Just about to Purchase this Tire/Wheel Package, can you help please? - Vintage Mustang Forums
 7Likes
  • 1 Post By patrickstapler
  • 1 Post By NEFaurora
  • 1 Post By blueovalfan68
  • 1 Post By Ptool2000
  • 3 Post By jakeinarkansas
post #1 of 10 (permalink) Old 06-18-2019, 01:56 AM Thread Starter
Hello,
After 6 months of back and forth I'm ready to purchase some wheels I have been wanting. Torq Thrust II 17inch Polished Aluminum. For basics, I have a 1968 289C Mustang with Drum brakes, all stock and nothing has been done with the springs or coils that I'm aware of. I want the tires to be flush with wheel wells so they don't stick out but I have no idea about what offset is or if the tires I want will work.
Here is what I want to purchase, 17x7 0mm offset. the only other option on tirerack is a 17x8 with a -11mm offset
https://www.tirerack.com/wheels/Whee...kageFlow=false
Planning to put on Raptor ZR A/S 225/45ZR17
https://www.tirerack.com/tires/tires...cleSearch=true
I have heard from several people these will fit and there shouldn't be a problem. Tirerack has a great return policy if they don't fit and I'm going or planning o having a local car shop install them for me, they have done some work on my mustang before. I'm returning from my deployment in 10 days and I'm trying to order these and have them installed on my mustang before I return.
Will these work?
Jacob
jakeinarkansas is offline
post #2 of 10 (permalink) Old 06-18-2019, 06:28 PM
Most people have really good fitment with 17x8 with 4.75” backspacing. Those appear to be 4”BS.
2nd 66 likes this.
patrickstapler is offline
post #3 of 10 (permalink) Old 06-18-2019, 07:36 PM
As Patrick said 17x8x4.75 Is "ideal" Squared with 225/45/17 ,235/45/17,some have even used 255/40/17
4.5 will work in some cases.These cars are all a bit different production tolerance wasn't job 1 back in the day. also depends on alignment specs and how low the car sits
Just for reference these pics are 17x8x4.75ish 225/45/17(could have gone bigger but tires where free) 05+ Bullitts with 1.5" adapter UCA drop 1/2 coil cut off 620's -1.5 camber +4.5 caster 1/8 toe in
2nd 66 is offline
post #4 of 10 (permalink) Old 06-18-2019, 07:57 PM
NEFaurora's Avatar
Acapulco Blue and AR Outlaw II's........Thumbs Up.... A great combination!
Can you tell that I'm a fan..... My old '69 Falcon Below... The last pic was in her later years.....just before I sold her in 2005..
Tony K.
2nd 66 likes this.
Tony Kovar
1965 Mustang Convertible 200cid I6, 3spd Manual (Soon to be swapped for a '65 Date Coded C4!)
MCA#70001
Getting Ready for the 2020 Melbourne, FL MCA Nationals!
NEFaurora is online now
post #5 of 10 (permalink) Old 06-18-2019, 08:25 PM
that wheel does not have enough backspace....
CJM68GT390 is offline
post #6 of 10 (permalink) Old 06-18-2019, 08:38 PM
blueovalfan68's Avatar
Originally Posted by jakeinarkansas View Post
Hello,
Will these work?
Jacob
I also have a 68 coupe. The 17x7 with 0mm offset works perfect (smallish in my opinion, but def works with no issues). The 17x8 with the -11mm offset will stick out. With a 17x8, you’re looking for 0mm offset (4.5” backspace) or ideally +6mm offset (4.75” backspace).
2nd 66 likes this.
-Chris
'68 Mustang
347ci that has a lot of neat stuff in it
T5 manual trans, alum driveshaft, 9" w/3.70 gears
Suspension parts from SoT, Global West, Maier Racing, and a few others. Works for me!
TCP manual rack (love it)
EPAS (Love this the most)
VWW V45 wheels (like these too)
SoT 13" brakes (stopping is good)
And I finally got a paint job!
blueovalfan68 is offline
post #7 of 10 (permalink) Old 06-19-2019, 08:50 PM
I run 17x8 4.75 BS torque thrust II. 235/45 up front and 255x45 in the rear. Opentracker suspension. Shelby drop and a half coil cut up front. I have no rubbing issues. I’m happy with the way they tuck.
File Type: jpg 95AEEAA7-0366-4DEC-95F3-D92D1609A9F5_1560991797894.jpg (447.6 KB, 10 views)
File Type: jpg 81CFEF7D-4F17-4BC4-A8AE-41FC0AC8295F_1560992270717.jpg (391.8 KB, 10 views)
2nd 66 likes this.
Ptool2000 is offline
post #8 of 10 (permalink) Old 07-02-2019, 01:43 PM Thread Starter
Finally got them 17x7!
File Type: jpg F5F68B04-DA6F-4AD7-8A1A-6F76EBCFDA94_1562088970837.jpg (504.9 KB, 11 views)
post #9 of 10 (permalink) Old 07-02-2019, 05:40 PM
Looks good bud.
-Chris
'68 Mustang
post #10 of 10 (permalink) Old 07-02-2019, 08:16 PM
Grabber70Mach's Avatar
Looks good
Grabber70Mach is online now
