Oil pressure gauge works intermittently. - Vintage Mustang Forums
post #1 of 4 (permalink) Old 03-20-2016, 06:44 PM Thread Starter
MedievaL's Avatar
65 GT style gauges. I accidentally shorted the IVR a few weeks ago. Decided to try my hand at making one. Gauges worked fine at first but the oil pressure gauge started working intermittently and eventually quit working. Went back to a repop Ford style IVR, replaced the gauge and sending unit. The new gauge worked for about 10 minutes and quit. The other gauges seem to be working but the temp gauge seems to be moving around quite a bit and I dont trust it at this point. The ground for the instruments seems fine. I'm out of ideas.
1965 Mustang Coupe
5.0/4v, T-5z 5 Speed, 3.25 Traction Lock
Web Site
MedievaL is offline
post #2 of 4 (permalink) Old 03-20-2016, 09:16 PM
Rebel Racing's Avatar
Few yr. back I chased a similar problem with the oil press gauge. All tests said the gauge was fine. Went to a solid state IVR from Ebay and still no better gauge action. As a last ditch effort I bought a new gauge and all has been fine ever since. YMMV.
Rebel Racing is offline
post #3 of 4 (permalink) Old 03-21-2016, 01:39 PM Thread Starter
MedievaL's Avatar
I replaced the gauge, sending unit, and IVR.
1965 Mustang Coupe
Web Site
MedievaL is offline
post #4 of 4 (permalink) Old 03-21-2016, 08:27 PM
Paul1958's Avatar
You still could have a bad component in there. Ans since you had a short you could have damaged a wire which can cause all kinds of intermittent issues.
Ford gauge circuits were not not rocket science. The gauges operate on ~5VDC produced by the stock IVR 'pulsing' between 0 and battery voltage. The oil, temp, and fuel senders basically are all are variable resistors that go from 10 ohms (High OP/Temp/Fuel) to 73 ohms (Low OP/Temp/Fuel). The guages are fed 5V from the IVR on one side and are connected to their variable resistance senders on the other. The gauges are not -and should not be- grounded but the IVR must be well grounded to operate. If the IVR is bad then ALL gauges will have problems. If only one gauge is having issues (or, conversely, only one gauge is operating normally) the problem is NOT the IVR.
Paul
Okay. Engine Stop. ACA out of Detent. Mode Control, both Auto. Descent Engine Command Override, Off. Engine Arm, Off. 413 is in.
-Buzz Aldrin, Apollo 11 LMP
Actual first words from the surface of the moon
Early Fox: 5.0L HO SEFI conversion, 5-speed, 8.8 w/3.27:1 TL, full dual exhaust
1968 coupe - Ordered 12.15.67 Delivered 2.1.68: 8T01T, 65C, 289 conversion, hanger queen
Paul1958 is offline
