Bottoming out and rubbing - Vintage Mustang Forums
 3Likes
  • 3 Post By awhtx
post #1 of 9 (permalink) Old 07-12-2019, 05:07 PM Thread Starter
Having issues bottoming out all the time and rubbing.
I think I have only 2 options. Put back a bigger set of springs have some performance lowered ones or change the tire.
Right now p215/60r15. Could try a p205/50r15
But that would lower the car even more. It's pretty common size so has to be the lowering springs
Thoughts? Not sure of the back spacing on the shelby rims
duberz is offline
post #2 of 9 (permalink) Old 07-12-2019, 08:35 PM
awhtx's Avatar
215/60R15 should not rub or bottom out. Perhaps your springs are completely worn out.
subpar63, 2nd 66 and 4ocious like this.
awhtx is offline
post #3 of 9 (permalink) Old 07-12-2019, 08:48 PM
Full gallop this way --->
4ocious's Avatar
I agree 100% with awhtx. It's not the tires. And although the backspacing on those wheels may not be exactly optimal, they aren't that far off either. The clearance in your pic looks good too. Something else is kerflooey and shot springs are the most likely suspects.
4ocious is offline
post #4 of 9 (permalink) Old 07-12-2019, 09:12 PM
Russstang's Avatar
Springs and shocks. Weak springs will allow it to move way too much and worn shocks wont slow this motion down. Bad combination.
Get off my back, get out of my pocket....
1965 2+2 painted (66) Vintage Burgundy, 1998 roller 5.0 with GT40P heads, plans are for Sniper, T5 and 3:55 rear.
Russstang is online now
post #5 of 9 (permalink) Old 07-12-2019, 09:14 PM
It's all about the right backspace
My car is lowered quit a bit with larger wheels/tires and I don't have that issue
2nd 66 is offline
post #6 of 9 (permalink) Old 07-13-2019, 11:41 AM
antho's Avatar
What size tires and are you running spacers up front? If so, what size? Thank you
antho is offline
post #7 of 9 (permalink) Old 07-13-2019, 07:25 PM
the pic shows 17x8 05+Bullitts using a 1.5" wheel adapter making for 4.75ish backspacing which is considered ideal. The tires are 225/45/17(got them free) but I have room for more 235/45/17 for sure maybe 255/40/17 even
the three basics are
15x7x4.25
16x8x4.50
17x8x4.75
of course these cars being built in the millions had pretty loose production tolerances and after 50 years of who knows what, other thing such as alignment specs can make a difference as well
2nd 66 is offline
post #8 of 9 (permalink) Old 07-14-2019, 11:17 PM
antho's Avatar
Thank you. I currently have 235/55/17 on the same wheel with 1.5 adapters. No rub in the rear so I may keep that size but go narrower up front. Thanks for the info.
antho is offline
post #9 of 9 (permalink) Old 07-14-2019, 11:37 PM
55's are a bit tall
2nd 66 is offline
