many that have tried it and removed it. A brake booster is not going to make your car stop any better. Itís only going to reduce pedal effort.
patrickstapler is offline
post #3 of 17 (permalink) Old 09-18-2019, 09:06 PM
awhtx's Avatar
If the OP is thinking that the booster will improve the performance of his drum brakes he is in for a big lesson in brake performance after he completes the booster installation and finds his car doesn't stop any better than it did before.
rpm likes this.
awhtx is offline
post #4 of 17 (permalink) Old 09-19-2019, 08:31 PM Thread Starter
shelby1969's Avatar
Really only want to change because of the single bowl master cylinder , it anything ever goes wrong , all the brakes will fail .Want to go with the dual bowl master cylinder , mainly for safty reasons. Thanks.
post #5 of 17 (permalink) Old 09-19-2019, 08:45 PM
ophthos's Avatar
So I asked the same question a while back and despite numerous people around here saying I didn't need it, I thought that my poor braking would be helped by a booster. I put the booster on and the car still didn't stop great, I just didn't have to put as much pressure on the pedal to get the same affect. Turns out my rear drums needed to be replaced. Now the car stops great with just a slight tap on the pedal. It's a little too easy for me. I'm gonna pull mine off and go back to non powered brakes. I liked the "feel" of the prior system I had.
I'm pretty new to this classic car thing, but trust me, there is tons of knowledge in here. Listen to what they all say........you don't need a booster. You just need well adjusted brakes.
I would consider a dual bowl master cylinder specific for manual drum brakes. Just for the safety aspect.
rpm and Thegundog like this.
66 Convertible, GT clone. 289 4V, C4. Springtime yellow with black top
ophthos is offline
post #6 of 17 (permalink) Old 09-19-2019, 09:25 PM
post #7 of 17 (permalink) Old 09-20-2019, 10:32 PM Thread Starter
shelby1969's Avatar
I have a new question - If instead i upgrade to front power disc brakes with booster and dual bowl master cylinder , is there anyone that makes a disc brake conversion kit that will let me use my original steel wheels on my 1966 6 cylinder ?. I would like to keep my stock hubcaps . I looked at several suppliers and dont see anyone that offers that.
post #8 of 17 (permalink) Old 09-21-2019, 05:47 AM
awhtx's Avatar
awhtx is offline
post #9 of 17 (permalink) Old 09-21-2019, 08:50 AM
RayTada's Avatar
Did you look at ChockoStang website. He is a member here and you can look up feedback from other members.
Classic Mustang Disc Brake Conversions and Power Steering
66 Mustang Convertible
RayTada is offline
post #10 of 17 (permalink) Old 09-21-2019, 08:48 PM
ophthos's Avatar
I just took my booster off tonight. Just need to bend some new lines and I'll let you know the difference. I have disks front and drums rear. If you are still really dying for a power booster, I might sell you mine cheap. Got it from NPD. Bolts right up to a dual bowl MC and has the pedal adapter that changes the fulcrum to make it correct for power brakes. Find a vacuum source and run some new lines and you're good to go............but remember, some very smart people around here are telling you you don't need the booster.
I'll post over the next couple of days what I think of the braking with and without the booster.
ophthos is offline
post #11 of 17 (permalink) Old 09-21-2019, 09:11 PM
CHOCK's Avatar
OP Might want to listen to this message.
rpm likes this.
CHOCK is offline
post #12 of 17 (permalink) Old 09-21-2019, 11:37 PM
@ophthos made a great comment on making sure everything is working correctly first
Huskinhano is offline
post #13 of 17 (permalink) Old 09-22-2019, 12:37 AM
bmcgc's Avatar
My 65 is disc/drum. No need for a booster, if there was a need, I would put it on.
My 67 is drum/drum with a booster. The booster needs to be rebuilt so I would remove it except on a 67 manual and power brakes use a different pedal.
Spend your money on a disc upgrade, rebuild the rear drum brakes and a dual master.
The dual master is a nice upgrade, but your car has made it 50+ years on the single.
Learn to use the emergency brake as your backup if you loose brakes, thats how it was done for many many years.
1965 Mustang Coupe 289/C4
1967 Mustang Coupe 200/C4
2017 Mustang EB Premium
bmcgc is offline
post #14 of 17 (permalink) Old 09-25-2019, 10:12 AM Thread Starter
shelby1969's Avatar
Ok. Great feedback from everyone. Thanks
post #15 of 17 (permalink) Old 09-25-2019, 10:28 AM
GT289's Avatar
Friction material. Get some good pads/shoes...... not the chain store crap.
Big difference.
One of my close friends has a shop and has done that scarebird front disc
kit a couple of times so that the original rims could be maintained.
1) the bracketry is pretty wimpy, he copies the originals but fabs thicker brackets
2) mishmash of caliper and rotors are used..... some folks don't care, some do.
The mechanic 5 years down the road will wonder what's on there though.
ex-Global West GM
1991-1995
- Douglas Adams
GT289 is offline
