Any idea why door glass slides down when cranked all the way up? - Vintage Mustang Forums
post #1 of 9 (permalink) Old 05-03-2016, 12:04 AM Thread Starter
The driver side window of my 71 Mustang falls down ever so slightly whenever I crank the window all the way up. It's extremely frustrating. Any ideas why where to start? Should I just replace the entire manual window regulator? I want to shy away from this at first because the clearances in the door may be really difficult to work with.
neurotoxin312 is offline
post #2 of 9 (permalink) Old 05-03-2016, 12:08 AM
PetesPonies
Posts: n/a
Yes, replace the regulator.
post #3 of 9 (permalink) Old 05-03-2016, 07:12 AM Thread Starter
Any experience using this guy?
Dorman 752-118 Ford Mustang Front Driver Side Manual Window Regulator
Or would I be better off getting a used OEM regulator?
post #4 of 9 (permalink) Old 05-03-2016, 01:26 PM
Crash's Avatar
You probably don't need a new regulator. The problem is likely with the clutch in the regulator. The original grease in there dries up and renders the clutch non-functional.
You can do a search for posts I made about this a few years back. The clutch can be removed, cleaned, relubed, and reassembled for like new performance. It's not hard, but you must be careful with that big spring.
Like I said in those posts, it would be great if we could purchase just the clutch, or even the bushings in them that wear out. Repop regulators have a reputation for being flimsy compared to originals.
PJ
Formerly known as Bashed68.
Resto-modded '68 convertible.
Crash is offline
post #5 of 9 (permalink) Old 05-03-2016, 01:57 PM
Paul1958's Avatar
Sounds like the OP has manual windows - here is a pic of the window regulator:
I thought the pinion gear on the end of the crank shaft is in direct contact with the [partial] ring gear on the regulator arm (like earlier year Mustangs Im familiar with). The pinion shaft is supported by a bearing under the little cover that is riveted on. What is this 'clutch' you speak of?
I would think if the OPs regulator is 'slipping' allowing the window to drop a bit then the pinion and/or ring gear teeth are worn which allows 'backlash' (clearance) which allows the window to move (drop).
Paul
Okay. Engine Stop. ACA out of Detent. Mode Control, both Auto. Descent Engine Command Override, Off. Engine Arm, Off. 413 is in.
-Buzz Aldrin, Apollo 11 LMP
Actual first words from the surface of the moon
Early Fox: 5.0L HO SEFI conversion, 5-speed, 8.8 w/3.27:1 TL, full dual exhaust
1968 coupe - Ordered 12.15.67 Delivered 2.1.68: 8T01T, 65C, 289 conversion, hanger queen
Paul1958 is offline
post #6 of 9 (permalink) Old 06-02-2016, 01:48 PM
Crash's Avatar
Paul
The clutch is that brass-colored thingy in your picture where the crank shaft comes out. Remove the large spring on the regulator, then the three rivets attaching the clutch. It comes apart after that. I used small, thin-headed screws to reattach the clutch. There's not enough room for an ordinary screw head. Pop rivets would probably work, but I didn't have such.
PJ
Crash is offline
post #7 of 9 (permalink) Old 06-02-2016, 02:11 PM
Paul1958's Avatar
I believe that is the bearing retainer/housing. There should be no serviceable parts under there. What is this 'clutch' you speak of? Please explain or show pics.
Paul
Paul1958 is offline
post #8 of 9 (permalink) Old 06-02-2016, 02:20 PM
Blues Power's Avatar
arent they bolted in for 71's
maybe the mounts are just loose
1970 Mach 1 San Jose built Dec 23 1969. Marti 1 of 7. Purchased in 1987. Original family owner of the power train
351C 2v FMX.
1993 GT 13,000 miles, Built 2-12-93 Bought 8/3/93 Auto, 3:27 Axle, cloth, sunroof, AC. Unmolested all original car. Purchased new 8-3-93. still has the factory windshield fluid.
Blues Power is offline
post #9 of 9 (permalink) Old 06-02-2016, 02:36 PM
Under the cover is a wrap spring clutch. Sorta the rotary equivalent of the Chinese finger torture toy I had as a kid. Push finger in easy, pull out not so much.
Pushing down on the window causes the wrap clutch to self lock and prevent the window from going down. If it weren't there a pry bar could force the windows down on any car. When it gets worn it cannot lock up anymore.
Asm109 is offline
