Not Enough Adjustment In Upper Control Arms - Page 3 - Vintage Mustang Forums
 18Likes
post #31 of 32 (permalink) Old 02-22-2019, 10:32 PM
Originally Posted by duoz View Post
The whole suspension is brand new. Literally everything. It has about 40 miles on it. I will look into those parts I eventually wanted to upgrade anyway.
New member here and just followed down this thread. I know it's been 2.5 years but what was the final outcome?
Nate D.
WIP - 65 FB T-code:
331 (302 Mexico block) with main girdle
Canfield 192 heads Pro Magnum roller rockers
Comp Cams retro roller 224/230 112
Torker 289 Single Plane w/ Holley 600 DP
Hooker long tube headers
Fidanza aluminum flywheel
Toploader 4-speed WR
Front disc KH 4 piston
Rear 1958 Edsel 9" w/ 3.50 traction loc
Shelby mods for track use.
Acapulco Blue w/ Wimbledon White stripes
331N8 is offline
post #32 of 32 (permalink) Old 02-23-2019, 12:10 AM
Ponyboy's Avatar
I don't have it with me at the moment. I can post that later. I don't have any shims in the upper arms. They are bolted right to the tower. I want to run specs from opentracker, but they could not be achieved with the current set up. I don't know if they are cheap reproduction arms or if something else it wrong. All the supports and cross bars in the engine compartment fit perfect so I don't think something is bent.
Interesting. I have stock arms (15 years old) and I have shims under the arms. If I remember right, I was running +5 caster and -1 camber my first year at the track. I remember one bolt was tight to the frame and the other had shims.
66 coupe, '93 Fox seats, Three point belts, 289, Edelbrock, Weiand, JBA tri-y's, 2" duel exhaust (H-pipe), T5 trans(3.35), Pro 5.0 shifter, 3.40 open, KH front disc, Porterfield R4-S pads, 1" front sway bar, Shelby drop, Spring perch relocation, Shelby quick steer, GT progressive coils (1/2 coil cut), 4.5 leaf mid-eye, Bilstein street shocks, Export brace, Monti-Carlo bar, Sub-frame connectors, Performance alignment (+3.5 caster/-.5 camber), 16x7 wheels, 215/55/16 & 225/55/16 BFG G-force
Ponyboy is offline
