what's diff between starters for auto/manual trans - Vintage Mustang Forums
 5Likes
post #1 of 24 (permalink) Old 03-12-2007, 10:38 AM Thread Starter
manyc's Avatar
I think I have the wrong starter for my 69 w/C4 trans. The partnumber (C7-#####-F) on the starter I have tells me that it went on a car with a manual trans, but I need one for a C4. Its never been installed on my car before so I'm not usre if it will work. How can I tell the difference between a starter from a manual transmission and an automatic transmission ? pics might help.
"If I can't fix it, I'll fix it so no one can !"
1969 Mustang LE600 Sportsroof - Groovy Green
1969 Mustang LE600 Coupe - Flower Power Red
1969 Mustang Sportsroof - Dark Jade
1969 Firebird 350 Conv - Mayfair Maze
1968 Cougar Hertz XR7-G (project)
1959 Oldsmobile Super 88
1963 Jaguar XKE Coupe (project)
[url=http://www.relicrecyclery.com/groovygreen/groovygreen.htm]
[url=http://www.relicrecyclery.com/]
manyc is offline
post #2 of 24 (permalink) Old 03-12-2007, 11:51 AM
Cruzer's Avatar
If I recall correctly I've used both starters on my toploader. I'm sure someone will know for sure, I just can't remember if they are the same or not.
"Senior moment"
Cruzer is offline
post #3 of 24 (permalink) Old 03-12-2007, 12:12 PM
Marc4d's Avatar
IIRC? You can use a automatic starter in a manual trans but you cant use a manual one in a automatic trans because the nose is longer.
Hopefully someone will chime in and let us know if im correct about this cause its been awhile and kinda curious as well.
Tore up from the floor up!lol
Marc4d is offline
post #4 of 24 (permalink) Old 03-12-2007, 01:00 PM
The starter gear offset is the difference (amount the gear protrudes from the mounting flange).
Automatics are 3/4"
Manual (except T5) are 3/8"
The hole that the nose sticks into in the block plate is also sized differently.
Auto = 4.09"
Manual = 4.14"
I just finished making a 3/8" thick adapter/spacer to alow the use of an auto starter on a 4spd, but you can't do it the other way around to my knowledge.
Huskinhano likes this.
87BOSS351C is offline
post #5 of 24 (permalink) Old 03-12-2007, 02:14 PM
JohnZ's Avatar
IIRC there is or was a screw up in the auto-part store computers that caused people to get the wrong starter at times.
Bought Deja Blue from Stef Roberts.
http://johnz.mustangsandmore.ws/
JohnZ is offline
post #6 of 24 (permalink) Old 03-12-2007, 06:28 PM
Midlife's Avatar
You can't fit a real automatic starter in a manual; it won't go in far enough. Most of the parts catalogs have the auto and manual starters reversed. How do I know? I went to a manufacturer of starters, and got both versions. The "automatic" fit my manual car, but the "manual" did not. I returned the one unit that did not fit. The part number that did work was 3153 from Precision CeriPro Warehouse in Chantilla, VA. Autozone lists the manual version as 3152.
'Electrical Guru: Let me Check Your Shorts! Ooops...that didn't turn out right.
http://midlifeharness.com
Midlife is offline
post #7 of 24 (permalink) Old 03-12-2007, 07:48 PM
wayne50f1's Avatar
i removed a 1965 c4 and bell,installed a late model manual bell and new t5z manual 5 speed and reused my old c4 starter , without any problems.
so the later model bell is deeper , at that starter area , than old manual bell....
i ***-u-me ?
[url= http://home.rr.com/wayne50f1 [/url]
1965 C4 to T5 Swap parts list on my web page
[color:red]1965 289 T5z powerdisc Caspian Blue[/color]
[color:red]2006 S197 GT 5 speed Vista Blue[/color]
wayne50f1 is offline
post #8 of 24 (permalink) Old 03-12-2007, 08:44 PM
Cruzer's Avatar
i think that was my case. So maybe it wasn't a "senior moment"
Cruzer is offline
post #9 of 24 (permalink) Old 03-12-2007, 09:53 PM
Midlife's Avatar
i ***-u-me ?
The T5Z manual and flywheel may have been the difference...
Midlife is offline
post #10 of 24 (permalink) Old 03-13-2007, 09:13 AM
ISLANDER's Avatar
I used the same starter from my original 3 Speed for the C4 and eventually for the T5 and never had a problem.
68'COUPE
5.0 FI
T-5
9" 3.25 TRACLOCK
Dakota digital
Magnaflow stainless, Heidts M2 front end, Flamming river tilt
ISLANDER is offline
post #11 of 24 (permalink) Old 11-21-2018, 07:06 PM
69GT350H's Avatar
This might clear things up a bit.
https://static.speedwaymotors.com/im...f/91067433.pdf
VMF Build Thread - 1969 Shelby GT350 Hertz rebuild Gallery
Used by Hertz for the 1969 "Rent-A-Racer" program at Miami Internation Airport.
69GT350H is online now
post #12 of 24 (permalink) Old 11-21-2018, 07:20 PM
PonyDoc's Avatar
Talking Starters
And here I always thought I had it backwards. When I had my shop, we got starters from Bennett Auto. We had to order the opposite for every starter, so now I know it wasn't just us with this problem!
64 9/10 Convertible- 400,000 miles & counting (2nd owner)- Invited by Ford to SEMA-2014 Pony Drive Pace Car
57 Thunderbird- E-Bird 312 w/ 2 4bbl carbs. 3 speed w/ O/D
65 GT Convertible
65 K GT Fastback- 60,000 original miles
Original 65 pedal car
69 GT Convertible- 90,000 miles Invited by Ford to SEMA-2014
69 Grande'- 1 of 11 on colors- 1 of 1 w/ options
2016 GT convertible w/ CDC Outlaw #13 package- delivered 10/27.
08 P-71 Police Intercepter
2000 F-250 Lariat, 2010 F-250 King Ranch
PonyDoc is offline
post #13 of 24 (permalink) Old 11-21-2018, 08:06 PM
This is still true, but it applies to 65 Mustangs. Two different flywheels were used on 4 speed cars in 65. Some use the starter listed for Manuals, some use the starter listed for Automatics.
Flade
68 289 convertible Candy-apple red & white
66 200 coupe Blue
94 GT convertible Red & black
98 GT convertible White & black
98 V6 convertible White & tan
Flade is offline
post #14 of 24 (permalink) Old 11-21-2018, 08:12 PM
Just some guy
GypsyR's Avatar
Wow, what an old thread. Wasn't there a recent one about starters? IE, not from 11 years ago?
GypsyR is offline
post #15 of 24 (permalink) Old 11-21-2018, 08:26 PM
awhtx's Avatar
Holy thread revival Batman! An 11 year old thread revived today.
Here's the answer, plain and simple.
If you have a 157T flywheel or 157T flexplate you need the so called "automatic" starter with the long snout and exposed drive gear.
If you have a 164T flywheel or 164T flexplate you need the so called "manual" starter with the short snout and the recessed drive gear.
There used to be a diagram with the difference in the location of the ring gear between the 2 different tooth count flywheels/flexplates explained on a Bronco forum.
When is this website going to have "stickies" so we don't have to explain this every time the question comes up.
Here it is. I hope it shows up.
https://imgur.com/a/BurQ2
awhtx is offline
