Bilsteins front shock help! - Vintage Mustang Forums
 5Likes
  • 1 Post By ToddMcF2002
  • 3 Post By Woodchuck
  • 1 Post By Huskinhano
post #1 of 11 (permalink) Old 08-03-2016, 08:06 PM Thread Starter
Hi all trying to install front shocks on '69. Have Bilstein street shock. Car on jack stands. I cannot pull these shocks down to install them! They will not move! Any suggestion would be welcome.
rayhicks1969 is offline
post #2 of 11 (permalink) Old 08-03-2016, 08:09 PM
GearHeadPeter's Avatar
So do you have all the bolts out for the top and bottom? Once the bolts are out the shock should just drop out, but you could use a small pry bar on the bottom if it is stuck.
US NAVY VET - 65 Custom Fastback GT-A-code. FiTech EFI w/Tanks Inc. w/Aero 340 LPH pump, TCP Power R&P; Full front coil over conversion w/1" Shelby drop; TMI Sport R custom interior; T5z TKO, Speed Hut custom speedo; Autometer Phantom gauges; SSBC Force 10 -13" disc brakes w/10.5" rear disc brakes; 24" Griffin Radiator w/twin 11" 2800 CFM fans; Classic Auto Air AC; Truck-Lite 7" LED headlights; Mustang Project Shelby LED sequential taillights. 2001 Bullitt rims w/Nitto NT555 235x45x17 tires.
GearHeadPeter is offline
post #3 of 11 (permalink) Old 08-03-2016, 08:13 PM Thread Starter
I am trying to install them, not remove.
post #4 of 11 (permalink) Old 08-03-2016, 08:20 PM
Sorry. Can you pull out the rod as far as it will go, put it in, and attach the top nut first? The bottom will hang below the mounting plate and you then should be able to push up the bottom of the shock.
post #5 of 11 (permalink) Old 08-03-2016, 08:20 PM
ToddMcF2002's Avatar
Loosely bolt the bottom and literally lift the car off the jack stand on that corner by the LCA. These f*ckers are short. Forget trying to bolt the top first. I did this just yesterday on my 65. Even then I had to use screwdriver handles to force the shock onto the top shock mount. Not fun.
Caper50 likes this.
1965 Mustang Fastback T5/302 Ivy Green
1982 Mustang GT Hatchback
1984 Mustang Predator GT302H
1957 Chevy Bel Air 4 speed
ToddMcF2002 is offline
post #6 of 11 (permalink) Old 08-03-2016, 08:21 PM Thread Starter
I can not pull out the rod AT ALL. It will not move.
post #7 of 11 (permalink) Old 08-03-2016, 08:26 PM
Have you tried spraying the rod with WD40 as it should move easily? If still nothing try calling the place you bought them or Bilstien and ask them HTF do you get the rod to move. I don't remember them being this difficult when I put them out my 69 Mach1 years ago.
post #8 of 11 (permalink) Old 08-03-2016, 08:29 PM
post #9 of 11 (permalink) Old 08-03-2016, 08:34 PM
Woodchuck's Avatar
Bolt in the bottom. Lower the car to the ground. Hook up the top.
Huskinhano, Caper50 and 2nd 66 like this.
Bart
What, me worry?
- Alfred E. Neuman
Woodchuck is online now
post #10 of 11 (permalink) Old 08-03-2016, 08:34 PM Thread Starter
THX Todd!
post #11 of 11 (permalink) Old 08-03-2016, 09:39 PM
The problem is there is more suspension travel then shock travel on these cars. Do as bartl said.
Caper50 likes this.
Tom
One thing great about getting older. A life in prison sentence is less of a deterrence
Huskinhano is offline
